PPPOE WAN Configuration issue
I am in the process of migrating my main firewall to vyos. And I have an issue with WAN interface. I am getting an IP address however when I try to ping or trace-route from vyos I get:
Operation not permitted error.
vyos@vyos:~$ traceroute 1.1.1.1
traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 60 byte packets
send: Operation not permitted
Looks like I am getting external IP 90.XX/32, I have tried routing options for pppoe interface ‘auto’ and ‘force’ both are producing the same results.
Any input would be appreciated.
IP route:
run show ip route
F - PBR, f - OpenFabric,
S>* 0.0.0.0/0 [1/0] is directly connected, pppoe0, weight 1, 00:03:02
C>* 192.168.1.0/24 is directly connected, eth1, 00:23:15
C>* 212.XX.XX.XX/32 is directly connected, pppoe0, 00:03:03
Show Interfaces:
run show interfaces
eth0 - u/u WAN
eth1 192.168.1.10/24 u/u LAN
lo 127.0.0.1/8 u/u
::1/128
pppoe0 90.XX.XX.XX/32 u/u
Network Layout:
WAN - PPPOE modem in bridge mode
WAN - vyos physical eth0
LAN - vyos physical eth1
Configuration:
$ show configuration
all-ping enable
    broadcast-ping disable
    config-trap disable
    ipv6-src-route disable
    ip-src-route disable
    log-martians enable
    name LAN-LOCAL {
        default-action accept
    name LAN-WAN {
    name LOCAL-LAN {
    name LOCAL-WAN {
    name WAN-LAN {
        default-action drop
        rule 5 {
            action accept
            description "Allow EST/Related Traffic"
            state {
                established enable
                related enable
        rule 20 {
            action accept
            protocol icmp
            state {
                new enable
    name WAN-LOCAL {
        default-action drop
        rule 5 {
            action accept
            state {
                established enable
                related enable
        rule 20 {
            action accept
            protocol icmp
            state {
                new enable
    send-redirects enable
    source-validation disable
    syn-cookies enable
        description WAN
        hw-id XX
        address 192
        description LAN
        hw-id XX
    loopback lo {
    pppoe pppoe0 {
        authentication {
            password XX
            user XX
        default-route force
        mtu 1492
        source-interface eth0
nat {
        rule 100 {
            outbound-interface eth0
                address 192
            translation {
                address masquerade
service {
    dns {
        forwarding {
            allow-from 192
            cache-size 0
            listen-address 192
            name-server 192
    ssh {
        port 22
system {
    config-management {
        commit-revisions 100
    conntrack {
        modules {
            ftp
            h323
            nfs
            pptp
            sip
            sqlnet
            tftp
    console {
        device ttyS0 {
            speed 115200
    host-name vyos
    login {
        banner {
            post-login "Welcome"
        user vyos {
            authentication {
    name-server 192
    ntp {
        server time {
        server time {
        server time {
    syslog {
        global {
            facility all {
                level info
            facility protocols {
                level debug
zone-policy {
    zone LAN {
        default-action drop
        from LOCAL {
            firewall {
                name LOCAL-LAN
        from WAN {
            firewall {
                name WAN-LAN
        interface eth1
    zone LOCAL {
        default-action drop
        from LAN {
            firewall {
                name LAN-LOCAL
        from WAN {
            firewall {
                name WAN-LOCAL
        local-zone
    zone WAN {
        default-action drop
        from LAN {
            firewall {
                name LAN-WAN
        from LOCAL {
            firewall {
                name LOCAL-WAN
        interface eth0
Apologies for spam had to break up the post as I was getting error that I can’t post more than 2 links in the post.
Base configuration was taken from:
https://blog.kroy.io/2020/05/04/vyos-from-scratch-edition-1
and pppoe configuration was taken from:
https://docs.vyos.io/en/equuleus/configuration/interfaces/pppoe.html?highlight=pppoe#operating-modes
Your masquerade rule should use pppoe as outbound interface , not eth0
But that won’t solve ping/traceroute issue from vyos itself.
Try adding manual default route, next-hop-interface is pppoe0
Also, try without ZBF stuff. (although Local->WAN looks OK)
Can you ping next hop 212.x.x.x ?
I can ping 90.X.X.X but not the 212.X.X.X. also moving NAT to pppoe interface didn’t have any effect ether.
Still getting the same error.
I wonder does anyone have any sort of configuration basic pppoe configuration that works? Just want to test known good configuration.
Forgot to mention I am on the 1.3 epa3.
From looking at the log the only thing that jumps out at me:
Nov 08 19:21:03 zebra[988]: warning: PtP interface pppoe0 with addr 90.X/32 needs a peer address
Log:
Nov 08 19:20:53 kernel: r8169 0000:01:00.0 eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Nov 08 19:20:53 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Nov 08 19:20:53 netplugd[908]: eth0: state INACTIVE flags 0x00001003 UP,BROADCAST,MULTICAST → 0x00011043 UP,BROADCAST,RUNNING,MULTICAST,10000
Nov 08 19:20:53 netplugd[3437]: /etc/netplug/netplug eth0 in → pid 3437
Nov 08 19:20:53 netplugd[908]: eth0: state INNING pid 3437 exited status 0
Nov 08 19:20:54 ntpd[2405]: bind(26) AF_INET6 fe80::%2#123 flags 0x11 failed: Cannot assign requested address
Nov 08 19:20:54 ntpd[2405]: unable to create socket on eth0 (7) for fe80::%2#123
Nov 08 19:20:54 ntpd[2405]: failed to init interface for address fe80::%2
Nov 08 19:20:56 ntpd[2405]: Listen normally on 8 eth0 [fe80::%2]:123
Nov 08 19:20:56 ntpd[2405]: new interface(s) found: waking up resolver
Nov 08 19:21:03 pppd[2277]: Send PPPOE Discovery V1T1 PADI session 0x0 length 4
Nov 08 19:21:03 pppd[2277]: dst ff:ff:ff:ff:ff:ff src 8c:X
Nov 08 19:21:03 pppd[2277]: [service-name]
Nov 08 19:21:03 pppd[2277]: Recv PPPOE Discovery V1T1 PADO session 0x0 length 41
Nov 08 19:21:03 pppd[2277]: dst 8c:X src 84:X
Nov 08 19:21:03 pppd[2277]: [AC-name WAHP06-BNG-01] [service-name] [AC-cookie X]
Nov 08 19:21:03 pppd[2277]: Send PPPOE Discovery V1T1 PADR session 0x0 length 24
Nov 08 19:21:03 pppd[2277]: dst 84:X src 8c:X
Nov 08 19:21:03 pppd[2277]: [service-name] [AC-cookie X]
Nov 08 19:21:03 pppd[2277]: Recv PPPOE Discovery V1T1 PADS session 0x8f4 length 41
Nov 08 19:21:03 pppd[2277]: [service-name] [AC-name WAHP06-BNG-01] [AC-cookie V]
Nov 08 19:21:03 pppd[2277]: PADS: Service-Name: ‘’
Nov 08 19:21:03 pppd[2277]: PPP session is 2292
Nov 08 19:21:03 kernel: pppoe0: renamed from ppp0
Nov 08 19:21:03 pppd[2277]: Connected to 84:X via interface eth0
Nov 08 19:21:03 pppd[2277]: using channel 1
Nov 08 19:21:03 pppd[2277]: Renamed interface ppp0 to pppoe0
Nov 08 19:21:03 pppd[2277]: Using interface pppoe0
Nov 08 19:21:03 pppd[2277]: Connect: pppoe0 <–> eth0
Nov 08 19:21:03 pppd[2277]: sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x>]
Nov 08 19:21:03 isisd[1017]: circuit already disconnected
Nov 08 19:21:03 bgpd[997]: [EC 100663301] INTERFACE_STATE: Cannot find IF ppp0 in VRF 0
