PPPoe + zone-policy - PPPoe interface not coming up
Hi All
I am trying to configure vyos in the most basic form using PPPoe with a zone base firewall
eth0 - WAN (PPPoe)
eth1 - LAN 192.168.0.0/24
When I have my zone policy configured the PPPoe interface never comes up
show interfaces
eth0             -                                 u/u  internet
eth1             192.168.0.254/24                  u/D  LAN
lo               127.0.0.1/8                       u/u
If I delete the zone-policy configuration the PPPoe interface comes up.
vyos@vyos# delete zone-policy
vyos@vyos# commit
vyos@vyos:~$ show inter
eth0             -                                 u/u  internet
lo               127.0.0.1/8                       u/u
pppoe0           203.202.73.210/32                 u/u
vyos@vyos:~$
How do I configure zone policy to allow PPPoe to work? Do I need something for eth0 in addition to PPPoe running on eth0?
As the commands have change since vyos 1.3. is my PPPoe stanza correct - to dial immediately and stay permanently connected and reconnect on drop.
set interfaces pppoe pppoe0 authentication password xxxxxx
set interfaces pppoe pppoe0 authentication user xxxxxx
set interfaces pppoe pppoe0 mtu '1492'
set interfaces pppoe pppoe0 service-name 'XXXXXX'
set interfaces pppoe pppoe0 source-interface 'eth0'
Joshy
My full configuration.
set firewall name LAN-LOCAL default-action 'accept'
set firewall name LAN-WAN default-action 'accept'
set firewall name LOCAL-LAN default-action 'accept'
set firewall name LOCAL-WAN default-action 'accept'
set firewall name WAN-LAN default-action 'drop'
set firewall name WAN-LAN enable-default-log
set firewall name WAN-LAN rule 1 action 'accept'
set firewall name WAN-LAN rule 1 description 'Allow Established/Related Traffic'
set firewall name WAN-LAN rule 1 state established 'enable'
set firewall name WAN-LAN rule 1 state related 'enable'
set firewall name WAN-LAN rule 2 action 'drop'
set firewall name WAN-LAN rule 2 log 'enable'
set firewall name WAN-LAN rule 2 state invalid 'enable'
set firewall name WAN-LOCAL default-action 'drop'
set firewall name WAN-LOCAL enable-default-log
set firewall name WAN-LOCAL rule 1 action 'accept'
set firewall name WAN-LOCAL rule 1 description 'Allow Established/Related Traffic'
set firewall name WAN-LOCAL rule 1 state established 'enable'
set firewall name WAN-LOCAL rule 1 state related 'enable'
set firewall name WAN-LOCAL rule 2 action 'drop'
set firewall name WAN-LOCAL rule 2 log 'enable'
set firewall name WAN-LOCAL rule 2 state invalid 'enable'
set interfaces ethernet eth0 description 'internet'
set interfaces ethernet eth0 hw-id 'xx:xx:xx:xx:xx:7a'
set interfaces ethernet eth1 address 'xxx.xxx.0.254/24'
set interfaces ethernet eth1 hw-id 'xx:xx:xx:xx:xx:7b'
set interfaces loopback lo
set nat source rule 100 outbound-interface 'pppoe0'
set nat source rule 100 source address 'xxx.xxx.0.0/24'
Try adding the following to allow packets for pppoe to the router.
set firewall name WAN_LOCAL rule 700 action ‘accept’
set firewall name WAN_LOCAL rule 700 destination port ‘546’
set firewall name WAN_LOCAL rule 700 protocol ‘udp’
set firewall name WAN_LOCAL rule 700 source port ‘547’
This reads as a bug. pppoe protocol itself is NOT ipv4 nor ipv6 (so allowing udp ports makes no sense)
pppoe packets have different ethertype than IPv4, and should not be touched by IPv4 logic. (at least, not before de-encapsulation)
I built a 1.3 image and that just worked with no additional configuration.
set interfaces pppoe pppoe0 default-route 'force'
I’ll try the latest rolling 1.4 image and see if the behaviour is still the same.
Confirmed works okay today using latest rolling release.
