Problem setting gateway-address on Vyos
Hi Everyone, I am trying to deploy VYOS in my lab and running into issues with the configuring the gateway for eth0. I get error "Configuration path: system [gateway-address] is not valid. This is directly from the document. Am i using the wrong document?
Default gateway
Set a default gateway address for the system:
set system gateway-address
guide- VyOS User Guide — VyOS rolling release (current)
OVA- https://marketplace.vmware.com/vsx/solutions/vyos-1-2-lts-1-2-0
Thanks,
I never use system gateway , try adding static route:
set protocols static route 0.0.0.0/0 next-hop 10.159.18.1
VYOS Version
system gateway has been replaced with ‘set protocols static route 0.0.0.0/0 next-hop X.X.X.X’.
https://vyos.readthedocs.io/en/latest/routing.html
Thanks, This solved my problem…
I am running into another issue, cant ping the devices on different network.
Foreman Server (PXE, IMAGING server)
  • Configured with Single Interface 10.158.18.168/24
  • Discovery setup
  • Setup with DHCP for 10.20.20.0/24
Vyos:
Eth0 - 10.158.18.254/24 - Outbound
Eth1 - 10.20.20.254/24 - DHCP- Relay
Eth2 - 172.16.17.1/24 - DHCP Server
Problem:
Eth1 - 10.20.20.0/24, devices in this network not getting IP address from Foreman
Eth2 - 172.16.17.0/24 - Devices In this network pickup DHCP address and can access internet.
– ping 8.8.8.8 no problem
– ping 10.158.18.254 no problem
– ping 10.158.18.168 fails…
Here is my config:
address 10.159.18.254/24
hw-id 00:50:56:87:93:45
address 10.20.20.254/24
hw-id 00:50:56:87:0d:ce
ethernet eth2 {
address 172.16.17.1/24
loopback lo {
protocols {
static {
route 0.0.0.0/0 {
next-hop 10.159.18.1 {
next-hop 10.159.18.254 {
distance 1
route 10.159.18.0/24 {
distance 2
service {
dhcp-relay {
interface eth0
interface eth1
relay-options {
relay-agents-packets discard
server 10.159.18.168
dhcp-server {
shared-network-name dhcpexample {
authoritative
subnet 172.16.17.0/24 {
default-router 172.16.17.1
dns-server 172.16.17.1
lease 86400
range 0 {
start 172.16.17.100
stop 172.16.17.199
Have you checked that if the traffic is getting to the destination. Could be that your destination isn’t routing it back.
I solved the issue, I added some nat rules and that allowed me to communicated…
Remaining issue is DHCP relay. I will check make sure DHCP options are properly configured…