Nov 08 19:21:03 systemd-udevd[3477]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 08 19:21:03 pppd[2277]: rcvd [LCP ConfReq id=0x83 <mru 1492> <magic 0x>]
Nov 08 19:21:03 pppd[2277]: sent [LCP ConfAck id=0x83 <mru 1492> <magic 0x>]
Nov 08 19:21:03 pppd[2277]: rcvd [LCP ConfAck id=0x1 <mru 1492> <magic 0x>]
Nov 08 19:21:03 pppd[2277]: sent [LCP EchoReq id=0x0 magic=0x]
Nov 08 19:21:03 systemd-udevd[3477]: link_config: could not get ethtool features for ppp0
Nov 08 19:21:03 systemd-udevd[3477]: Could not set offload features of ppp0: No such device
Nov 08 19:21:03 pppd[2277]: rcvd [CHAP Challenge id=0xb4 , name = “JUNOS”]
Nov 08 19:21:03 pppd[2277]: sent [CHAP Response id=0xb4 , name = “X@X”]
Nov 08 19:21:03 pppd[2277]: rcvd [LCP EchoRep id=0x0 magic=X]
Nov 08 19:21:03 pppd[2277]: rcvd [CHAP Success id=0xb4 “”]
Nov 08 19:21:03 pppd[2277]: CHAP authentication succeeded
Nov 08 19:21:03 pppd[2277]: peer from calling number 84:X authorized
Nov 08 19:21:03 pppd[2277]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Nov 08 19:21:03 pppd[2277]: rcvd [IPCP ConfReq id=0x2d <addr 212.X>]
Nov 08 19:21:03 pppd[2277]: sent [IPCP ConfAck id=0x2d <addr 212.X>]
Nov 08 19:21:03 pppd[2277]: rcvd [IPCP ConfNak id=0x1 <addr 90.X> <ms-dns1 90.X> <ms-dns2 90.X>]
Nov 08 19:21:03 pppd[2277]: sent [IPCP ConfReq id=0x2 <addr 90.X> <ms-dns1 90.X> <ms-dns2 90.255.255.90>]
Nov 08 19:21:03 pppd[2277]: rcvd [IPCP ConfAck id=0x2 <addr 90.X> <ms-dns1 90.X> <ms-dns2 90.X>]
Nov 08 19:21:03 pppd[2277]: Script /etc/ppp/ip-pre-up started (pid 3486)
Nov 08 19:21:03 pppd[3491]: executing /etc/ppp/ip-pre-up.d/1000-vyos-pppoe-pppoe0
Nov 08 19:21:03 pppd[2277]: Script /etc/ppp/ip-pre-up finished (pid 3486), status = 0x0
Nov 08 19:21:03 pppd[2277]: local IP address 90.X
Nov 08 19:21:03 pppd[2277]: remote IP address 212.X
Nov 08 19:21:03 pppd[2277]: primary DNS address 90.X
Nov 08 19:21:03 pppd[2277]: secondary DNS address 90.X
Nov 08 19:21:03 pppd[2277]: Script /etc/ppp/ip-up started (pid 3492)
Nov 08 19:21:03 pppd[3503]: executing /etc/ppp/ip-up.d/1000-vyos-pppoe-pppoe0
Nov 08 19:21:03 pppd[3510]: added default route via pppoe0
Nov 08 19:21:04 systemd[2547]: opt-vyatta-config-tmp-new_config_3494.mount: Succeeded.
Nov 08 19:21:04 systemd[1]: opt-vyatta-config-tmp-new_config_3494.mount: Succeeded.
Nov 08 19:21:04 pppd[2277]: Script /etc/ppp/ip-up finished (pid 3492), status = 0x0
Nov 08 19:21:05 ntpd[2405]: Listen normally on 9 pppoe0 90.X:123
Nov 08 19:21:05 ntpd[2405]: new interface(s) found: waking up resolver
Hello @lepri13. I reproduced your configuration in network laboratory. You need change firewall configuration:
delete zone-policy zone WAN interface 'eth0'
set zone-policy zone WAN interface 'pppoe0'
Hey @RyVolodya.
Thank you so much. I will give it a try over the weekend and report back.
@RyVolodya
I am still testing however I have one observation. I need to have PPPOE interface up in order to be able to configure a zone-policy.
