Hello there,
I set to No-IP DDNS, it working well, but the website say that is not sync..
I set it yesterday, but today i restart my VyOS, but the ddns not update automatically… (i wait about half and hour)
it is normal? How many time to sync it?
which version of VyOS.
show relevant part of config please
Version: VyOS 1.2.0-rolling+201804110337
Built by: autobuild@vyos.net
Built on: Wed 11 Apr 2018 03:37 UTC
Build ID: a7cf1949-4659-43e8-82ca-1db806310d4b
Architecture: x86_64
Boot via: installed image
System type: KVM guest
Hardware vendor: QEMU
Hardware S/N:
Hardware UUID: 5EC01258-023E-4D67-9549-5B942B664D26
config
dns {
dynamic {
interface eth0 {
service noip {
host-name *****.ddns.net
login *********
password ****************
Edit:
Ahhh it possible that i found the problem
I use PPPOE, but set to eth0 to source interface, instead of pppoe 1…
What do you think?
I think i would like to know if it work on pppoe
also if it works after reboot (suspect that it can be issue if pppoe shows up later)
Working, thanks!
By any chance you want do quick guide with screenshots ?
Thats all:
# edit service dns dynamic interface pppoe 1 service noip
# set login my-login
# set password my-password
# set host-name my-dyndns-hostname
i mean screenshots from no-ip
i do nothing in no-ip site. That is all i can see:
