Problem after update to latest rolling
Hello all ,
I have upgrade yesterday one of my 2 route reflector servers from rolling 1.2.xxx to latest 1.4-rolling-202102130218 . It seems that it start to have packet loss every 30-40 icmp packets . In the logs i see the below event ,
Feb 15 14:09:00 ef-1-routeserver2 ntpd[2015]: routing socket reports: No buffer space available
Feb 15 14:09:00 ef-1-routeserver2 ntpd[2015]: message repeated 2 times: [ routing socket reports: No buffer space available]
Feb 15 14:09:01 ef-1-routeserver2 ntpd[2015]: routing socket reports: No buffer space available
Feb 15 14:09:01 ef-1-routeserver2 ntpd[2015]: message repeated 16 times: [ routing socket reports: No buffer space available]
Feb 15 14:09:02 ef-1-routeserver2 ntpd[2015]: message repeated 3 times: [ routing socket reports: No buffer space available]
Feb 15 14:09:02 ef-1-routeserver2 ntpd[2015]: routing socket reports: No buffer space available
Feb 15 14:09:02 ef-1-routeserver2 ntpd[2015]: message repeated 8 times: [ routing socket reports: No buffer space available]
Any ideas ?
Hello @merlinios, is it bare-metal or VM? Could you show configuration?
show configuration commands | strip-private
It is a bare-metal installation ,
superadmin@ef-1-routeserver2.interworks.cloud:~$ show configuration commands | strip-private
set interfaces bonding bond0 description ‘Trunk_to_Z9100’
set interfaces bonding bond0 hash-policy ‘layer2’
set interfaces bonding bond0 member interface ‘eth2’
set interfaces bonding bond0 member interface ‘eth3’
set interfaces bonding bond0 mode ‘802.3ad’
set interfaces bonding bond0 vif 702
set interfaces bonding bond0 vif 704
set interfaces bonding bond0 vif 707 address ‘xxx.xxx.79.185/30’
set interfaces bonding bond0 vif 707 address ‘xxxx:xxxx:1::a/126’
set interfaces bonding bond0 vif 708 address ‘xxx.xxx.79.189/30’
set interfaces bonding bond0 vif 708 address ‘xxxx:xxxx:1::e/126’
set interfaces bonding bond0 vif 999 address ‘xxx.xxx.0.4/29’
set interfaces ethernet eth0 address ‘xxx.xxx.0.42/24’
set interfaces ethernet eth0 description ‘Management’
set interfaces ethernet eth0 duplex ‘auto’
set interfaces ethernet eth0 hw-id ‘XX:XX:XX:XX:XX:e0’
set interfaces ethernet eth0 speed ‘auto’
set interfaces ethernet eth1 duplex ‘auto’
set interfaces ethernet eth1 hw-id ‘XX:XX:XX:XX:XX:e1’
set interfaces ethernet eth1 speed ‘auto’
set interfaces ethernet eth2 duplex ‘auto’
set interfaces ethernet eth2 hw-id ‘XX:XX:XX:XX:XX:50’
set interfaces ethernet eth2 speed ‘auto’
set interfaces ethernet eth3 duplex ‘auto’
set interfaces ethernet eth3 hw-id ‘XX:XX:XX:XX:XX:52’
set interfaces ethernet eth3 speed ‘auto’
set interfaces loopback lo address ‘xxx.xxx.100.4/32’
set interfaces loopback lo address ‘xxxx:xxxx::4/128’
set protocols bgp XXXXXX neighbor xxx.xxx.100.5 address-family ipv4-unicast soft-reconfiguration inbound
set protocols bgp XXXXXX neighbor xxx.xxx.100.5 remote-as ‘50919’
set protocols bgp XXXXXX neighbor xxx.xxx.100.5 update-source ‘xxx.xxx.100.4’
set protocols bgp XXXXXX neighbor xxx.xxx.100.6 address-family ipv4-unicast soft-reconfiguration inbound
set protocols bgp XXXXXX neighbor xxx.xxx.100.6 remote-as ‘50919’
set protocols bgp XXXXXX neighbor xxx.xxx.100.6 update-source ‘xxx.xxx.100.4’
set protocols bgp XXXXXX neighbor xxxx:xxxx::1 address-family ipv6-unicast
set protocols bgp XXXXXX neighbor xxxx:xxxx::1 remote-as ‘50919’
set protocols bgp XXXXXX neighbor xxxx:xxxx::1 update-source ‘xxxx:xxxx::4’
set protocols bgp XXXXXX neighbor xxxx:xxxx::2 address-family ipv6-unicast
set protocols bgp XXXXXX neighbor xxxx:xxxx::2 remote-as ‘50919’
set protocols bgp XXXXXX neighbor xxxx:xxxx::2 update-source ‘xxxx:xxxx::4’
set protocols ospf area 0 network ‘xxx.xxx.0.0/29’
set protocols ospf area 0 network ‘xxx.xxx.100.4/32’
set protocols ospf area 0 network ‘xxx.xxx.79.188/30’
set protocols ospf area 0 network ‘xxx.xxx.79.184/30’
set protocols ospf parameters abr-type ‘cisco’
set protocols ospf parameters router-id ‘xxx.xxx.100.4’
set protocols ospf passive-interface ‘default’
set protocols ospf passive-interface-exclude ‘bond0.999’
set protocols ospf passive-interface-exclude ‘bond0.708’
set protocols ospf passive-interface-exclude ‘bond0.707’
set protocols ospfv3 area xxx.xxx.0.0 interface bond0.707
set protocols ospfv3 area xxx.xxx.0.0 interface bond0.708
set protocols ospfv3 area xxx.xxx.0.0 range xxxx:xxxx:1::8/126
set protocols ospfv3 area xxx.xxx.0.0 range xxxx:xxxx:1::c/126
set protocols ospfv3 parameters router-id ‘xxx.xxx.100.4’
set protocols ospfv3 redistribute connected
set protocols static route xxx.xxx.2.0/24 next-hop xxx.xxx.0.120
set protocols static route xxx.xxx.40.0/24 next-hop xxx.xxx.0.120
set service snmp community interworks authorization ‘ro’
set service snmp community interworks network ‘xxx.xxx.2.0/24’
set service ssh port ‘2222’
set system config-management commit-revisions ‘20’
set system console device ttyS0 speed ‘9600’
set system host-name xxxxxx
set system name-server ‘xxx.xxx.8.8’
set system name-server ‘xxx.xxx.4.4’
set system ntp server xxxxx.tld
set system syslog global facility all level ‘notice’
set system syslog host xxx.xxx.2.130 facility all level ‘warning’
set system time-zone ‘Europe/Athens’
Could you show an output of the command sudo top and press 1
Also, it will be interesting to get NICs information
show interfaces ethernet eth0 physical
show interfaces ethernet eth1 physical
show interfaces ethernet eth2 physical
show interfaces ethernet eth3 physical
And check sudo dmesg output, try to confirm that this is not conntrack table overflow issue
Ofcourse no problem
top - 15:13:27 up  2:04,  2 users,  load average: 3.44, 3.18, 3.12
Tasks: 127 total,   3 running, 124 sleeping,   0 stopped,   0 zombie
%Cpu0  : 54.9 us, 19.5 sy,  0.0 ni, 12.7 id,  0.0 wa,  0.0 hi, 12.9 si,  0.0 st
%Cpu1  : 30.6 us, 23.8 sy,  0.0 ni, 33.1 id,  0.0 wa,  0.0 hi, 12.5 si,  0.0 st
%Cpu2  : 57.7 us, 13.0 sy,  0.0 ni, 21.9 id,  0.0 wa,  0.0 hi,  7.4 si,  0.0 st
%Cpu3  : 39.7 us, 21.9 sy,  0.0 ni, 30.3 id,  0.0 wa,  0.0 hi,  8.1 si,  0.0 st
MiB Mem :  15851.6 total,  12453.4 free,   3016.9 used,    381.3 buff/cache
MiB Swap:      0.0 total,      0.0 free,      0.0 used.  12296.8 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
  991 frr       20   0 1619224 587804   5492 R 155.4   3.6 188:29.44 zebra
 1039 frr       20   0   12100   4048   1836 S  66.1   0.0  80:32.70 ldpd
  999 frr       20   0 2284264   2.0g   7892 R  51.6  13.0  61:27.32 bgpd
 2015 ntp       20   0   76472   3164   2644 S  18.7   0.0  22:10.13 ntpd
  674 root      20   0   63452  26268  23072 S   0.5   0.2   0:35.73 systemd-journal
   10 root      20   0       0      0      0 S   0.3   0.0   0:19.14 ksoftirqd/0
   11 root      20   0       0      0      0 I   0.3   0.0   0:04.13 rcu_sched
   17 root      20   0       0      0      0 S   0.3   0.0   0:19.84 ksoftirqd/1
   22 root      20   0       0      0      0 S   0.3   0.0   0:18.04 ksoftirqd/2
   27 root      20   0       0      0      0 S   0.3   0.0   0:17.90 ksoftirqd/3
    1 root      20   0  170604  10532   7984 S   0.0   0.1   0:02.24 systemd
    2 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kthreadd
    3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
    4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
    6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
    8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
    9 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_trace
   12 root      rt   0       0      0      0 S   0.0   0.0   0:00.01 migration/0
   14 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
   15 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
   16 root      rt   0       0      0      0 S   0.0   0.0   0:00.08 migration/1
   19 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/1:0H-events_highpri
   20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
   21 root      rt   0       0      0      0 S   0.0   0.0   0:00.08 migration/2
   23 root      20   0       0      0      0 I   0.0   0.0   0:00.09 kworker/2:0-mm_percpu_wq
   24 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/2:0H-events_highpri
   25 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
   26 root      rt   0       0      0      0 S   0.0   0.0   0:00.08 migration/3
   29 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/3:0H-events_highpri
   30 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kdevtmpfs
   31 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
   32 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kauditd
   33 root      20   0       0      0      0 S   0.0   0.0   0:00.00 khungtaskd
   34 root      20   0       0      0      0 S   0.0   0.0   0:00.00 oom_reaper
