I need to install the build-essential package to compile softethervpn on my new vyos kvm micro server.
But i can not install the build-essential package due to missing packages.
Can somebody ehlp me how to install the build tools?
i try to install build-essential with apt-get
sudo apt-get install -y build-essential
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
build-essential : Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: g++ (>= 4:4.4.3) but it is not going to be installed
E: Broken packages
I already did an
and here is my config of repos:
show system package
repository community {
components main
distribution helium
repository squeeze {
components "main contrib non-free"
distribution squeeze
password ""
url http://debian.ethz.ch/debian
I don’t think building packages under a vyos install is supported. You might see 510 Software Group for a procedure that works for me to rebuild an iso from source code. You could modify that to add the softethervpn package.
rebuild iso is better way, but
I can install build-essential with the following command on VyOS 1.1.0.
Maybe first two line does not need.
conf
set system package repository squeeze components 'main contrib non-free'
set system package repository squeeze distribution 'squeeze'
set system package repository squeeze url 'http://mirrors.kernel.org/debian'
commit
save
sudo apt-get update
sudo apt-get install build-essential
Version: VyOS 1.1.0
Description: VyOS 1.1.0 (helium)
Copyright: 2014 VyOS maintainers and contributors
Built by: [email protected]
Built on: Thu Oct 9 22:27:26 UTC 2014
Build ID: 1410092227-af6433f
System type: x86 64-bit
Boot via: disk
Hypervisor: KVM
Log.
vyos@vyos# set system package repository squeeze components 'main contrib non-free'
Configuration path: [system package repository squeeze components main contrib non-free] already exists
vyos@vyos# set system package repository squeeze distribution 'squeeze'
Configuration path: [system package repository squeeze distribution squeeze] already exists
vyos@vyos# set system package repository squeeze url 'http://mirrors.kernel.org/debian'
vyos@vyos# commit
[ system package repository squeeze ]
Updating /etc/apt/sources.list...
vyos@vyos# save
Saving configuration to '/config/config.boot'...
Done
vyos@vyos# sudo apt-get update
Get:1 http://ftp.jp.debian.org squeeze-lts Release.gpg [836 B]
Ign http://ftp.jp.debian.org/debian/ squeeze-lts/contrib Translation-en
Ign http://ftp.jp.debian.org/debian/ squeeze-lts/main Translation-en
Ign http://ftp.jp.debian.org/debian/ squeeze-lts/non-free Translation-en
Get:2 http://ftp.jp.debian.org squeeze-lts Release [28.7 kB]
Get:3 http://ftp.jp.debian.org squeeze-lts/main amd64 Packages [120 kB]
Get:4 http://ftp.jp.debian.org squeeze-lts/contrib amd64 Packages [20 B]
Get:5 http://ftp.jp.debian.org squeeze-lts/non-free amd64 Packages [20 B]
Get:6 http://packages.vyos.net helium Release.gpg [836 B]
Get:7 http://mirrors.kernel.org squeeze Release.gpg [1655 B]
Ign http://mirrors.kernel.org/debian/ squeeze/contrib Translation-en
Ign http://mirrors.kernel.org/debian/ squeeze/main Translation-en
Ign http://mirrors.kernel.org/debian/ squeeze/non-free Translation-en
Get:8 http://mirrors.kernel.org squeeze Release [96.0 kB]
Ign http://packages.vyos.net/vyos/ helium/main Translation-en
