Hi all…
I’m trying to get VyOS to run in an Openstack instance (GRE With VLANS)…
I have the interfaces up & running, all is good there.
VYOS router has one directly attached interface to an external network, and one interface attached to the internal interace.
Internet works on the external interface without issues.
- I can ping outside machines (8.8.8.8)
Network works on internal interface without issues.
- I can ping internal address no problem (10.168.11.102)
But if I try and route through the VyOS, something doesn’t make it through.
I can see the packets through tcpdump on both interfaces, but the destination machine never sees the inbound packets! (10.168.11.102)
vyos@vyos:~$ /usr/sbin/tcpdump -f “icmp” -i eth0
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
18:10:13.234909 IP 10.168.11.102 > 8.8.8.8: ICMP echo request, id 40962, seq 49, length 64
18:10:13.261277 IP 8.8.8.8 > 10.168.11.102: ICMP echo reply, id 40962, seq 49, length 64
18:10:14.235045 IP 10.168.11.102 > 8.8.8.8: ICMP echo request, id 40962, seq 50, length 64
18:10:14.261379 IP 8.8.8.8 > 10.168.11.102: ICMP echo reply, id 40962, seq 50, length 64
18:10:15.235249 IP 10.168.11.102 > 8.8.8.8: ICMP echo request, id 40962, seq 51, length 64
18:10:15.261549 IP 8.8.8.8 > 10.168.11.102: ICMP echo reply, id 40962, seq 51, length 64
^C
6 packets captured
6 packets received by filter
0 packets dropped by kernel
vyos@vyos:~$ /usr/sbin/tcpdump -f “icmp” -i eth1
listening on eth1, link-type EN10MB (Ethernet), capture size 65535 bytes
18:10:18.235887 IP XXX.XXX.187.78 > 8.8.8.8: ICMP echo request, id 40962, seq 54, length 64
18:10:18.262249 IP 8.8.8.8 > XXX.XXX.187.78: ICMP echo reply, id 40962, seq 54, length 64
18:10:19.236110 IP XXX.XXX.187.78 > 8.8.8.8: ICMP echo request, id 40962, seq 55, length 64
18:10:19.262477 IP 8.8.8.8 > XXX.XXX.187.78: ICMP echo reply, id 40962, seq 55, length 64
18:10:20.236345 IP XXX.XXX.187.78 > 8.8.8.8: ICMP echo request, id 40962, seq 56, length 64
18:10:20.262652 IP 8.8.8.8 > XXX.XXX.187.78: ICMP echo reply, id 40962, seq 56, length 64
18:10:21.236527 IP XXX.XXX.187.78 > 8.8.8.8: ICMP echo request, id 40962, seq 57, length 64
18:10:21.262927 IP 8.8.8.8 > XXX.XXX.187.78: ICMP echo reply, id 40962, seq 57, length 64
18:10:22.237082 IP XXX.XXX.187.78 > 8.8.8.8: ICMP echo request, id 40962, seq 58, length 64
18:10:22.263398 IP 8.8.8.8 > XXX.XXX.187.78: ICMP echo reply, id 40962, seq 58, length 64
^C
10 packets captured
10 packets received by filter
vyos@vyos:~$ ping 10.168.11.102
PING 10.168.11.102 (10.168.11.102) 56(84) bytes of data.
64 bytes from 10.168.11.102: icmp_req=1 ttl=64 time=0.481 ms
64 bytes from 10.168.11.102: icmp_req=2 ttl=64 time=0.559 ms
Any Ideas? 10.168.11.102 never sees the responses…
