NVME-oF auto-connect
On boot i’ve got an issue on the service nvme-autoconnect
× nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot
     Loaded: loaded (/lib/systemd/system/nvmf-autoconnect.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Sat 2023-05-20 11:33:56 CEST; 1min 52s ago
    Process: 5738 ExecStartPre=/sbin/modprobe nvme-fabrics (code=exited, status=1/FAILURE)
        CPU: 1ms
May 20 11:33:56 vy-home systemd[1]: Starting nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot...
May 20 11:33:56 vy-home modprobe[5738]: modprobe: FATAL: Module nvme-fabrics not found in directory /lib/modules/6.1.28-amd64-vyos
May 20 11:33:56 vy-home systemd[1]: nvmf-autoconnect.service: Control process exited, code=exited, status=1/FAILURE
May 20 11:33:56 vy-home systemd[1]: nvmf-autoconnect.service: Failed with result 'exit-code'.
May 20 11:33:56 vy-home systemd[1]: Failed to start nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot.
Should be fixed in T5208
