My configuration for openvpn is not working as expected and I am suspecting that I might have not configured something right.
I want to PC-A to be able to ping PC-B
VYOS-A configuration:
vyos@vyos-A# show inter
address 10.1.1.10/24
hw-id 00:0c:29:e4:5b:e0
address 192.168.1.251/24
hw-id 00:0c:29:e4:5b:ea
ethernet eth2 {
hw-id 00:0c:29:e4:5b:f4
loopback lo {
openvpn vtun10 {
local-address 192.168.10.1 {
local-host 10.1.1.10
local-port 8000
mode site-to-site
persistent-tunnel
protocol udp
remote-address 192.168.10.2
remote-host 10.1.1.20
shared-secret-key-file /config/auth/mysite.key
vyos@vyos-B# show inter
address 10.1.1.20/24
hw-id 00:0c:29:31:d3:32
address 192.168.1.252/24
hw-id 00:0c:29:31:d3:3c
ethernet eth2 {
hw-id 00:0c:29:31:d3:46
loopback lo {
openvpn vtun10 {
local-address 192.168.10.2 {
local-port 8000
mode site-to-site
persistent-tunnel
protocol udp
remote-address 192.168.10.1
remote-host 10.1.1.10
Not using NAT, Not using Firewall.
Any Suggestions?
rob
December 15, 2019, 8:31pm
2
the both eth1 networks on Side A and B are two different Layer2 domains so you need NAT.
Or, but i don’t tested or used it, you bridge eth1 to the vtun10 interface.
https://docs.vyos.io/en/latest/configuration/interfaces/bridge.html
I am actually was trying to avoid double NAT as it is a headache in troubleshooting network issues.
That is a good idea, I will try it.
I forgot to mention, openVPN link is not up, I can’t ping 192.168.10.2 from VyOS-A
vyos@vyos-A:~$ show openvpn site-to-site status
OpenVPN client status on vtun10 []
Remote CN Remote IP Tunnel IP TX byte RX byte Connected Since
None (PSK) 10.1.1.20 192.168.10.2 420 0 N/A
vyos@vyos-B:~$ show openvpn site-to-site status
None (PSK) 10.1.1.10 192.168.10.1 540 0 N/A
In previous vyos/vyatta releases (1.1x), I was able to carry a L2 VLAN across an OpenVPN tunnel…and it seems to be what you’re looking for also.
I tried with the recent 1.2 rolling and it seems that there was some changes made regarding how OpenVPN site-to-site works and it seems to require an L3 IP on both ends of the tunnels.
Here’s my server config. I NAT the L2 VLAN out the server’s eth1 interface. In your case, since you want the remote end to be on the same VLAN as your LAN, you can add eth1 to br0 and re-assign br0 with the LAN IP.
bridge br0 {
address 88.88.88.1/24
description vpn_88_net
address 192.168.1.88/24
description to_LAN }
openvpn vtun1 {
bridge-group {
bridge br0
description tcp_8881
local-port 8881
mode site-to-site
openvpn-option --comp-lzo
protocol tcp-passive
tls {
ca-cert-file /config/auth/ca.crt
cert-file /config/auth/vpnserver.crt
dh-file /config/auth/dh.pem
key-file /config/auth/vpnserver.key
role passive
nat {
rule 10 {
outbound-interface eth1
address 88.88.88.0/24
translation {
address masquerade
service {
dhcp-server {
disabled false
shared-network-name 88NET {
authoritative disable
subnet 88.88.88.0/24 {
default-router 88.88.88.1
dns-server 88.88.88.1
domain-name 88net.local
lease 86400
start 88.88.88.100 {
stop 88.88.88.254
Remote side config:
bridge br0 {
address dhcp
description WAN
bridge-group {
bridge br0
description vpn_88_net_bridgeport
ethernet eth2 {
bridge-group {
bridge br0
ethernet eth3 {
bridge-group {
bridge br0
ethernet eth4 {
bridge-group {
bridge br0
ethernet eth5 {
bridge-group {
bridge br0
openvpn vtun0 {
bridge-group {
bridge br0
description vpn_88_tunnel
mode site-to-site
openvpn-option "--comp-lzo"
protocol tcp-active
remote-host my-openvpn-server.dyndns.org
remote-port 8881
tls {
cert-file /config/auth/s2sremote1.crt
key-file /config/auth/s2sremote1.key
role active