Get:9 http://packages.vyos.net helium Release [1666 B]
Get:10 http://mirrors.kernel.org squeeze/main amd64 Packages [8370 kB]
Get:11 http://packages.vyos.net helium/main amd64 Packages [36.4 kB]
Get:12 http://mirrors.kernel.org squeeze/contrib amd64 Packages [61.7 kB]
Get:13 http://mirrors.kernel.org squeeze/non-free amd64 Packages [121 kB]
Fetched 8839 kB in 5s (1524 kB/s)
vyos@vyos# show config
Configuration path: [config] is not valid
Show failed
vyos@vyos# sudo apt-get install build-essential
The following extra packages will be installed:
binutils bzip2 cpp cpp-4.4 dpkg-dev g++ g++-4.4 gcc gcc-4.4 libc-dev-bin
libc6-dev libdpkg-perl libgomp1 libmpfr4 libstdc++6-4.4-dev linux-libc-dev
make
Suggested packages:
binutils-doc bzip2-doc cpp-doc gcc-4.4-locales debian-keyring g++-multilib
g++-4.4-multilib gcc-4.4-doc libstdc++6-4.4-dbg gcc-multilib manpages-dev
autoconf automake1.9 libtool flex bison gdb gcc-doc gcc-4.4-multilib
libmudflap0-4.4-dev libgcc1-dbg libgomp1-dbg libmudflap0-dbg libcloog-ppl0
libppl-c2 libppl7 glibc-doc libstdc++6-4.4-doc make-doc
Recommended packages:
fakeroot libalgorithm-merge-perl
The following NEW packages will be installed:
binutils build-essential bzip2 cpp cpp-4.4 dpkg-dev g++ g++-4.4 gcc gcc-4.4
libc-dev-bin libc6-dev libdpkg-perl libgomp1 libmpfr4 libstdc++6-4.4-dev
linux-libc-dev make
0 upgraded, 18 newly installed, 0 to remove and 34 not upgraded.
Need to get 23.9 MB of archives.
After this operation, 71.7 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://mirrors.kernel.org/debian/ squeeze/main binutils amd64 2.20.1-16 [3993 kB]
Get:2 http://mirrors.kernel.org/debian/ squeeze/main libmpfr4 amd64 3.0.0-2 [474 kB]
Get:3 http://mirrors.kernel.org/debian/ squeeze/main cpp-4.4 amd64 4.4.5-8 [3873 kB]
Get:4 http://ftp.jp.debian.org/debian/ squeeze-lts/main libc-dev-bin amd64 2.11.3-4+deb6u1 [210 kB]
Get:5 http://mirrors.kernel.org/debian/ squeeze/main cpp amd64 4:4.4.5-1 [15.0 kB]
Get:6 http://ftp.jp.debian.org/debian/ squeeze-lts/main libc6-dev amd64 2.11.3-4+deb6u1 [2583 kB]
Get:7 http://packages.vyos.net/vyos/ helium/main linux-libc-dev amd64 3.13.11-1+vyos1+helium5 [1003 kB]
Get:8 http://mirrors.kernel.org/debian/ squeeze/main libgomp1 amd64 4.4.5-8 [25.3 kB]
Get:9 http://mirrors.kernel.org/debian/ squeeze/main gcc-4.4 amd64 4.4.5-8 [2688 kB]
Get:10 http://mirrors.kernel.org/debian/ squeeze/main gcc amd64 4:4.4.5-1 [4970 B]
Get:11 http://mirrors.kernel.org/debian/ squeeze/main libstdc++6-4.4-dev amd64 4.4.5-8 [1526 kB]
Get:12 http://mirrors.kernel.org/debian/ squeeze/main g++-4.4 amd64 4.4.5-8 [5515 kB]
Get:13 http://mirrors.kernel.org/debian/ squeeze/main g++ amd64 4:4.4.5-1 [1376 B]
Get:14 http://mirrors.kernel.org/debian/ squeeze/main make amd64 3.81-8 [398 kB]
Get:15 http://mirrors.kernel.org/debian/ squeeze/main libdpkg-perl all 1.15.11 [698 kB]
Get:16 http://mirrors.kernel.org/debian/ squeeze/main bzip2 amd64 1.0.5-6+squeeze1 [50.5 kB]
Get:17 http://mirrors.kernel.org/debian/ squeeze/main dpkg-dev all 1.15.11 [815 kB]
Get:18 http://mirrors.kernel.org/debian/ squeeze/main build-essential amd64 11.5 [7178 B]
Fetched 23.9 MB in 12s (1924 kB/s)
Selecting previously deselected package binutils.
(Reading database ... 38964 files and directories currently installed.)
