When you have 2 core routers Advertising themself af default gateway to VyOS only on router is shown as default gateway but both show up for the other subnets in the area’s.
When the existing default route hop dies the routing table is not updated and the old IP still exists there.
Is this a bug or how it works ? I thought it was possible to use a metric order when you have a FailOver IP at your want side of your core routers so the in/out traffic would always go over the right next hop.
