NTP not syncing with dummy interface
Running version: VyOS 1.4-rolling-202206300217
If I bind the NTP server to a dummy interface, I cannot get NTP client (ubuntu 22.04) to sync.
nmap -sU -p 123 <<DUMMY_HOST_IP>> shows the port is open, but sync state remains ‘unsynced’.
I tried on VyOS 1.4-rolling-202207030217 as a server. Debian 11 and Windows 10 as clients. And it works.
Server config:
set interfaces dummy dum1 address '192.168.1.1/32'
set system ntp allow-clients address '192.168.17.0/24'
set system ntp listen-address '192.168.1.1'
set system ntp server pool.ntp.org
Still having this issue; you are correct that I can sync with the dummy interface; but only as long as I also bind the NTP to a ‘real’ interface as well. If I remove all binds to ‘real’ interfaces and only set listen-address to the dummy interface, NTP is not syncing…
Do you have snat rules to allow ip address on dummy interface to communicate with external ntp servers?
Don’t know how I missed that… Thanks; looks like it’s solved, misconfig on my side! TY!
