Hi all,
small network
diagram
[attachment=159]
goal: all network traffic from/for 172.16.15.0/24 needs to go through the gw-ext and gw-int should work with dualwan in failover mode.
note: I have no physical access to the console of router gw-int, the only external access through the Internet
trouble: the configuration with the openvpn site-to-site tunnel + one wan or two wans without openvpn tunnel works fine but I need two wans worked in failover mode + openvpn site-to-site tunnel together
gw-ext configuration
firewall
name IN {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
destination {
address 172.16.15.0/29
name IN-local {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
icmp {
type-name echo-request
limit {
burst 5
rate 2/second
protocol icmp
rule 30 {
action drop
destination {
port 22
protocol tcp
recent {
count 3
time 30
state {
new enable
rule 31 {
action accept
destination {
port 22
protocol tcp
state {
new enable
rule 40 {
action accept
destination {
port 11950
protocol udp
state {
new enable
interfaces
address 217.xxx.xxx.xxx/25
description inet
duplex auto
firewall {
in {
name IN
local {
name IN-local
smp_affinity auto
speed auto
loopback lo {
openvpn vtun0 {
encryption aes256
hash sha512
local-address 10.0.100.1 {
subnet-mask 255.255.255.252
local-host 217.xxx.xxx.xxx
local-port 11950
mode site-to-site
persistent-tunnel
protocol udp
remote-address 10.0.100.2
shared-secret-key-file /config/auth/tun0.key
nat destination
nat {
destination {
rule 10 {
description "ssh to gw-ext"
destination {
port xxxxx
inbound-interface eth0
protocol tcp
translation {
address 10.0.100.1
port ssh
rule 11 {
description "ssh to gw-int-tunnel"
destination {
port xxxxx
protocol tcp
translation {
address 172.16.15.1
port ssh
rule 20 {
destination {
port https
protocol tcp
translation {
address 172.16.15.2
port https
rule 30 {
destination {
port 5222,5269
protocol tcp
translation {
address 172.16.15.3
nat source
rule 10 {
outbound-interface eth0
translation {
address masquerade
rule 20 {
address 10.0.100.0/30
translation {
address masquerade
gw-int configuration
firewall
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name IN {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
name IN-local {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
icmp {
limit {
burst 5
rate 2/second
protocol icmp
rule 30 {
action drop
destination {
port 22
protocol tcp
recent {
count 3
time 30
state {
new enable
rule 31 {
action accept
destination {
port 22
protocol tcp
state {
new enable
send-redirects enable
source-validation disable
syn-cookies enable
twa-hazards-protection enable
interfaces
address 82.xxx.xxx.xxx/27
duplex auto
firewall {
in {
name IN
local {
name IN-local
smp_affinity auto
speed auto
address 195.xxx.xxx.xxx/27
duplex auto
firewall {
in {
name IN
local {
name IN-local
smp_affinity auto
speed auto
ethernet eth2 {
address 172.16.15.1/29
duplex auto
smp_affinity auto
speed auto
loopback lo {
openvpn vtun0 {
encryption aes256
hash sha512
local-address 10.0.100.2 {
mode site-to-site
protocol udp
remote-address 10.0.100.1
remote-host 217.xxx.xxx.xxx
remote-port 11950
replace-default-route {
dualwan
load-balancing {
wan {
enable-local-traffic
flush-connections
interface-health eth0 {
failure-count 4
nexthop 82.xxx.xxx.xx0
success-count 2
test 10 {
resp-time 5
target 194.25.0.125
ttl-limit 1
type ping
test 20 {
resp-time 5
target 64.102.255.44
ttl-limit 1
type ping
interface-health eth1 {
failure-count 4
nexthop 195.xxx.xxx.xx3
success-count 2
test 10 {
resp-time 5
target 195.244.245.25
ttl-limit 1
type ping
test 20 {
resp-time 5
target 173.37.146.41
ttl-limit 1
type ping
rule 10 {
inbound-interface eth2
interface eth0 {
weight 1
protocol all
rule 20 {
interface eth1 {
weight 1
protocol all
sticky-connections {
inbound
static route
protocols {
static {
route 0.0.0.0/0 {
next-hop 82.xxx.xxx.xx0 {
distance 210
next-hop 195.xxx.xxx.xx3 {
distance 210
route 10.0.0.0/8 {
blackhole {
distance 254
route 64.102.255.44/32 {
route 172.16.0.0/12 {
blackhole {
distance 254
route 173.37.146.41/32 {
route 192.168.0.0/16 {
blackhole {
distance 254
route 194.25.0.125/32 {
route 195.244.245.25/32 {
in this configuration I have access to a router gw-int at the address 82.ххх.ххх.ххх, the openvpn tunnel is working fine but traffic to/from the network 172.16.15.0 not goes through the tunnel
as soon as I add in the config “load‐balancing wan disable‐source‐nat” I lose access to the router and the openvpn tunnel not working.
anyone can tell me what I missed?
