Hello all! I have to ask how I may configure my VyOS device to be able to run as an OpenVPN server and be able to use it as a way to connect to the private server being hosted on it.
Here are the server configurations:
openvpn vtun1 {
local-port 1194
mode server
persistent-tunnel
protocol udp
server {
client client1 {
ip 10.16.1.10
push-route 172.16.0.0/24
subnet 10.16.1.0/25
name-server 10.16.0.254
push-route 172.16.0.0/24 {
subnet 10.16.0.0/24
topology subnet
tls {
ca-certificate ca
certificate server
dh-params dh
The clients trying to access are individuals and their machines, rather than another VyOS machine. So there are files like client1.crt, client1.key & ca.crt for each client on said machines.
So far, I’ve been able to technically connect to the VyOS machine via OpenVPN on a client machine, however, I have not been able to access the private network 172.16.0.0/24 that’s being hosted within its server. The only thing even pingable is the client’s own ip (10.16.1.10)
Anyone know any good tips or configuration changes I must follow to correct this?
Thank you for reading!
Extra info:
Client configuration file:
client
nobind
remote xxx.xxx.xxx.xxx xxxxx # censored
remote-cert-tls server
proto udp
dev tun1
persist-key
persist-tun
verb 3
mute 3
tls-client
ca "E:\\Users\\Client1\\OpenVPN\\config\\c1\\ca.crt"
cert "E:\\Users\\Client1\\OpenVPN\\config\\c1\\client1.crt"
key "E:\\Users\\Client1\\OpenVPN\\config\\c1\\client1.key"
keysize 256
comp-lzo no
The same router that hosts the OpenVPN server also hosts a DHCP server, which is providing the private network and IPs to the devices on 172.16.0.0/24. So I believe that the devices might not have any routing to the VPN server, as I’ve only started OpenVPN configuration after the main server configuration was done.
Here is what the server’s routing looks like:
Destination Gateway Genmask Flags Metric Ref Use Iface
default xxx.xxx.xxx.xxx 0.0.0.0 UG 20 0 0 eth0 # Censored
10.16.0.0 0.0.0.0 255.255.255.0 U 0 0 0 vtun1
10.16.0.0 0.0.0.0 255.255.240.0 U 20 0 0 vtun1
172.16.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
xxx.xxx.xxx.xxx 0.0.0.0 xxx.xxx.xxx.xxx U 0 0 0 eth0 # Censored
Here is a host’s routing:
default 172.16.0.1 0.0.0.0 UG 20 0 0 eth1
Hi! did you make this work? I think the “client client1” section is totally off.
You’re just configuring a LAN behind the OpenVPN server, not a LAN behind client1.
Remove that entire section (why are you picking a specific IP for that client?) and try again
