Hi, I am trying to config VTI interface for routing between sites, and found discrepancy between document and reality that I am unable to config IPv6 address in VTI interface.
According to document,
https://docs.vyos.io/en/latest/configuration/interfaces/tunnel.html?highlight=VTI#virtual-tunnel-interface-vti
The VTI interface can config both IPv4 and IPv6 address together (and I hope to run BGP routing with my Juniper SRX clusters through this vpn)
However, when I input IPv6 address to VTI interface, the error message said itβs not a valid address. Anyone experienced same? Should I use a specific version in order to use this function? Thanks.
The error message looks like this
[edit interfaces] vyos@lab3a# set vti vti0 address 2001:db8:2::249/64 "2001:db8:2::249/64" is not a valid value of type "ipv4net" Value validation failed Set failed
