port 53 open
Hi everyone,
hope you guys are doing well.
is there a chance in vyos to get all ports closed/filtered from outside so that only port 22/tcp is open?
i configured the vyos router via zone Policy. Regarding to the configuration, only port 22/tcp should be open.
But a scan with nmap shows the following ports as open
Port State Service
22/tcp open ssh
53/tcp open tcpwrapped
135/tcp filtered msrpc
139/tcp filtered netbios-ssn
445/tcp filtered microsoft-ds
Hope someone can give me a good advice
best regards
Jean
What is your config?
:~$ show configuration
firewall {
all-ping enable
broadcast-ping disable
ipv6-src-route disable
log-martians enable
name Extern-nach-Intern {
default-action drop
rule 10 {
action accept
description “ALLOW-VPN Tunnel Zentrale”
destination {
address 192.168.30.0/24
address 192.168.10.0/24
rule 15 {
action accept
description ALLOW-VOIP-VPN-TRAFFIC
destination {
address 10.10.200.0/24
rule 20 {
action accept
description ALLOW-SMTP
destination {
address 192.168.30.1
port 25
protocol tcp
rule 30 {
action accept
description “ALLOW OWA”
destination {
port 443
protocol tcp
rule 40 {
action accept
description ALLOW-OVPN-DATA
destination {
address 192.168.30.253
port 1194
protocol udp
rule 100 {
action accept
description ALLOW-IPSEC-IKE
destination {
port 500
protocol udp
rule 200 {
action accept
description ALLOW-IPSEC-ESP
protocol esp
name Intern-nach-Extern {
default-action accept
send-redirects enable
source-validation disable
state-policy {
established {
action accept
related {
action accept
syn-cookies enable
address 13.195.155.114/22
hw-id 00:50:56:bd:38:ff
address 192.168.30.254/24
hw-id 00:50:56:bd:30:c0
loopback lo {
nat {
destination {
rule 30 {
description OVPN-DATA
destination {
port 1194
inbound-interface eth0
protocol udp
translation {
rule 40 {
description OWA
destination {
port 443
protocol tcp
translation {
rule 50 {
description “EXCHANGE SMTP”
destination {
port 25
protocol tcp
translation {
rule 49 {
description Umleiten-VPN-Traffic-Filale
destination {
exclude
outbound-interface eth0
rule 50 {
protocol all
translation {
address masquerade
protocols {
static {
route 10.10.200.0/24 {
next-hop 192.168.10.254 {
service {
dns {
forwarding {
listen-on eth1
ssh {
system {
config-management {
commit-revisions 20
console {
device ttyS0 {
speed 9600
gateway-address 13.195.155.114
host-name asanger
login {
user vyos {
authentication {
level admin
name-server **********
ntp {
server 0.pool.ntp.org {
server 1.pool.ntp.org {
server 2.pool.ntp.org {
server de.pool.ntp.org {
package {
repository community {
components main
distribution helium
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone *********
vpn {
ipsec {
auto-update 60
esp-group PHASE_II {
lifetime 14400
pfs dh-group2
proposal 1 {
encryption 3des
hash sha1
ike-group PHASE_I {
dead-peer-detection {
action restart
timeout 30
lifetime 86400
proposal 1 {
dh-group 2
encryption 3des
hash sha1
ipsec-interfaces {
interface eth0
nat-traversal disable
site-to-site {
peer 33.241.16.122 {
authentication {
mode pre-shared-secret
connection-type initiate
default-esp-group PHASE_II
ike-group PHASE_I
local-address 13.195.155.114
tunnel 0 {
esp-group PHASE_II
local {
prefix 192.168.30.0/24
remote {
prefix 192.168.10.0/24
zone-policy {
zone Extern {
from Intern {
firewall {
interface eth0
zone Intern {
from Extern {
firewall {
interface eth1
I’m not using zoning but I think a zone is being applied for traffic passing through (iptables FORWARD chain) VyOS by default. The configuration allows you to set a zone to ‘local-zone’. Can you try to apply this?
Thinking of how the firewall is implemented (in/out/local) compared to iptables (forward in/forward out/input) this would make sense.
