No ICMPv6 echo replies on vrf
Hey, thats very strange. I got a router running on VyOS 1.5-stream-2025-Q2 and only on eth0 it send back ICMP echo replies. On my own subnet on vrf net it does not send echo replies back but receives echo requests. Also after I explicitly allow ipv6-icmp on firewall there is no echo reply outgoing. Did anyone had this strange behavior?
With similar config (only other IPs) ICMP echos are replied. Only not on my VMs. Also recreating the VM did not fix it.
Summary
firewall {
ipv6 {
input {
filter {
rule 1 {
action accept
destination {
port 222
protocol tcp
address xxxx:xxxx:1c1c:7113::/64
rule 2 {
action accept
destination {
port 222
protocol tcp
address xxxx:xxxx:c0c:abb2::/64
rule 3 {
action accept
protocol ipv6-icmp
rule 10 {
action drop
destination {
port 222
protocol tcp
dummy dum0 {
address xxxx:xxxx:d41::ce:0/128
vrf net
address xxxx:xxxx:1b7:730::a/56
hw-id xx:xx:xx:xx:xx:d7
offload {
gro
gso
sg
tso
address xxxx:xxxx:15b:1::1:7/64
hw-id xx:xx:xx:xx:xx:96
offload {
gro
gso
sg
tso
vrf net
loopback lo {
tunnel tun001 {
address xxxx:xxxx:d41::8000/127
description core-w0.draphago.de
encapsulation ip6gre
mtu 1376
remote xxxx:xxxx:1c1c:f2c:1001:101:1:2
source-address xxxx:xxxx:1b7:730::a
vrf net
tunnel tun213292 {
address xxxx:xxxx:d41::2:1/127
description Okkel-Router
mtu 1456
remote xxxx:xxxx:1b7:730::7
vrf net
policy {
as-path-list apl-bogon-asns {
rule 10 {
action permit
regex 23456
rule 20 {
action permit
regex 64496-131071
rule 30 {
action permit
regex 4200000000-4294967295
large-community-list cm-learnt-downstream {
rule 1 {
action permit
regex “213036:4:"
large-community-list lcm-own-communities {
rule 1 {
action permit
regex "213036:
prefix-list6 pl6-bogons {
rule 10 {
action permit
le 128
prefix ::/8
rule 20 {
action permit
le 128
prefix 100::/64
rule 30 {
action permit
le 128
prefix xxxx:xxxx::/48
rule 40 {
action permit
le 128
prefix xxxx:xxxx::/28
rule 50 {
action permit
le 128
prefix xxxx:xxxx::/32
rule 60 {
action permit
le 128
prefix 2002::/16
rule 70 {
action permit
le 128
prefix 3ffe::/16
rule 80 {
action permit
le 128
prefix fc00::/7
rule 90 {
action permit
le 128
prefix fe80::/10
rule 100 {
action permit
le 128
prefix fec0::/10
rule 110 {
action permit
le 128
prefix ff00::/8
rule 120 {
action permit
le 128
prefix 3fff::/20
rule 130 {
action permit
le 128
prefix 5f00::/16
prefix-list6 pl6-ixp-lan {
rule 1 {
action permit
ge 64
le 128
prefix xxxx:xxxx:701::/64
rule 2 {
action permit
ge 64
le 128
prefix xxxx:xxxx:1000:46::/64
rule 3 {
action permit
ge 64
le 128
prefix xxxx:xxxx:15b:1::/64
prefix-list6 pl6-own-prefixes {
rule 1 {
action permit
ge 48
le 48
prefix xxxx:xxxx:d41::/48
prefix-list6 pl6-tiny-prefix {
rule 10 {
action permit
ge 49
le 128
prefix ::/0
route-map rm-noexport {
rule 1 {
action deny
route-map rm-noimport {
rule 1 {
action deny
route-map rm-as213422-in {
rule 1 {
action deny
match {
as-path apl-bogon-asns
rule 2 {
action deny
match {
ipv6 {
address {
prefix-list pl6-bogons
rule 3 {
action deny
match {
ipv6 {
address {
prefix-list pl6-tiny-prefix
rule 4 {
action deny
match {
