(Possible) Bug with Wireguard configuration
I noticed a strange behaviour using wireshark and zone based firewalls. As I do not know which of my configuration might have an implication on this I am first going to try to share only the relevant parts of the config and later share the whole config.
In short, the behaviour is as follow:
When applying a firewall with a default action of accept to WIREGUARD from LOCAL interface using the command set zone-policy zone WIREGUARD from LOCAL firewall name LOCAL-WIREGUARD all request are blocked. This makes not sense at all but I don’t know how to narrow this down.
System information:
Version:      v2.0.9-hotfix.2
Build ID:     5402463
Build on:     05/11/21 13:17
Copyright:    2012-2020 Ubiquiti Networks, Inc.
HW model:     EdgeRouter 6P
HW S/N:       245A4C593E2F
Uptime:       22:54:07 up  1:08,  1 user,  load average: 0.22, 0.15, 0.07
Here is the relevant part of the config from my pov:
firewall {
    all-ping enable
    broadcast-ping disable
    group {
        address-group DNSoverHTTPs-SERVER {
            address 168.235.81.167
            # Some more
        network-group LAN_NETWORKS {
            description "Local Traffic"
            network 192.168.21.0/24
            network 192.168.31.0/24
            network 192.168.41.0/24
    name GUEST-WAN {
        default-action reject
        rule 30 {
            action drop
            description "Block DNS over HTTPS Traffic"
            destination {
                group {
        rule 40 {
            action accept
            destination {
                port 443
            protocol tcp
        rule 41 {
            action accept
            destination {
                port 80
            protocol tcp
        rule 42 {
            action accept
            destination {
                address 208.67.222.123
                port 53
            protocol tcp_udp
        rule 43 {
            action accept
            destination {
                address 208.67.220.123
                port 53
            protocol tcp_udp
        rule 44 {
            action accept
            destination {
                port 853
            protocol udp
        rule 45 {
            action accept
            destination {
                port 853
            protocol udp
        rule 60 {
            action accept
            protocol icmp
            state {
                established enable
                new enable
        rule 70 {
            action accept
            description "iperf Performance monitor"
            destination {
                address 192.168.80.0/24
                port 5201
            protocol tcp_udp
    name INT-LOCAL {
        default-action accept
    name INT-WAN {
    name INT-WIREGUARD {
    name LOCAL-WIREGUARD {
    name WAN-GUEST {
        default-action drop
        rule 5 {
            action accept
            description "Allow EST/Related Traffic"
            state {
                established enable
                related enable
    name WAN-INT {
        default-action drop
        rule 5 {
            action accept
            state {
                established enable
                related enable
        rule 20 {
            action accept
            protocol icmp
            state {
                new enable
    name WAN-LOCAL {
        default-action drop
        rule 5 {
            action accept
            state {
                established enable
                related enable
        rule 20 {
            action accept
            protocol icmp
            state {
                new enable
        rule 30 {
            action accept
            description WireGuard
            destination {
                port 51820
            protocol udp
        rule 39 {
            action drop
            description "SSH Management"
            destination {
                port 22
            protocol tcp
            recent {
                count 5
                time 60
            state {
                new enable
        rule 40 {
            action accept
            description "Limit SSH when brute force is used"
            destination {
                port 22
            protocol tcp
            state {
                new enable
    name WIREGUARD-INT {
    name WIREGUARD-LOCAL {
    receive-redirects disable
    send-redirects enable
    source-validation disable
    syn-cookies enable
    bridge br21 {
        address 192.168.21.254/24
        aging 300
        bridged-conntrack disable
        description skylounge.INT
        hello-time 2
        max-age 20
        priority 32768
        promiscuous disable
        stp false
    bridge br31 {
        address 192.168.31.254/24
        aging 300
        description skylounge.GUEST
        hello-time 2
        max-age 20
        priority 32768
        promiscuous disable
        stp false
        address 192.168.80.11/24
        duplex auto
        poe {
            output off
        speed auto
        bridge-group {
            bridge br21
        duplex auto
        poe {
            output off
        speed auto
    ethernet eth2 {
        bridge-group {
            bridge br31
        duplex auto
        poe {
            output off
        speed auto
    ethernet eth3 {
        bridge-group {
            bridge br21
        description skylounge.WIFI
        duplex auto
        poe {
            output off
        speed auto
        vif 21 {
            bridge-group {
                bridge br21
        vif 31 {
            bridge-group {
                bridge br31
    ethernet eth4 {
        address dhcp
        duplex auto
        poe {
            output off
        speed auto
    ethernet eth5 {
        duplex auto
        speed auto
    loopback lo {
    wireguard wg0 {
        address 192.168.41.254/24
        description skylounge.WIREGUARD
        listen-port 51820
        mtu 1420
        peer secret {
            allowed-ips 192.168.41.2/32
        peer secret {
            allowed-ips 192.168.41.1/32
        private-key secret
        route-allowed-ips true
protocols {
    static {
        route 0.0.0.0/0 {
            next-hop 192.168.80.254 {
zone-policy {
    zone GUEST {
        default-action drop
        from WAN {
            firewall {
                name WAN-GUEST
        interface br31
    zone INT {
        default-action drop
        from WAN {
            firewall {