Unpacking binutils (from .../binutils_2.20.1-16_amd64.deb) ...
Selecting previously deselected package libc-dev-bin.
Unpacking libc-dev-bin (from .../libc-dev-bin_2.11.3-4+deb6u1_amd64.deb) ...
Selecting previously deselected package linux-libc-dev.
Unpacking linux-libc-dev (from .../linux-libc-dev_3.13.11-1+vyos1+helium5_amd64.deb) ...
Selecting previously deselected package libc6-dev.
Unpacking libc6-dev (from .../libc6-dev_2.11.3-4+deb6u1_amd64.deb) ...
Selecting previously deselected package libmpfr4.
Unpacking libmpfr4 (from .../libmpfr4_3.0.0-2_amd64.deb) ...
Selecting previously deselected package cpp-4.4.
Unpacking cpp-4.4 (from .../cpp-4.4_4.4.5-8_amd64.deb) ...
Selecting previously deselected package cpp.
Unpacking cpp (from .../cpp_4%3a4.4.5-1_amd64.deb) ...
Selecting previously deselected package libgomp1.
Unpacking libgomp1 (from .../libgomp1_4.4.5-8_amd64.deb) ...
Selecting previously deselected package gcc-4.4.
Unpacking gcc-4.4 (from .../gcc-4.4_4.4.5-8_amd64.deb) ...
Selecting previously deselected package gcc.
Unpacking gcc (from .../gcc_4%3a4.4.5-1_amd64.deb) ...
Selecting previously deselected package libstdc++6-4.4-dev.
Unpacking libstdc++6-4.4-dev (from .../libstdc++6-4.4-dev_4.4.5-8_amd64.deb) ...
Selecting previously deselected package g++-4.4.
Unpacking g++-4.4 (from .../g++-4.4_4.4.5-8_amd64.deb) ...
Selecting previously deselected package g++.
Unpacking g++ (from .../g++_4%3a4.4.5-1_amd64.deb) ...
Selecting previously deselected package make.
Unpacking make (from .../archives/make_3.81-8_amd64.deb) ...
Selecting previously deselected package libdpkg-perl.
Unpacking libdpkg-perl (from .../libdpkg-perl_1.15.11_all.deb) ...
Selecting previously deselected package bzip2.
Unpacking bzip2 (from .../bzip2_1.0.5-6+squeeze1_amd64.deb) ...
Selecting previously deselected package dpkg-dev.
Unpacking dpkg-dev (from .../dpkg-dev_1.15.11_all.deb) ...
Selecting previously deselected package build-essential.
Unpacking build-essential (from .../build-essential_11.5_amd64.deb) ...
Processing triggers for man-db ...
Setting up binutils (2.20.1-16) ...
Setting up libc-dev-bin (2.11.3-4+deb6u1) ...
Setting up linux-libc-dev (3.13.11-1+vyos1+helium5) ...
Setting up libc6-dev (2.11.3-4+deb6u1) ...
Setting up libmpfr4 (3.0.0-2) ...
Setting up cpp-4.4 (4.4.5-8) ...
Setting up cpp (4:4.4.5-1) ...
Setting up libgomp1 (4.4.5-8) ...
Setting up gcc-4.4 (4.4.5-8) ...
Setting up gcc (4:4.4.5-1) ...
Setting up make (3.81-8) ...
Setting up libdpkg-perl (1.15.11) ...
Setting up bzip2 (1.0.5-6+squeeze1) ...
Setting up dpkg-dev (1.15.11) ...
Setting up libstdc++6-4.4-dev (4.4.5-8) ...
Setting up g++-4.4 (4.4.5-8) ...
Setting up g++ (4:4.4.5-1) ...
update-alternatives: using /usr/bin/g++ to provide /usr/bin/c++ (c++) in auto mode.
Setting up build-essential (11.5) ...
vyos@vyos:~$ gcc
gcc: no input files
many thanks for the link. so i know my plans are not impossible
I have setup a new vyos kvm on my virtualbox and just set up the primary ethernet with dhcp. then i tried to follow the how to you mentioned.