Is there a way to enable / declared the interface active while configuring?
On the side note I was able to ping 1.1.1.1 using updated policy however my machine never got any ping replys. I will continue to troubleshoot at the weekend.
Hello @lepri13
Please send your current config:
vyos@vyos:~$ show configuration commands | strip-private
set firewall name LAN-LOCAL default-action ‘accept’
set firewall name LAN-WAN default-action ‘accept’
set firewall name LOCAL-LAN default-action ‘accept’
set firewall name LOCAL-WAN default-action ‘accept’
set firewall name WAN-LAN default-action ‘drop’
set firewall name WAN-LAN rule 5 action ‘accept’
set firewall name WAN-LAN rule 5 description ‘Allow EST/Related Traffic’
set firewall name WAN-LAN rule 5 state established ‘enable’
set firewall name WAN-LAN rule 5 state related ‘enable’
set firewall name WAN-LAN rule 20 action ‘accept’
set firewall name WAN-LAN rule 20 protocol ‘icmp’
set firewall name WAN-LAN rule 20 state new ‘enable’
set firewall name WAN-LOCAL default-action ‘drop’
set firewall name WAN-LOCAL rule 5 action ‘accept’
set firewall name WAN-LOCAL rule 5 description ‘Allow EST/Related Traffic’
set firewall name WAN-LOCAL rule 5 state established ‘enable’
set firewall name WAN-LOCAL rule 5 state related ‘enable’
set firewall name WAN-LOCAL rule 20 action ‘accept’
set firewall name WAN-LOCAL rule 20 protocol ‘icmp’
set firewall name WAN-LOCAL rule 20 state new ‘enable’
set interfaces ethernet eth0 address ‘xxx.xxx.1.11/24’
set interfaces ethernet eth0 description ‘LAN’
set interfaces ethernet eth0 hw-id ‘XX:XX:XX:XX:XX:6c’
set interfaces ethernet eth1 description ‘WAN’
set interfaces ethernet eth1 hw-id ‘XX:XX:XX:XX:XX:c5’
set interfaces loopback lo
set interfaces pppoe pppoe0 authentication password xxxxxx
set interfaces pppoe pppoe0 authentication user xxxxxx
set interfaces pppoe pppoe0 default-route ‘auto’
set interfaces pppoe pppoe0 mtu ‘1492’
set interfaces pppoe pppoe0 source-interface ‘eth1’
set nat source rule 100 outbound-interface ‘eth1’
set nat source rule 100 source address ‘xxx.xxx.1.0/24’
set nat source rule 100 translation address ‘masquerade’
set service dns forwarding allow-from ‘xxx.xxx.1.0/24’
set service dns forwarding cache-size ‘0’
set service dns forwarding listen-address ‘xxx.xxx.1.11’
set service dns forwarding name-server ‘xxx.xxx.1.1’
set service ssh port ‘22’
set system host-name xxxxxx
set system name-server ‘xxx.xxx.1.1’
set system ntp server xxxxx.tld
set zone-policy zone LAN default-action ‘drop’
set zone-policy zone LAN from LOCAL firewall name ‘LOCAL-LAN’
set zone-policy zone LAN from WAN firewall name ‘WAN-LAN’
set zone-policy zone LAN interface ‘eth0’
set zone-policy zone LOCAL default-action ‘drop’
set zone-policy zone LOCAL from LAN firewall name ‘LAN-LOCAL’
set zone-policy zone LOCAL from WAN firewall name ‘WAN-LOCAL’
set zone-policy zone LOCAL local-zone
set zone-policy zone WAN default-action ‘drop’
set zone-policy zone WAN from LAN firewall name ‘LAN-WAN’
set zone-policy zone WAN from LOCAL firewall name ‘LOCAL-WAN’
set zone-policy zone WAN interface ‘pppoe0’
After connecting the modem the interface is up and I can now assign the rule
@RyVolodya I don’t have an ability to PM you. I would like to share something with Vyos core team as a thank you for all the help.
You could join the Slack community? The devs are always active there.
