Hi there,
I’m testing the DMVPN solution provided on the Link below:
https://whiskeyalpharomeo.com/2016/09/16/vyos-testing-dmvpn/
I’m facing a routing problem with routes redistributed from OSPF into BGP protocol as you can see below:
vyos@wrw-rtr-vyos1:~$ show ip route
S>* 0.0.0.0/0 [1/0] via 10.170.191.254, eth0
C>* 4.0.0.0/32 is directly connected, lo
O 5.8.128.0/24 [110/10] is directly connected, eth1, 02w1d20h
C>* 5.8.128.0/24 is directly connected, eth1
O 5.144.48.0/24 [110/10] is directly connected, eth1, 02w1d20h
C>* 5.144.48.0/24 is directly connected, eth1
O 5.149.96.0/24 [110/10] is directly connected, eth2, 02w1d20h
C>* 5.149.96.0/24 is directly connected, eth2
O 5.200.96.0/24 [110/10] is directly connected, eth2, 02w1d20h
C>* 5.200.96.0/24 is directly connected, eth2
B>* 10.5.10.0/24 [200/110] via 24.31.140.242 (recursive via 10.170.191.254), 4d04h53m
B>* 10.5.10.100/32 [200/210] via 24.31.140.242 (recursive via 10.170.191.254), 01w4d23h
B>* 10.5.20.0/24 [200/210] via 24.31.140.242 (recursive via 10.170.191.254), 01w4d23h
S>* 10.154.0.0/16 [1/0] via 10.170.191.254, eth0
S>* 10.170.0.0/16 [1/0] via 10.170.191.254, eth0
C>* 10.170.128.0/18 is directly connected, eth0
S>* 10.200.0.0/16 [1/0] via 10.170.191.254, eth0
S>* 10.208.0.0/16 [1/0] via 10.170.191.254, eth0
S>* 10.232.0.0/16 [1/0] via 10.170.191.254, eth0
S>* 10.248.0.0/16 [1/0] via 10.170.191.254, eth0
B>* 24.30.1.0/24 [200/1] via 192.168.199.5, tun0, 02w1d20h
B>* 24.31.140.0/24 [200/1] via 192.168.199.5, tun0, 02w1d20h
S>* 172.18.0.0/16 [1/0] via 10.170.191.254, eth0
S>* 172.24.0.0/16 [1/0] via 10.170.191.254, eth0
S>* 192.168.163.0/24 [1/0] via 10.170.191.254, eth0
C>* 192.168.199.0/24 is directly connected, tun0
vyos@wrw-rtr-vyos1:~$ show interfaces
eth0 10.170.167.100/18 u/u MGMT
eth1 5.8.128.254/24 u/u Lebanon/Israel - AS(ME) range
5.144.48.254/24
eth2 5.149.96.254/24 u/u Iraq/Iran - AS(ME) range
5.200.96.254/24
lo 127.0.0.1/8 u/u
4.0.0.0/32
::1/128
tun0 192.168.199.4/24 u/u
--- The traffic towards 10.5.x.x should flow via tun0, not via eth0
vyos@wrw-rtr-vyos1:~$ traceroute 10.5.10.100
traceroute to 10.5.10.100 (10.5.10.100), 30 hops max, 60 byte packets
1 10.170.191.254 (10.170.191.254) 0.271 ms 0.356 ms 0.338 ms
2 <scrubbed> 1.275 ms 1.499 ms 1.258 ms
3 10.225.3.45 (10.225.3.45) 1.599 ms 1.701 ms 1.801 ms
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 *^C
Here is the HUB BGP/OSPF config:
vyos@wrw-rtr-vyos1# show protocols bgp
bgp 65000 {
neighbor 192.168.199.1 {
peer-group DMVPNPEERS
neighbor 192.168.199.2 {
neighbor 192.168.199.3 {
neighbor 192.168.199.5 {
network 5.8.128.0/24 {
network 5.144.48.0/24 {
network 5.149.96.0/24 {
network 5.200.96.0/24 {
parameters {
router-id 4.0.0.0
peer-group DMVPNPEERS {
passive
remote-as 65000
route-reflector-client
soft-reconfiguration {
inbound
update-source 192.168.199.4
redistribute {
ospf {
vyos@wrw-rtr-vyos1# show protocols ospf
area 0.0.0.0 {
network 5.0.0.0/8
parameters {
abr-type cisco
router-id 4.0.0.0
passive-interface eth0
Here is SPOKE1 config:
vyos@spk-rtr-vyos1# show protocols bgp
bgp 65000 {
neighbor 192.168.199.4 {
remote-as 65000
update-source 192.168.199.5
network 24.30.1.0/24 {
network 24.31.140.0/24 {
parameters {
router-id 192.168.199.5
redistribute {
ospf {
vyos@spk-rtr-vyos1# show protocols ospf
area 0.0.0.0 {
network 24.30.0.0/15
parameters {
abr-type cisco
router-id 5.0.0.0
Can someone help me to understand if this is a bug in Vyos or a bad configuration somewhere?
