I’m trying to set the following policy route with vyos 1.1.7:
set protocols static table 5 route 10.0.1.29/32 next-hop 10.0.1.1
set policy route A-ROUTE rule 100 destination address 10.0.1.29/32
set policy route A-ROUTE rule 100 protocol tcp
set policy route A-ROUTE rule 100 source address 91.112.x.x/32
set policy route A-ROUTE rule 100 set table 5
set policy route A-ROUTE rule 999 destination address 0.0.0.0/0
set policy route A-ROUTE rule 999 source address 0.0.0.0/0
set policy route A-ROUTE rule 999 set table main
91.112.x.x is the IP of the WAN interface
10.0.1.29 is the IP of an internal server
When I’m trying to commit then I get the following error:
[ policy route A-ROUTE ]
iptables v1.4.12.2: Couldn’t load target `VYATTA_PBR_5’:No such file or directory
Try `iptables -h’ or ‘iptables --help’ for more information.
Use of uninitialized value $rule_strs[1] in join or string at /opt/vyatta/sbin/vyatta-firewall.pl line 642.
Use of uninitialized value $rule_strs[2] in join or string at /opt/vyatta/sbin/vyatta-firewall.pl line 642.
Use of uninitialized value $rule_strs[3] in join or string at /opt/vyatta/sbin/vyatta-firewall.pl line 642.
Use of uninitialized value $rule_strs[4] in join or string at /opt/vyatta/sbin/vyatta-firewall.pl line 642.
Use of uninitialized value $rule_strs[5] in join or string at /opt/vyatta/sbin/vyatta-firewall.pl line 642.
iptables error: No such file or directory - -m comment --comment “A-ROUTE-100” -p tcp --source 91.112.x.x/32 --destination 10.0.1.29/32 -j VYATTA_PBR_5 at /opt/vyatta/sbin/vyatta-firewall.pl line 642.
[[policy route A-ROUTE]] failed
Commit failed
Please help!