                name WAN-INT
        from WIREGUARD {
            firewall {
                name WIREGUARD-INT
        interface br21
    zone LOCAL {
        default-action drop
        from INT {
            firewall {
                name INT-LOCAL
        from WAN {
            firewall {
                name WAN-LOCAL
        from WIREGUARD {
            firewall {
        local-zone
    zone WAN {
        default-action drop
        from GUEST {
            firewall {
                name GUEST-WAN
        from INT {
            firewall {
                name INT-WAN
        interface eth0
    zone WIREGUARD {
        from INT {
            firewall {
                name INT-WIREGUARD
        interface wg0
For the sake of completeness here is the full config:
firewall {
    all-ping enable
    group {
            address 176.56.236.175
            address 176.103.130.131
            address 176.103.130.130
    ipv6-src-route disable
    ip-src-route disable
    log-martians enable
    modify Modify_Local_In_Mark {
        rule 1 {
            action accept
            description "Do not mark local traffic"
            destination {
                group {
        rule 2 {
            action modify
            description restore_all_marks
            modify {
                connmark {
                    restore-mark
        rule 20 {
            action modify
            description "skylounge.INT Mark Packet"
            modify {
                mark 10
                address 192.168.21.0/24
        rule 25 {
            action modify
            description "VoIP Mark Packet"
            modify {
                mark 1
                address 192.168.21.10/32
        rule 30 {
            action modify
            description "skylounge.GUEST Mark Packet"
            modify {
                mark 20
                address 192.168.31.0/24
        rule 100 {
            action modify
            description CopyPacketMarkToConnectionMark
            modify {
                connmark {
                    save-mark
    modify WAN_MOD_IN {
        rule 10 {
            action modify
            modify {
                connmark {
                    restore-mark
        rule 11 {
            action accept
            description DoneOnMarkPresent
            mark !0
    name GUEST-WAN {
        rule 30 {
            action drop
            destination {
                group {
        rule 40 {
            action accept
            destination {
                port 443
            protocol tcp
        rule 41 {
            action accept
            destination {
                port 80
            protocol tcp
        rule 42 {
            action accept
            destination {
                port 53
            protocol tcp_udp
        rule 43 {
            action accept
            destination {
                port 53
            protocol tcp_udp
        rule 44 {
            action accept
            destination {
                port 853
            protocol udp
        rule 45 {
            action accept
            destination {
                port 853
            protocol udp
        rule 60 {
            action accept
            protocol icmp
            state {
                established enable
                new enable
        rule 70 {
            action accept
            destination {
                port 5201
            protocol tcp_udp
    name INT-LOCAL {
    name INT-WAN {
    name WAN-GUEST {
        default-action drop
        rule 5 {
            action accept
            state {
                established enable
                related enable
    name WAN-INT {
        default-action drop
        rule 5 {
            action accept
            state {
                established enable
                related enable
        rule 20 {
            action accept
            protocol icmp
            state {
                new enable
    name WAN-LOCAL {
        default-action drop
        rule 5 {
            action accept
            state {
                established enable
                related enable
        rule 20 {
            action accept
            protocol icmp
            state {
                new enable
        rule 30 {
            action accept
            destination {
                port 51820
            protocol udp
        rule 39 {
            action drop
            destination {
                port 22
            protocol tcp
            recent {
                count 5
                time 60
            state {
                new enable
        rule 40 {
            action accept
            destination {
                port 22
            protocol tcp
            state {
                new enable
    syn-cookies enable
    bridge br21 {
        aging 300
        firewall {
            in {
        hello-time 2
        max-age 20
        priority 32768
        promiscuous disable
        stp false
    bridge br31 {
        aging 300
        firewall {
            in {
        hello-time 2
        max-age 20
        priority 32768
        promiscuous disable
        stp false
        duplex auto
        firewall {
            in {
                modify WAN_MOD_IN
        poe {
            output off
        speed auto
        bridge-group {
            bridge br21
        duplex auto
        poe {
            output off
        speed auto
    ethernet eth2 {
        bridge-group {
            bridge br31
        duplex auto
        poe {
            output off
        speed auto
    ethernet eth3 {
        bridge-group {
            bridge br21
        duplex auto
        poe {
            output off
        speed auto
        vif 21 {
            bridge-group {
                bridge br21
        vif 31 {
            bridge-group {
                bridge br31
    ethernet eth4 {
        address dhcp
        duplex auto
        poe {
            output off
        speed auto
    ethernet eth5 {
        duplex auto
        speed auto
    loopback lo {
    wireguard wg0 {
        listen-port 51820
        mtu 1420
        peer xxxx{
        peer xxxx {
        private-key xxxx
protocols {
    static {
        route 0.0.0.0/0 {
service {
    dhcp-server {
        disabled false
        hostfile-update disable
        shared-network-name skylounge.GUEST {
            authoritative disable
            subnet 192.168.31.0/24 {
                default-router 192.168.31.254
