So modified a config a little bit …
vyos@vyos-test# show protocols
ospf {
area 192.168.190.0 {
network 172.30.6.0/30
network 192.168.190.0/24
parameters {
router-id 84.255.xxx.xxx
static {
route 0.0.0.0/0 {
next-hop 84.255.xxx.xxx {
on the 1.4 vyos I see this:
vyos@vyos-test# run sh ip r
rip route
vyos@vyos-test# run sh ip route ospf
F - PBR, f - OpenFabric,
O>* 10.20.0.0/16 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 10.40.1.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 10.40.1.1/32 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 172.30.1.1/32 [110/70] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.1.2/32 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.3.1/32 [110/60] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.3.2/32 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.4.0/30 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.5.1/32 [110/70] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.5.2/32 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.11.1/32 [110/30] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.11.2/32 [110/40] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.13.1/32 [110/50] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.13.2/32 [110/40] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.14.0/30 [110/30] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.15.1/32 [110/30] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.15.2/32 [110/40] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 172.30.50.0/30 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 172.30.202.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 172.30.203.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 172.31.201.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.8.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:14
O>* 192.168.12.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.28.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.32.0/22 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O 192.168.190.0/24 [110/1] is directly connected, eth0.190, weight 1, 00:01:13
O>* 192.168.195.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.200.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.201.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.202.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.203.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.204.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.205.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
O>* 192.168.210.0/24 [110/20] via 172.30.6.1, vtun10 onlink, weight 1, 00:07:13
But 192.168.190.0/24 is still not propagated in to OSPF network. I even tried the 1.1.8 as a neighbor … not working.
