when i set firewall address group, it report errors
someone can explain why, Thanks!
Hello @youcan,
This error message shows that you need to use range only in one segment, e,g,
set firewall group address-group test address 172.25.0.0-172.25.0.255
In your case better to define
set firewall group address-group test address 172.25.0.0/16
Or add multiple ranges if you need some flexibility, as an example
set firewall group address-group test address 172.25.1.20-172.25.1.100
when i execute
it reports error
so it not support this usage?
Hi @youcan , for network groups use the following syntax:
set firewall group network-group test network 172.25.0.0/16