                dns-server 208.67.222.123
                dns-server 208.67.220.123
                lease 86400
                start 192.168.31.100 {
                    stop 192.168.31.150
        shared-network-name skylounge.INT {
            subnet 192.168.21.0/24 {
                default-router 192.168.21.254
                dns-server 1.1.1.1
                lease 86400
                start 192.168.21.100 {
                    stop 192.168.21.150
        static-arp disable
        use-dnsmasq disable
    gui {
        http-port 80
        https-port 443
        older-ciphers enable
    nat {
        rule 5021 {
            description "skylounge.INT to WAN"
            outbound-interface eth0
            protocol all
            type masquerade
        rule 5031 {
            description "skylounge.GUEST to WAN"
            protocol all
            type masquerade
    ssh {
        port 22
        protocol-version v2
    unms {
system {
    analytics-handler {
        send-analytics-report false
    config-management {
        commit-revisions 100
    crash-handler {
        send-crash-report false
    host-name xxxx
    login {
        user skylounge-admin {
            authentication {
                encrypted-password xxxx
                plaintext-password ""
                public-keys lobo@lobo-hp-g7 {
                    key xxxxx
                    type ssh-rsa
            level admin
    name-server 1.1.1.1
    ntp {
        server 0.ubnt.pool.ntp.org {
        server 1.ubnt.pool.ntp.org {
        server 2.ubnt.pool.ntp.org {
        server 3.ubnt.pool.ntp.org {
    syslog {
        global {
            facility all {
                level notice
            facility protocols {
                level debug
    time-zone Europe/Vienna
    traffic-analysis {
        dpi disable
        export enable
traffic-control {
    advanced-queue {
        branch {
            queue 10 {
                bandwidth 10mbit
                description BRANCH_UP
                parent 1
                priority 0
            queue 20 {
                bandwidth 40mbit
                description BRANCH_DOWN
                parent 2
                priority 3
        filters {
            match 1 {
                attach-to 1
                description WAN_Root_to_Branch_UP
                target 10
            match 2 {
                attach-to 2
                description Global_Root_to_Branch_Down
                target 20
            match 1000 {
                attach-to 10
                description VOIP_Up_Filter
                mark 1
                target 100
            match 1100 {
                attach-to 10
                description Int_Up_Filter
                mark 10
                target 110
            match 1200 {
                attach-to 10
                description Guest_Up_Filter
                mark 20
                target 120
            match 2000 {
                attach-to 20
                description VOIP_Down_Filter
                mark 1
                target 200
            match 2100 {
                attach-to 20
                description Int_Down_Filter
                mark 10
                target 210
            match 2200 {
                attach-to 20
                description Guest_Down_Filter
                mark 20
                target 220
        leaf {
            queue 100 {
                bandwidth 1mbit
                ceiling 2mbit
                description VOIP_Up_Leaf
                parent 10
                priority 1
                queue-type FQ_Codel_Up
            queue 110 {
                bandwidth 4mbit
                ceiling 10mbit
                description Int_Up_Leaf
                parent 10
                priority 3
            queue 120 {
                bandwidth 5mbit
                ceiling 10mbit
                description Guest_Up_Leaf
                parent 10
                priority 5
            queue 200 {
                bandwidth 1mbit
                ceiling 5mbit
                description VOIP_Down_Leaf
                parent 20
                priority 1
                queue-type FQ_Codel_Down
            queue 210 {
                bandwidth 19mbit
                ceiling 40mbit
                description Int_Down_Leaf
                parent 20
                priority 3
            queue 220 {
                bandwidth 21mbit
                ceiling 40mbit
                description Guest_Down_Leaf
                parent 20
                priority 5
        queue-type {
            fq-codel FQ_Codel_Down {
                ecn disable
                flows 65535
                interval 28ms
                quantum 300
                target 7ms
            fq-codel FQ_Codel_Up {
                ecn disable
                interval 16ms
                quantum 300
                target 4ms
        root {
            queue 1 {
                attach-to eth0
                bandwidth 10mbit
            queue 2 {
                attach-to global
                bandwidth 40mbit
                description DOWNLOAD_ROOT
zone-policy {
    zone GUEST {
        default-action drop
        from WAN {
            firewall {
                name WAN-GUEST
        interface br31
    zone INT {
        default-action drop
        from WAN {
            firewall {
                name WAN-INT
        from WIREGUARD {
            firewall {
                name WIREGUARD-INT
        interface br21
    zone LOCAL {
        default-action drop
        from INT {
            firewall {
                name INT-LOCAL
        from WAN {
            firewall {
                name WAN-LOCAL
        from WIREGUARD {
            firewall {
        local-zone
    zone WAN {
        default-action drop
        from GUEST {
            firewall {
                name GUEST-WAN
        from INT {
            firewall {
                name INT-WAN
        interface eth0
    zone WIREGUARD {
        from INT {
            firewall {
                name INT-WIREGUARD
        interface wg0
Hi @Lobo did you try this on VyOS?
Hi Dimitri! This is a forked VyOS from Ubiquiti - so the mechanisms schould be the same
Definitely not the same. You should ask on the ubiquity forum where you’ll get platform specific advice.
EdgeOS is not forked from VyOS. Both projects forked from Vyatta at different times, different versions.
