Iβm working on OSPF and BGP.
As below schema :
PC1 can ping all routers. My goal was make a redudancy WAN with Vy4 - Vy3 - Vy2
On Vy2 route table i get a static route (default route) with Vy1 :
vyos@vyos:~$ show ip route
F - PBR, f - OpenFabric,
- selected route, * - FIB route, q - queued route, r - rejected route
S>* 0.0.0.0/0 [1/0] via 88.88.88.3, eth3, 00:11:09
O 0.0.0.0/0 [110/50] via 77.77.77.1, eth0, 00:13:40
O>* 10.0.0.0/24 [110/21] via 77.77.77.1, eth0, 00:08:48
S 10.2.2.2/32 [1/0] unreachable (blackhole), 00:36:48
C>* 10.2.2.2/32 is directly connected, lo, 00:37:04
C>* 11.0.0.0/31 is directly connected, vti10, 00:36:37
C>* 66.66.66.0/24 is directly connected, eth2, 00:36:55
O 77.77.77.0/24 [110/1] is directly connected, eth0, 00:36:38
C>* 77.77.77.0/24 is directly connected, eth0, 00:36:57
C>* 88.88.88.0/24 is directly connected, eth3, 00:11:09
B>* 99.99.99.0/24 [20/2] via 66.66.66.4, eth2, 00:36:41
When i cut Link between Vy2 β Vy3, trafic is not routed on Network 66.66.66.0/24
PC1 Ping command :
Config Vy-1 :
set interfaces ethernet eth0 address β10.0.0.1/24β
set interfaces ethernet eth0 hw-id β0c:1c:0a:ac:ce:00β
set interfaces ethernet eth1 hw-id β0c:1c:0a:ac:ce:01β
set interfaces ethernet eth2 hw-id β0c:1c:0a:ac:ce:02β
set interfaces ethernet eth3 address β77.77.77.1/24β
set interfaces ethernet eth3 hw-id β0c:1c:0a:ac:ce:03β
set interfaces loopback lo address β10.1.1.1/32β
set policy route-map CONNECT rule 11 action βpermitβ
set policy route-map CONNECT rule 11 match interface βeth0β
set protocols ospf area 777 network β77.77.77.0/24β
set protocols ospf default-information originate always
set protocols ospf default-information originate metric β50β
set protocols ospf default-information originate metric-type β2β
set protocols ospf log-adjacency-changes
set protocols ospf parameters abr-type βciscoβ
set protocols ospf parameters router-id β77.77.77.1β
set protocols ospf redistribute connected metric-type β2β
set protocols ospf redistribute connected route-map βCONNECTβ
set protocols static route 10.1.1.1/32 blackhole
set service dhcp-server shared-network-name LAN authoritative
set service dhcp-server shared-network-name LAN subnet 10.0.0.0/24 default-router β10.0.0.1β
0.0.0.1β
set service dhcp-server shared-network-name LAN subnet 10.0.0.0/24 lease β86400β
set service dhcp-server shared-network-name LAN subnet 10.0.0.0/24 range 0 start β10.0.0.10β
set service dhcp-server shared-network-name LAN subnet 10.0.0.0/24 range 0 stop β10.0.0.20β
set system config-management commit-revisions β100β
set system console device ttyS0 speed β115200β
set system host-name βvyosβ
set system login banner pre-login βvr-VY-1β
set system login user vyos authentication encrypted-password β$6$17Sn.oD0SFDBvne$ZZgaV/UfSwvkKxVZeCf21MJ06vxPOVvLwC.84ISBn.cArBHw0aXJBGT9l.2yYZMFaYiRsOoAnUnNebhxV1B6a.β
set system login user vyos authentication plaintext-password ββ
set system syslog global facility all level βinfoβ
set system syslog global facility protocols level βdebugβ
Confg Vy-2 :
set interfaces ethernet eth0 address β77.77.77.2/24β
set interfaces ethernet eth0 hw-id β0c:1c:0a:b4:4a:00β
set interfaces ethernet eth1 hw-id β0c:1c:0a:b4:4a:01β