   35 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 writeback
   36 root      20   0       0      0      0 S   0.0   0.0   0:00.06 kcompactd0
   37 root      25   5       0      0      0 S   0.0   0.0   0:00.00 ksmd
   38 root      39  19       0      0      0 S   0.0   0.0   0:00.61 khugepaged
   43 root      20   0       0      0      0 I   0.0   0.0   0:00.06 kworker/1:1-cgroup_destroy
   58 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kintegrityd
   59 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kblockd
   60 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 blkcg_punt_bio
   61 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 md
   62 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 edac-poller
   63 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 devfreq_wq
   64 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 watchdogd
   66 root       0 -20       0      0      0 I   0.0   0.0   0:00.01 kworker/3:1H-kblockd
   68 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kswapd0
   69 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kthrotld
   70 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 irq/25-aerdrv
   71 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 irq/26-aerdrv
   72 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 irq/27-aerdrv
   73 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 irq/28-aerdrv
   74 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 irq/29-aerdrv
   75 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 ipv6_addrconf
   79 root       0 -20       0      0      0 I   0.0   0.0   0:00.01 kworker/0:1H-kblockd
  144 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 i40e
  145 root      20   0       0      0      0 S   0.0   0.0   0:00.00 scsi_eh_0
  146 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 scsi_tmf_0
  147 root      20   0       0      0      0 I   0.0   0.0   0:00.36 kworker/1:2-events_power_efficient
  148 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 ata_sff
  150 root      20   0       0      0      0 S   0.0   0.0   0:00.00 scsi_eh_1
  151 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 scsi_tmf_1
  152 root      20   0       0      0      0 S   0.0   0.0   0:00.00 scsi_eh_2
  153 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 scsi_tmf_2
  154 root      20   0       0      0      0 S   0.0   0.0   0:00.00 scsi_eh_3
  155 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 scsi_tmf_3
  156 root      20   0       0      0      0 S   0.0   0.0   0:00.00 scsi_eh_4
  157 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 scsi_tmf_4
  158 root      20   0       0      0      0 S   0.0   0.0   0:00.00 scsi_eh_5
  159 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 scsi_tmf_5
  160 root      20   0       0      0      0 S   0.0   0.0   0:00.00 scsi_eh_6
  161 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 scsi_tmf_6
  167 root      20   0       0      0      0 I   0.0   0.0   0:00.06 kworker/2:2-events
  168 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 poll_megasas0_s
  170 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/2:1H-kblockd
  175 root       0 -20       0      0      0 I   0.0   0.0   0:00.01 kworker/1:1H-kblockd
  268 root      20   0       0      0      0 S   0.0   0.0   0:00.06 jbd2/sda1-8
  269 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 ext4-rsv-conver
  312 root       0 -20       0      0      0 S   0.0   0.0   0:00.21 loop0
  677 root      20   0  308308  61652  16972 S   0.0   0.4   0:01.65 python3
  679 root      20   0  121764  26148  13196 S   0.0   0.2   0:00.64 python3
  685 root      20   0   21484   5580   3916 S   0.0   0.0   0:00.12 systemd-udevd
  687 root      20   0    8088   7524   1648 S   0.0   0.0   0:00.49 haveged
  796 message+  20   0    8692   3668   3336 S   0.0   0.0   0:00.36 dbus-daemon
  803 root       0 -20    2288     72      0 S   0.0   0.0   0:00.38 atopacctd
superadmin@ef-1-routeserver2.interworks.cloud:~$ show interfaces ethernet eth1 physical
Settings for eth1:
        Supported ports: [ TP ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Half 1000baseT/Full
        Supported pause frame use: No
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: Symmetric
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             1000baseT/Full