Its no problem to understand but the same error with dependencies.
I also did not change the package mirror.
And my try with import the compiled package form a debian squeeze vm does work but if i try to create a tap interface i get kernel panic.
So i have to try some more things to get softether working on vyos…
before I had softether running on the same vps on a vyatta base. I really like the possibilities with both packages.
you can do all the site2site vpn with a cheap and fast server and also the clients can connect to the whole network without complicated setup
next i will try to install build-essentials on a vyos-1.1.0-i586-virt system.
here my logs:
vyos@vyos:~$ show version
Version: VyOS 1.1.0
Boot via: image
Hypervisor: VirtualBox
HW model: VirtualBox
HW S/N: 0
HW UUID: 9E54C8A0-7C34-42FF-9C73-2BDF3879B7F7
Uptime: 14:25:31 up 10 min, 2 users, load average: 0.00, 0.01, 0.02
and here the log of my settings:
vyos@vyos# set system package repository squeeze components 'main'
vyos@vyos# set system package repository squeeze url 'http://ftp.jp.debian.org/d ebian/'
vyos@vyos# commit
Adding new entry to /etc/apt/sources.list...
vyos@vyos# save
Done
vyos@vyos# exit
exit
vyos@vyos:~$ sudo aptitude update
Get:1 http://packages.vyos.net helium Release.gpg [836 B]
Get:2 http://packages.vyos.net helium Release [1666 B]
Get:3 http://packages.vyos.net helium/main amd64 Packages [36.4 kB]
Get:4 http://ftp.jp.debian.org squeeze Release.gpg [1655 B]
Ign http://ftp.jp.debian.org/debian/ squeeze/main Translation-en
Get:5 http://ftp.jp.debian.org squeeze Release [96.0 kB]
Get:6 http://ftp.jp.debian.org squeeze/main amd64 Packages [8370 kB]
Fetched 8507 kB in 8s (1010 kB/s)
Current status: 20 updates [+20], 27794 new [+27713].
vyos@vyos:~$ sudo aptitude -y install build-essential
binutils{a} build-essential bzip2{a} cpp{a} cpp-4.4{a} dpkg-dev{a} g++{a}
g++-4.4{a} gcc{a} gcc-4.4{a} libc-dev-bin{a} libc6-dev{ab}
libdpkg-perl{a} libgomp1{a} libmpfr4{a} libstdc++6-4.4-dev{a}
linux-libc-dev{a} make{a}
The following packages are RECOMMENDED but will NOT be installed:
fakeroot libalgorithm-merge-perl manpages-dev
0 packages upgraded, 18 newly installed, 0 to remove and 20 not upgraded.
Need to get 23.9 MB of archives. After unpacking 71.9 MB will be used.
libc6-dev: Depends: libc6 (= 2.11.3-4) but 2.11.3-4+deb6u1 is installed.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) build-essential [Not Installed]
2) g++ [Not Installed]
3) g++-4.4 [Not Installed]
4) libc6-dev [Not Installed]
5) libstdc++6-4.4-dev [Not Installed]
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
i did the test with the checksum. it was identical to yours.
but i found the solution or at least a way to install build-essentials.
i had to install it with aptitude and have to cancel the first offerd solution.
no i will try to make the softether package
here is my log: (package repository squeeze components ‘main contrib non-free’)
sudo aptitude install build-essential
Accept this solution? [Y/n/q/?] n
Downgrade the following packages:
1) libc-bin [2.11.3-4+deb6u1 (now) -> 2.11.3-4 (oldstable)]
2) libc6 [2.11.3-4+deb6u1 (now) -> 2.11.3-4 (oldstable)]
Accept this solution? [Y/n/q/?] y
The following packages will be DOWNGRADED:
libc-bin libc6
g++-4.4{a} gcc{a} gcc-4.4{a} libc-dev-bin{a} libc6-dev{a} libdpkg-perl{a}
libgomp1{a} libmpfr4{a} libstdc++6-4.4-dev{a} linux-libc-dev{a} make{a}
0 packages upgraded, 18 newly installed, 2 downgraded, 0 to remove and 20 not up graded.
