I have the following setup:
WAN eth0: static ip1 mac1
WAN peth0: static ip2 mac2
LAN eth1: internal network
I use the two WAN IPs to do destination NAT, that is, I forward traffic to different internal hosts depending on the WAN IP. Recently my ISP (Hetzner) enforced that the MAC of outgoing packets must match the source IP. With the current configuration all outgoing packets have mac1. Here is a tcpdump of a ping:
12:42:55.466661 gw > mac2, ethertype IPv4 (0x0800), length 98: client > ip2: ICMP echo request, id 12151, seq 29, length 64
12:42:55.466753 mac1 > gw, ethertype IPv4 (0x0800), length 98: ip2 > client: ICMP echo reply, id 12151, seq 29, length 64
How can I make the MAC match the outgoing IP?
Although I don’t need WAN load balancing I set it up to try the sticky-connections feature. No change.
Here is a simplified configuration:
address ip1
mac mac1
pseudo-ethernet peth0 {
address ip2
link eth0
mac mac2
mode private
address 10.1.1.254/24
wan {
interface-health eth0 {
nexthop gw1
interface-health peth0 {
nexthop gw2
rule 10 {
inbound-interface eth1
interface eth0 {
interface peth0 {
sticky-connections {
nat {
destination {
rule 10 {
destination {
address ip1
inbound-interface eth0
Vyos Version: VyOS 1.1.8