rpki invalid
rule 5 {
action deny
match {
ipv6 {
address {
prefix-list pl6-ixp-lan
rule 65535 {
action permit
set {
large-community {
add 213036:1:213422
add 213036:0:0
local-preference 50
route-map rm-frankonix-in {
rule 1 {
action deny
match {
rule 2 {
action deny
match {
ipv6 {
address {
rule 3 {
action deny
match {
ipv6 {
address {
rule 4 {
action deny
match {
rpki invalid
rule 5 {
action deny
match {
ipv6 {
address {
rule 65535 {
action permit
set {
large-community {
add 213036:2:214591
add 213036:0:0
local-preference 150
route-map rm-internal-in {
rule 1 {
action permit
route-map rm-internal-out {
rule 1 {
action deny
match {
ipv6 {
address {
prefix-list pl6-own-prefixes
rule 65535 {
action permit
route-map rm-peer-out {
rule 1 {
action deny
match {
rpki invalid
rule 2 {
action permit
match {
large-community {
route-map rm-set-src {
rule 1 {
action permit
set {
src xxxx:xxxx:b7a::ce:0
route-map rm-tag-downstream {
rule 1 {
action permit
set {
large-community {
add 213036:4:213036
route-map rm-upstream-out {
rule 1 {
action deny
match {
rpki invalid
rule 2 {
action permit
match {
large-community {
protocols {
rpki {
cache routinator.xnee.net {
port 8282
preference 1
static {
route6 ::/0 {
next-hop xxxx:xxxx:1b7:700::1 {
interface eth0
service {
lldp {
ntp {
allow-client xxxxxx
address xxx.xxx.0.0/8
address xxx.xxx.0.0/16
address xxx.xxx.0.0/12
address ::1/128
address fe80::/10
address fc00::/7
server xxxxx.tld {
server xxxxx.tld {
server xxxxx.tld {
ssh {
access-control {
allow {
user xxxxxx
listen-address xxxx:xxxx:1b7:730::a
port 222
system {
config-management {
commit-revisions 100
console {
device ttyS0 {
speed 115200
host-name xxxxxx
login {
user xxxxxx {
authentication {
encrypted-password xxxxxx
public-keys xxxx@xxx.xxx {
key xxxxxx
type ssh-ed25519
key xxxxxx
type ssh-ed25519
key xxxxxx
type ssh-ed25519
full-name xxxxxx
name-server xxxx:xxxx::fe
name-server xxxx:xxxx::9
option {
ctrl-alt-delete reboot
kernel {
debug {
keyboard-layout de
reboot-on-panic
reboot-on-upgrade-failure 5
time-format 24-hour
syslog {
local {
facility all {
level info
facility local7 {
level debug
time-zone Europe/Berlin
vrf {
name net {
ipv6 {
protocol any {
protocols {
bgp {
address-family {
ipv6-unicast {
aggregate-address xxxx:xxxx:d41::/48 {
redistribute {
connected {
neighbor xxxx:xxxx:15b:1::1:4 {
address-family {
ipv6-unicast {
maximum-prefix 300000
nexthop-self {
route-map {
export rm-upstream-out
import rm-as213422-in
soft-reconfiguration {
inbound
description XGWQ
local-role customer {
remote-as XXXXXX
neighbor xxxx:xxxx:15b:1::c122:cbc1 {
address-family {
ipv6-unicast {
maximum-prefix 300
nexthop-self {
route-map {
export rm-peer-out
import rm-frankonix-in
inbound
bfd {
description frankonIX
local-role rs-client xxxxxx
remote-as XXXXXX
neighbor xxxx:xxxx:15b:1::c122:cbc2 {
address-family {
ipv6-unicast {
maximum-prefix 300
nexthop-self {
route-map {
export rm-peer-out
inbound
bfd {
remote-as XXXXXX
parameters {
ebgp-requires-policy
log-neighbor-changes
router-id xxx.xxx.0.1
system-as 213036
table 100
Issue also exists on other hypervisors.