        Link partner advertised pause frame use: No
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 2
        Transceiver: internal
        Auto-negotiation: on
        MDI-X: off
        Supports Wake-on: g
        Wake-on: d
        Current message level: 0x000000ff (255)
                               drv probe link timer ifdown ifup rx_err tx_err
        Link detected: yes
driver: tg3
version: 5.10.14-amd64-vyos
firmware-version: FFV20.6.18 bc 5720-v1.39
expansion-rom-version:
bus-info: 0000:04:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
superadmin@ef-1-routeserver2.interworks.cloud:~$ show interfaces ethernet eth2 physical
Settings for eth2:
        Supported ports: [ FIBRE ]
        Supported link modes:   10000baseT/Full
        Supported pause frame use: Symmetric
        Supports auto-negotiation: No
        Advertised link modes:  10000baseT/Full
        Advertised pause frame use: No
        Advertised auto-negotiation: No
        Speed: 10000Mb/s
        Duplex: Full
        Port: Direct Attach Copper
        PHYAD: 0
        Auto-negotiation: off
        Supports Wake-on: g
        Wake-on: g
        Current message level: 0x00000007 (7)
                               drv probe link
        Link detected: yes
driver: i40e
firmware-version: 5.40 0x80002e8d 18.0.14
bus-info: 0000:01:00.0
supports-test: yes
supports-priv-flags: yes
superadmin@ef-1-routeserver2.interworks.cloud:~$ show interfaces ethernet eth3 physical
Settings for eth3:
        Speed: 10000Mb/s
        Duplex: Full
        PHYAD: 0
        Supports Wake-on: d
        Wake-on: d
                               drv probe link
        Link detected: yes
driver: i40e
bus-info: 0000:01:00.1
supports-test: yes
Can i revert to previous version without having any problems ? I have a lot of complaints and no time for troubleshoot unfortunately
Thanks
Sure you can, use operational mode command
 set system image default-boot vyos-1.2....
and reboot router
I guess the main issue related to i40e firmware and i40e kernel module, but on the other hand I see high cpu load by frr components, like zebra, mpls, etc.
Thanks Dmitry ! I will revert to the one that works
Had this exact problem, on one of our core routers after an update. The NIC is actually flapping, it drops the BGP and OSPF routing tables and makes a mess of things, had to isolate router. It may even run for 24 hours but once it happens it’s game over. Eventually this popped up. So the interface logging was not showing anything, I presumed it was routing over flows but that was not the case.
Feb 16 18:44:56 endeavor kernel: [ 657.234688] i40e 0000:04:00.3 eth7: tx_timeout: VSI_seid: 525, Q 1, NTC: 0x89, HWB: 0x89, NTU: 0x97, TAIL: 0x97, INT: 0x1
Feb 16 18:44:56 endeavor kernel: [ 657.234700] i40e 0000:04:00.3 eth7: tx_timeout recovery level 1, txqueue 1
I have two identical servers, one works on the older version, the newer version is unstable.
I’m using Intel X710 nic’s. It was a firmware NVM issue with the card, as of the firmware update today things are stable. Non-Volatile Memory (NVM) Update Utility for Intel® Ethernet Network Adapter 700 Series
NOT WORKING VyOS 1.4-rolling-202202080317 (after firmware updates it works)
ethtool -i eth7
driver: i40e
version: 5.10.96-amd64-vyos
firmware-version: 4.25 0x800014cc 0.0.0
bus-info: 0000:04:00.3
supports-test: yes
WORKING VyOS 1.4-rolling-202101301326
ethtool -i eth7
driver: i40e
version: 5.10.10-amd64-vyos
supports-test: yes
lspci -vt
±07.0-[04]–±00.0 Intel Corporation Ethernet Controller X710 for 10GbE SFP+
| ±00.1 Intel Corporation Ethernet Controller X710 for 10GbE SFP+
| ±00.2 Intel Corporation Ethernet Controller X710 for 10GbE SFP+
| -00.3 Intel Corporation Ethernet Controller X710 for 10GbE SFP+
±09.0-[05]–±00.0 Intel Corporation 82598EB 10-Gigabit AF Dual Port Network Connection
| -00.1 Intel Corporation 82598EB 10-Gigabit AF Dual Port Network Connection
After firmware update VyOS 1.4-rolling-202202080317
ethtool -i eth7
driver: i40e
firmware-version: 8.40 0x8000abdf 1.2992.0
supports-test: yes
Still having issues, no errors but ceilinged at 300mb on a 10gb and started dropping traffic, can’t find anything in the logs. Remote side says they were seeing flapping when it was pushed. Nothing in the logs on our side.
Hi rpoorman ,
So if i understand correctly the firmware update wont solve the problem correct ?