set interfaces ethernet eth2 address β66.66.66.2/24β
set interfaces ethernet eth2 hw-id β0c:1c:0a:b4:4a:02β
set interfaces ethernet eth3 address β88.88.88.2/24β
set interfaces ethernet eth3 hw-id β0c:1c:0a:b4:4a:03β
set interfaces loopback lo address β10.2.2.2/32β
set interfaces vti vti10 address β11.0.0.1/31β
set policy prefix-list AS65534-IN rule 10 action βpermitβ
set policy prefix-list AS65534-IN rule 10 prefix β99.99.99.0/24β
set policy prefix-list AS65534-IN rule 11 action βpermitβ
set policy prefix-list AS65534-IN rule 11 prefix β88.88.88.0/24β
set policy prefix-list AS65534-IN rule 12 action βpermitβ
set policy prefix-list AS65534-IN rule 12 prefix β10.0.0.0/24β
set policy prefix-list AS65534-IN rule 13 action βpermitβ
set policy prefix-list AS65534-IN rule 13 prefix β77.77.77.0/24β
set policy prefix-list AS65534-IN rule 14 action βpermitβ
set policy prefix-list AS65534-IN rule 14 prefix β66.66.66.0/24β
set policy prefix-list AS65534-OUT rule 10 action βpermitβ
set policy prefix-list AS65534-OUT rule 10 prefix β99.99.99.0/24β
set policy prefix-list AS65534-OUT rule 11 action βpermitβ
set policy prefix-list AS65534-OUT rule 11 prefix β88.88.88.0/24β
set policy prefix-list AS65534-OUT rule 12 action βpermitβ
set policy prefix-list AS65534-OUT rule 12 prefix β10.0.0.0/24β
set policy prefix-list AS65534-OUT rule 13 action βpermitβ
set policy prefix-list AS65534-OUT rule 13 prefix β77.77.77.0/24β
set policy prefix-list AS65534-OUT rule 14 action βpermitβ
set policy prefix-list AS65534-OUT rule 14 prefix β66.66.66.0/24β
set policy route-map AS65534-IN rule 10 action βpermitβ
set policy route-map AS65534-IN rule 10 match ip address prefix-list βAS65534-INβ
set policy route-map AS65534-OUT rule 10 action βpermitβ
set policy route-map AS65534-OUT rule 10 match ip address prefix-list βAS65534-OUTβ
set protocols bgp 65534 address-family ipv4-unicast network 10.2.2.2/32
set protocols bgp 65534 address-family ipv4-unicast redistribute connected metric β2β
set protocols bgp 65534 address-family ipv4-unicast redistribute ospf metric β2β
set protocols bgp 65534 neighbor 66.66.66.4 address-family ipv4-unicast route-map export βAS65534-OUTβ
set protocols bgp 65534 neighbor 66.66.66.4 address-family ipv4-unicast route-map import βAS65534-INβ
set protocols bgp 65534 neighbor 66.66.66.4 ebgp-multihop β2β
set protocols bgp 65534 neighbor 66.66.66.4 remote-as β65566β
set protocols bgp 65534 neighbor 66.66.66.4 update-source β66.66.66.2β
set protocols bgp 65534 neighbor 88.88.88.3 address-family ipv4-unicast route-map export βAS65534-OUTβ
set protocols bgp 65534 neighbor 88.88.88.3 address-family ipv4-unicast route-map import βAS65534-INβ
set protocols bgp 65534 neighbor 88.88.88.3 ebgp-multihop β2β
set protocols bgp 65534 neighbor 88.88.88.3 remote-as β65535β
set protocols bgp 65534 neighbor 88.88.88.3 update-source β88.88.88.2β
set protocols bgp 65534 parameters router-id β10.2.2.2β
set protocols ospf parameters router-id β77.77.77.2β
set protocols ospf redistribute bgp metric-type β2β
set protocols ospf redistribute bgp route-map βAS65534-INβ
set protocols static route 0.0.0.0/0 next-hop 88.88.88.3
set protocols static route 10.2.2.2/32 blackhole
