Openconnect VPN with radius authentication doesn't work?
Hi there
Recently try to replace existing L2TP/IPSEC VPN by openconnect vpn.
Radius forking fine in L2TP but not with openconnect.
Openconnect with local authentication mode working but switch to raidus with working parameters from L2TP not.
Radius request even not reached server.
openconnect VPN GUI client log as below
2024-07-30 12:47:00 |  9d8 | Server 'server' requested Basic authentication which is disabled by default
2024-07-30 12:47:00 |  9d8 | Authentication error; cannot obtain cookie
VyOS 1.5-rolling-202407060019
opencoonect client from there OpenConnect VPN graphical client (openconnect-vpn.net)
VYOS configuration is
set vpn openconnect authentication local-users username xxxxxx password xxxxxx
set vpn openconnect authentication mode radius
set vpn openconnect authentication radius server xxxxx.tld key xxxxxx
set vpn openconnect authentication radius source-address 'xxx.xxx.0.12'
set vpn openconnect http-security-headers
set vpn openconnect network-settings client-ip-settings subnet 'xxx.xxx.0.0/24'
set vpn openconnect network-settings name-server 'xxx.xxx.184.3'
set vpn openconnect network-settings name-server 'xxx.xxx.74.3'
set vpn openconnect ssl ca-certificate 'ca-silversrv'
set vpn openconnect ssl certificate 'srv-silversrv'
any idea or direction?
Thanks
There will be more questions about openconnect vpn - certbot certificate import, local network access and so on.
What does the log of your RADIUS server tell you?
nothing, because authentication call to server didn’t even generated.
Tested with tcpdump, no requests.
Hi there
In order to arrange access to the RADIUS server in local network i need to push no-route rule.
There is no corresponding command in configuration, isn’t?
Any idea?
Finally i’ve do it.
Just added no-route option manually to ocserv.conf to reroute internal traffic to RADIUS server.
So, there are two questions to community/mantainers
  1. Does you have any plan to extend the openconnect command set with no-route option?
  2. what is the more or less workable solution to push required option during reconfiguration? SED in postconfigure script is ok?
thanks
if possible to add this request, Can you share with us the full configuration add on ocsev.conf? or
add a feature request with this information to extend the function:
https://vyos.dev/
there were nothing special in ocsev.conf
My RADIUS Server resides in 10.1.0.0/24 network.
openconnect client configured to 10.1.0.0/24 network.
What i simply need - split tunneling for 10.1.0.0
This possible by adding option into ocsev.conf
no-route=10.1.0.0/24
i’ve added few lines to posconfiguration script in VYOS
/config/scripts/vyos-postconfig-bootup.script
# Insert workaround for openconnect VPN ocserv configuration
# to allow RADIUS server authentication
echo '#' | sudo tee -a /run/ocserv/ocserv.conf
echo 'no-route=10.1.0.0/24' | sudo tee -a /run/ocserv/ocserv.conf
sudo systemctl restart ocserv
thus authentication requests went freely to server.
