2 networks,. each with their own subnet configuration. each with their own internet connection (my house and neighbors house im trying to let on to my Plex server without using our internet connection since we both have Starlink and the upstream isnt great.)
network 1, 192.168.50.0/24
network 2, 192.168.1.0/24
wireless ethernet bridge on the 192.168.1.0/24 network (engenius enh500v3).
the bridge terminates at an esxi host with 2 nics (vswitches).
vyos is running as virtual machine on esxi host and can see both networks.
but i dont feel like this is right. im not trying to provide access to an internet connection… it seems like traffic should flow both ways, not all designated to eth0 as an outbound. if i remove the nat entirely, i cant ping anything on the other network. if i leave it there, then everything show’s as source the .254 for each network, where as, with my logging, id like to see individual class c ip addresses for each subnet.
Are these configured on the default gateways/routers of each network? Normally if it doesn’t work without NAT it’s because of a lack of correct routes in my experience.
My other thought is that maybe firewall on a gateway is blocking traffic from the other subnet. If there are traffic logs available on either, I would suggest checking that. You could also use the monitor traffic interface operational command in VyOS to see if return packets are even hitting VyOS.
Yes, I dont have any problems pinging individual hosts from vyos. however, unable to ping across the the subnet’s from client machines without the nat rule in place.
vyos@vyos:~$ show ip route
f - OpenFabric,
C>* 192.168.1.0/24 is directly connected, eth1, 22:50:31
C>* 192.168.50.0/24 is directly connected, eth0, 22:50:31
vyos@vyos:~$ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
192.168.50.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
vyos@vyos:~$
yes, this is with it on the qnap. same nic configuration,etc. not sure what would be different which is now causing it to perform like it should. very strange.
