PBR based on GeoIP
Hi Vyos team!
It will be great if it possible to make rules in PBR based on geoip.
What I mean, for example:
set policy route TEST rule 10 destination geoip us
set policy route TEST rule 10 set table 1
set policy route TEST rule 20 destination geoip nl
set policy route TEST rule 20 set table 2
Thank you!
What problem?
vyos@vpp# set policy route FOO rule 10 destination
Possible completions:
   address              IP address, subnet, or range
 > geoip                GeoIP options - Data provided by DB-IP.com
 > group                Group
   port                 Port
The problem is it is not available in stable.
vyos@vyos# set policy route TEST rule 10 destination
 > group                Group
   port                 Port
vyos@vyos# run show version
Version:          VyOS 1.4.2
Release train:    sagitta
Release flavor:   generic
Built by:         VyOS Networks Iberia S.L.U.
Built on:         Tue 01 Apr 2025 17:21 UTC
Build UUID:       01cfd92d-64ae-406c-83f7-bc75e509b75a
Build commit ID:  9cc58255f19640-dirty
Architecture:     x86_64
System type:      KVM guest
Hardware vendor:  OpenStack Foundation
Hardware model:   OpenStack Nova
Hardware S/N:     726d2699-9ddf-4823-99af-bddf16de0e52
Hardware UUID:    726d2699-9ddf-4823-99af-bddf16de0e52
Did you test this feature in a rolling release? Does it work fine?
