I’m testing some IPv6 changes on the PPPoE interface on my VyOS box.
I noticed the docs mention a connect, and disconnect command for PPPoE here:
However, I made some configuration changes (e.g. enabled DHCPV6-PD, and SLAAC etc) - I then tried to disconnect and reconnect on the PPPoE interface, but nothing seemed to happen, and it didn’t show IPv6 addresses.
I then went into configuration mode, and did:
set interfaces pppoe pppoe0 disable
commit
delete interfaces pppoe pppoe0 disable
commit
And show interfaces showed some changes after that - just curious what connect and disconnect do, and how they might be different to simply administratively disabling the interface?
