Hi
Is it possible to prevent specific routes between Areas on OSPF on VyOS like showed in this example?: vyos example will be helpful.
https://packetlife.net/blog/2010/feb/10/ospf-filtering-inter-area-vs-intra-area/
Hi
Maybe the “not-advertise” option will work for you:
set protocols ospf area <number> range <A.B.C.D/M> not-advertise
This command instead of summarizing intra area paths filter them - i.e. intra area paths from this range are not advertised into other areas. This command makes sense in ABR only
This worked
Thank you!
Do you know if there is a way to block all subnets and only open for the ones I want to allow between the areas?
If that is possible it will be easier when I want to expand my network.
