OpenSSL accleration by QAT?
May I know how to confirm that the OpenSSL process/connection would accelerated by QAT?
vyos@VyOS-v2ray# sudo openssl engine -t -c
(dynamic) Dynamic engine loading support
     [ unavailable ]
vyos@VyOS-v2ray# sudo openssl engine qat -t
40173911D37F0000:error:12800067:DSO support routines:dlfcn_load:could not load the shared library:../crypto/dso/dso_dlfcn.c:118:filename(/usr/lib/x86_64-linux-gnu/engines-3/qat.so): /usr/lib/x86_64-linux-gnu/engines-3/qat.so: cannot open shared object file: No such file or directory
40173911D37F0000:error:12800067:DSO support routines:DSO_load:could not load the shared library:../crypto/dso/dso_lib.c:152:
40173911D37F0000:error:13000084:engine routines:dynamic_load:dso not found:../crypto/engine/eng_dyn.c:442:
40173911D37F0000:error:13000074:engine routines:ENGINE_by_id:no such engine:../crypto/engine/eng_list.c:433:id=qat
show version
Version: VyOS 1.4.0-release-20240923
Release train: sagitta
Release flavor: iso
Built by: [email protected]
Built on: Sun 22 Sep 2024 16:42 UTC
Architecture: x86_64
Boot via: installed image
System type: bare metal
CPU is Atom C3558
vyos@VyOS-v2ray# run show system acceleration qat
01:00.0 Co-processor [0b40]: Intel Corporation Atom Processor C3000 Series QuickAssist Technology [8086:19e2] (rev 11)
vyos@VyOS-v2ray# run show system acceleration qat status
Checking status of all devices.
There is 1 QAT acceleration device(s) in the system:
 qat_dev0 - type: c3xxx,  inst_id: 0,  node_id: 0,  bsf: 0000:01:00.0,  #accel: 3 #engines: 6 state: up
openssl ras2048 speed shows 'Invalid engine "qat_dev0"'
vyos@VyOS-v2ray# sudo openssl speed -elapsed rsa2048
You have chosen to measure elapsed time instead of user CPU time.
Doing 2048 bits private rsa's for 10s:
3701 2048 bits private RSA's in 10.00s
Doing 2048 bits public rsa's for 10s:
128426 2048 bits public RSA's in 10.00s
version: 3.0.14
built on: Sun Sep  1 14:59:10 2024 UTC
options: bn(64,64)
compiler: gcc -fPIC -pthread -m64 -Wa,--noexecstack -Wall -fzero-call-used-regs=used-gpr -DOPENSSL_TLS_SECURITY_LEVEL=2 -Wa,--noexecstack -g -O2 -ffile-prefix-map=/build/reproducible-path/openssl-3.0.14=. -fstack-protector-strong -Wformat -Werror=format-security -DOPENSSL_USE_NODELETE -DL_ENDIAN -DOPENSSL_PIC -DOPENSSL_BUILDING_OPENSSL -DNDEBUG -Wdate-time -D_FORTIFY_SOURCE=2
CPUINFO: OPENSSL_ia32cap=0x4ff8e3bfefebffff:0x2294e283
                  sign    verify    sign/s verify/s
rsa 2048 bits 0.002702s 0.000078s    370.1  12842.6
vyos@VyOS-v2ray# sudo openssl speed -engine qat_dev0 -elapsed rsa2048
4017C695727F0000:error:12800067:DSO support routines:dlfcn_load:could not load the shared library:../crypto/dso/dso_dlfcn.c:118:filename(/usr/lib/x86_64-linux-gnu/engines-3/qat_dev0.so): /usr/lib/x86_64-linux-gnu/engines-3/qat_dev0.so: cannot open shared object file: No such file or directory
4017C695727F0000:error:12800067:DSO support routines:DSO_load:could not load the shared library:../crypto/dso/dso_lib.c:152:
4017C695727F0000:error:13000084:engine routines:dynamic_load:dso not found:../crypto/engine/eng_dyn.c:442:
4017C695727F0000:error:13000074:engine routines:ENGINE_by_id:no such engine:../crypto/engine/eng_list.c:433:id=qat_dev0
4017C695727F0000:error:12800067:DSO support routines:dlfcn_load:could not load the shared library:../crypto/dso/dso_dlfcn.c:118:filename(libqat_dev0.so): libqat_dev0.so: cannot open shared object file: No such file or directory
Doing 2048 bits private rsa's for 10s: 3700 2048 bits private RSA's in 10.00s
Doing 2048 bits public rsa's for 10s: 128152 2048 bits public RSA's in 10.00s
version: 3.0.14
options: bn(64,64)
rsa 2048 bits 0.002703s 0.000078s    370.0  12815.2
I noticed that vyos-build/scripts/package-build/linux-kernel/build-intel-qat.sh at current ยท vyos/vyos-build (github.com)
This is Intel QAT HW 1.0 Linux driver.
url="https://packages.vyos.net/source-mirror/QAT.L.4.24.0-00005.tar.gz"
So, the QAT module (qat.ko) is compiled for the kernel.
Then, back to my case. If I want OpenSSL can support QAT then it will be required to compile an Intel QAT Engine (qat.so) for OpenSSL?