Need to get 28.9 MB of archives. After unpacking 72.0 MB will be used.
Do you want to continue? [Y/n/?] y
Get:1 http://mirrors.kernel.org/debian/ squeeze/main libc-bin amd64 2.11.3-4 [74 9 kB]
Get:2 http://mirrors.kernel.org/debian/ squeeze/main libc6 amd64 2.11.3-4 [4282 kB]
Get:3 http://packages.vyos.net/vyos/ helium/main linux-libc-dev amd64 3.13.11-1+ vyos1+helium5 [1003 kB]
Get:4 http://mirrors.kernel.org/debian/ squeeze/main binutils amd64 2.20.1-16 [3 993 kB]
Get:5 http://mirrors.kernel.org/debian/ squeeze/main libc-dev-bin amd64 2.11.3-4 [210 kB]
Get:6 http://mirrors.kernel.org/debian/ squeeze/main libc6-dev amd64 2.11.3-4 [2 593 kB]
Get:7 http://mirrors.kernel.org/debian/ squeeze/main libmpfr4 amd64 3.0.0-2 [474 kB]
Get:8 http://mirrors.kernel.org/debian/ squeeze/main cpp-4.4 amd64 4.4.5-8 [3873 kB]
Get:9 http://mirrors.kernel.org/debian/ squeeze/main cpp amd64 4:4.4.5-1 [15.0 k B]
Get:10 http://mirrors.kernel.org/debian/ squeeze/main libgomp1 amd64 4.4.5-8 [25 .3 kB]
Get:11 http://mirrors.kernel.org/debian/ squeeze/main gcc-4.4 amd64 4.4.5-8 [268 8 kB]
Get:12 http://mirrors.kernel.org/debian/ squeeze/main gcc amd64 4:4.4.5-1 [4970 B]
Get:13 http://mirrors.kernel.org/debian/ squeeze/main libstdc++6-4.4-dev amd64 4 .4.5-8 [1526 kB]
Get:14 http://mirrors.kernel.org/debian/ squeeze/main g++-4.4 amd64 4.4.5-8 [5515 kB]
Get:15 http://mirrors.kernel.org/debian/ squeeze/main g++ amd64 4:4.4.5-1 [1376 B]
Get:16 http://mirrors.kernel.org/debian/ squeeze/main make amd64 3.81-8 [398 kB]
Get:17 http://mirrors.kernel.org/debian/ squeeze/main libdpkg-perl all 1.15.11 [698 kB]
Get:18 http://mirrors.kernel.org/debian/ squeeze/main bzip2 amd64 1.0.5-6+squeeze1 [50.5 kB]
Get:19 http://mirrors.kernel.org/debian/ squeeze/main dpkg-dev all 1.15.11 [815 kB]
Get:20 http://mirrors.kernel.org/debian/ squeeze/main build-essential amd64 11.5 [7178 B]
Fetched 28.9 MB in 20s (1379 kB/s)
Preconfiguring packages ...
dpkg: warning: downgrading libc-bin from 2.11.3-4+deb6u1 to 2.11.3-4.
Preparing to replace libc-bin 2.11.3-4+deb6u1 (using .../libc-bin_2.11.3-4_amd64.deb) ...
Unpacking replacement libc-bin ...
Setting up libc-bin (2.11.3-4) ...
dpkg: warning: downgrading libc6 from 2.11.3-4+deb6u1 to 2.11.3-4.
Preparing to replace libc6 2.11.3-4+deb6u1 (using .../libc6_2.11.3-4_amd64.deb) ...
Unpacking replacement libc6 ...
Setting up libc6 (2.11.3-4) ...
Unpacking libc-dev-bin (from .../libc-dev-bin_2.11.3-4_amd64.deb) ...
Unpacking libc6-dev (from .../libc6-dev_2.11.3-4_amd64.deb) ...
Setting up libc-dev-bin (2.11.3-4) ...
Setting up libc6-dev (2.11.3-4) ...
