PPPoE setup
I am unsure if this is the proper spot but here goes.
I know plenty are from the original vyatta and just know this but I have scoured the Internet and these forums for a simple command on how to set pppoe up on my eth1
I have found references to vyatta but I have not attempted.
I see all these what look like scripts I have no idea (I am first time user just learned about this long running project days ago) where would I put these scripts
I just would like a simple set command and commit so I can get it up and running so I can research some more of this wonderful project.
I am taking my router down each day and playing a little bit with this in hopes of eventually getting pppoe running and the basic functionality to browse the web do dhcp squid limit some ports and maybe later get another Internet connection going then balance my voip connection then maybe this vybuddy web interface will be mature enough so its easier to enter things or maybe some stats who knows.
Hello notut,
The following link is PPPoE setup example for VyOS. (I’m not author)
http://sideceres.blogspot.jp/2014/06/vyos-1041.html
This is written in Japanese but maybe you can read set command.
eth0 PPPoE interface connect to Internet
eth2 LAN Interface.
set int eth eth0 pppoe 0
set int eth eth0 pppoe 0 user-id [email protected]
set int eth eth0 pppoe 0 password PASSWORDS
run show int
disconnect: disconnect int pppoe0
connect: connect int pppoe0
3.2.5 MSS config setting
This config apply on LAN interface. I’m not sure this config require or not outside of Japan.
set policy route PPPOE-IN rule 10 protocol tcp
set policy route PPPOE-IN rule 10 set tcp-mss 1414
set policy route PPPOE-IN rule 10 tcp flags SYN
set int eth eth2 policy route PPPOE-IN
Hiroyuki Sato.
Ok , like I said be easy on me first time doing this.
I have entered ports in ranges and I have guessed settings . I love how tab gives you possible commands or that its valid or not.
Looks like I can connect now (thank you Hiroyuki Sato.) I am unsure about the set policy route PPPOE-IN rule 10 set tcp-mss 1414
or what a ontario canada dsl connection would be for tcp-mss.
I can not browse any websites. I am guessing I need to add a route and/or firewall setting. what do I need?
you can see i played with getting my voip sip connection going through no luck there
route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 10.0.0.254 0.0.0.0 UG 0 0 0 eth0 10.0.0.0 * 255.255.255.0 U 0 0 0 eth0 root@hostnaeme:/home/xxxx# ping google.ca PING google.ca (173.194.43.127) 56(84) bytes of data. ^C --- google.ca ping statistics --- 5 packets transmitted, 0 received, 100% packet loss, time 3999ms
[code]vyos@vyos:~$ show interfaces
eth0 - u/u OUTSIDE
eth1 10.0.0.254/24 u/u INSIDE
lo 127.0.0.1/8 u/u
::1/128
pppoe0 2xx.2xx.1xx.1xx u/u
vyos@vyos:~$ show configuration
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name OUTSIDE-IN {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
destination {
address 10.0.0.110
port 5060
protocol tcp_udp
state {
new enable
rule 21 {
action accept
destination {
address 10.0.0.110
port 10001-19001
protocol udp
state {
new enable
name OUTSIDE-LOCAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
icmp {
type-name echo-request
protocol icmp
state {
new enable
rule 30 {
action drop
destination {
port 22
protocol tcp
recent {
count 4
time 60
state {
new enable
rule 31 {
action accept
destination {
port 22
protocol tcp
state {
new enable
rule 32 {
action accept
destination {
port 2238
protocol tcp
state {
new enable
send-redirects enable
source-validation disable
syn-cookies enable
description OUTSIDE
duplex auto
firewall {
in {
name OUTSIDE-IN
local {
name OUTSIDE-LOCAL
hw-id 08:00:27:f3:c5:20
pppoe 0 {
default-route auto
mtu 1492
name-server auto
password ****************
smp_affinity auto
speed auto
address 10.0.0.254/24
description INSIDE
duplex auto
hw-id 08:00:27:55:6e:b2
policy {
route PPPOE-IN
smp_affinity auto
speed auto
loopback lo {
nat {
destination {
rule 10 {
description “Port Forward: SIP to 10.0.0.110”
destination {
port 5060
inbound-interface eth0
protocol tcp_udp
translation {
address 10.0.0.110
rule 11 {
description “Port Forward: SIP RTP to 10.0.0.110”
destination {
port 10001-19001
protocol udp
translation {
address 10.0.0.110
rule 110 {
description “NAT Reflection: INSIDE”
destination {
address 10.0.0.0/24
outbound-interface eth1
address 10.0.0.0/24
translation {
address masquerade
policy {
route PPPOE-IN {
rule 10 {
protocol tcp
set {
tcp-mss 1414
tcp {
flags SYN
service {
dhcp-server {
disabled false
shared-network-name LAN {
authoritative disable
subnet 10.0.0.0/24 {
default-router 10.0.0.254
dns-server 10.0.0.254
domain-name internal-network
lease 86400
start 10.0.0.200 {
stop 10.0.0.253
dns {
forwarding {
cache-size 2000
listen-on eth1
ssh {
port 22
system {
config-management {
commit-revisions 20
console {
device ttyS0 {
speed 9600
host-name vyos
login {
user vyos {
authentication {
level admin
ntp {
server 0.pool.ntp.org {
server 1.pool.ntp.org {
server 2.pool.ntp.org {
package {
auto-sync 1
repository community {
components main
distribution helium
username “”
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone UTC
}[/code]
It looks like the NAT source rule is wrong.
Probably you want to NAT when destination is not like your internal network, and when the traffic is leaving your network.
Destination could be like 0.0.0.0/0 and outgoing interface eth0.
Regards
Arne
oh my
Ok I will read though that and study what i can on it and try again. if I make it work i will surly give back and let folks know
thank you for your analysis and guidance
Anyone know why every 4-5 days my interfaces go admin down / down. I always need to reboot the vm to recover
