Hello everyone,
I’ve just build 1.4.0-epa1 and it works fine in many cases!
After configuring the openvpn-client (without setting “local-host”), it should be accept connections on all addresses.
manuel@fe73651# show interfaces openvpn vtun0
encryption {
cipher aes256
local-port 1195
mode server
offload {
dco
persistent-tunnel
protocol udp
server {
name-server 10.13.0.3
push-route 192.168.0.0/16 {
subnet 10.49.6.0/24
tls {
ca-certificate xxxxxxxxxx-ca
certificate ovpn1195
dh-params dh1
But it’s actually listening only on all ipv4-addresses, not ipv6:
manuel@fe73651# sudo netstat -lnup | grep openvpn
udp 0 0 0.0.0.0:1195 0.0.0.0:* 105300/openvpn
In general, openvpn works fine with both, ipv6 and ipv4. When I use the “local-host” statement with the routers ipv6-address, openvpn is bond correctly to it. But, openvpn cannot be bond to both addresses. So a dualstack-deployment will not be possible, because I have to decide whether to assign v4 or v6?
