Getting the following error with vtun0 running in interface mode tun. Same configuration works when switched to tap. Can’t seem to run down the issue, running version 1.3.2.
Cannot ioctl TUNSETIFF vtun0: Invalid argument (errno=22)
Please provide the CLI configuration used and also the system logs show log openvpn vtun0
I’m also experiencing this exact error, and this is the only mention I’ve seen of it in the context of VyOS. This is my configuration (for vtun0), I’ve tried removing local-address and remote-address and using a bridge but I get an error that the vtun0 interface can’t be enslaved to the bridge.
description Site-Home
device-type tap
encryption {
cipher aes256
hash sha256
local-address 10.11.3.205 {
subnet-mask 255.255.255.248
local-port 1194
mode site-to-site
openvpn-option "--proto udp4"
persistent-tunnel
remote-address 10.11.3.206
remote-host home.example.com
remote-port 1194
shared-secret-key s2s
Running 1.4 built from the currrent branch yesterday.
I was able to get my config working (with the local-address and remote-address removed) by removing the entire vtun0 config, committing, and then re-adding it as part of a bridge.
