On the newer rolling releases adjust-mss is broken on pppoe.
set interfaces pppoe pppoe0 ip
Possible completions:
adjust-mss Adjust TCP MSS value
disable-forwarding Disable IP forwarding on this interface
source-validation Source validation by reversed path (RFC3704)
set interfaces pppoe pppoe0 ip adjust-mss 1452
While committing this results in an error:
File "/usr/libexec/vyos/conf_mode/interfaces-pppoe.py", line 134, in <module>
apply(c)
File "/usr/libexec/vyos/conf_mode/interfaces-pppoe.py", line 125, in apply
p.update(pppoe)
File "/usr/lib/python3/dist-packages/vyos/ifconfig/pppoe.py", line 129, in update
self.set_dhcpv6(True)
File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 1292, in set_dhcpv6
render(config_file, 'dhcp-client/ipv6.j2', self._config)
File "/usr/lib/python3/dist-packages/vyos/template.py", line 141, in render
rendered = render_to_string(template, content, formater, location)
File "/usr/lib/python3/dist-packages/vyos/template.py", line 110, in render_to_string
rendered = template.render(content)
File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/lib/python3/dist-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "/usr/share/vyos/templates/dhcp-client/ipv6.j2", line 43, in top-level template code
{% for interface, interface_config in pd_config.interface.items() if pd_config.interface is vyos_defined %}
jinja2.exceptions.UndefinedError: 'dict object' has no attribute 'interface'
**[[interfaces pppoe pppoe0]] failed**
