OSPFv3 for IPv4
Hello! The documentation explicitly says that for IPv6, OSPFv3 must be used, and since the OSPFv3 specifications contains the capability of handling both addressing, IPv4 & IPv6, can this be done in VyOS 1.5? Thanks in advance!
Provide FRR documentation where it is implemented and which option should be used. As the backend is FRR this feature should be configured somehow before we can add/use it.
And there should be a feature request on https://vyos.dev/ with link to FRR docs and example of FRR configuration
Thanks for the answer @Viacheslav, but it seems that FRR do NOT support Address Families (IPv4 & IPv6) in OSPFv3, in fact, this functionality has been already requested in the feature request list.
