Hi Everyone,
The session control option in the PPPoE server on 1.3 latest rolling release is malfunctioning where deny session on PPPoE is not working. Whatever be the configuration the default value of disable is considered.
To overcome this the template file pppoe.config.tmpl under accel-ppp folder has to be updated as below.
Error noticed:-
Session control variable should be under [common] group in PPPoE configuration file but the auto phyton script is creating the session control variable under [ppp] group.
The configuration variable mismatch resulting in default session control replace value with whatever configuration loaded in vyos.
Update Script:-
Add the below lines after [core] module.
[common]
{% if not session_control == ‘disable’ %}
{% if session_control %}
single-session={{session_control}}
{% else %}
single-session={{sesscrtl}}
{% endif -%}
{% endif %}
Post Update:-
Session control now works for all three cases. Deny, replace and disable.
Thank You.
