I just ran into an interesting problem with DHCP-relay from a multihomed VyOS router (R2). DHCPDISCOVER requests from the client are transmitted to a remote DHCP server, and the server responds with a DHCPOFFER. This is received by R2, but not transmitted back to the client, as witnessed by tcpdump on R2 (and the client not actually getting an IP address). When I disable DHCP-relay on R2, and add a singlehomed VyOS router R3, just as DHCP-relay, to the client subnet, everything works as it should: the client recieves the offer, and requests and receives (dhcpack) the offered address.
One obvious difference between the two, is in the unicast addressing used:
R2:
DHCPDISCOVER: s:10.10.20.2 d:10.10.10.1
DHCPOFFER: s:10.10.10.1 d:[color=#FF0000]10.20.10.1[/color]
R3:
DHCPDISCOVER: s:10.20.10.2 d:10.10.10.1
DHCPOFFER: s:10.10.10.1 d:10.20.10.2
R2 sends the DHCPDISCOVER on it’s upstream interface (R2 eth0), but the DHCP server reponds with a DHCPOFFER directed at the IP listed in the DHCPDISCOVER’s giaddr field , which is the address of R2 eth1. This is correct behaviour as per the DHCP RFC. Apparently, the DHCP relay agent on R2 is unable to match the offer to the discover (tcpdump shows the transaction IDs match). When I use R3 as relay, because of it’s configuration the addresses stay the same, and (presumably) the relay agent is able to match the offer, and forwards it to the client.
Did I miss something when I configured the DHCP-relay on R2, or is this a bug?
Some details:
[DHCPd]-10.10.10.0/24-[R1]-10.10.20.0/24-[R2]-10.20.10.0/24-[client]
DHCPd is a physical linux box running ISC DHCP v4.3.2. v4.2.4 was tested as well.
R1 and R2 are dualhomed virtual VyOS routers
R3 is a singlehome virtual VyOS router connected to 10.20.10.0/24
Client is a virtual linux client (Kali)
All virtual systems are VMware Workstation 11, running on a PC in subnet 10.10.10.0/24. R1 has a bridged NIC in this subnet.
All VyOS routers are v1.1.3.
Other than the DHCP issue, the networks work as intended.
TCPdump from R2, R2 as relay:
19:56:11.635394 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 00:0c:29:c2:f5:fb (oui Unknown), length 334
19:56:11.635628 IP 10.10.20.2.bootps > 10.10.10.1.bootps: BOOTP/DHCP, Request from 00:0c:29:c2:f5:fb (oui Unknown), length 334
19:56:11.637151 IP 10.10.10.1.bootps > 10.20.10.1.bootps: BOOTP/DHCP, Reply, length 339
R2:
address 10.10.20.2/24
description Outside
hw-id 00:0c:29:79:f8:ae
address 10.20.10.1/24
description Inside
hw-id 00:0c:29:79:f8:b8
loopback lo {
protocols {
static {
route 0.0.0.0/0 {
next-hop 10.10.20.1 {
service {
dhcp-relay {
interface eth1
server 10.10.10.1
R3:
address 10.20.10.2/24
hw-id 00:0c:29:c0:b9:56
loopback lo {
protocols {
static {
route 0.0.0.0/0 {
next-hop 10.20.10.1 {
service {
dhcp-relay {
interface eth0
server 10.10.10.1
R1 is a straightforward router with static routes:
ethernet eth2 {
address 10.10.20.1/24
description Outside
hw-id 00:0c:29:d7:77:53
ethernet eth3 {
address 10.10.10.3/24
description Thuisnet
hw-id 00:0c:29:d7:77:49
loopback lo {
protocols {
static {
route 0.0.0.0/0 {
next-hop 10.10.10.1 {
route 10.20.10.0/24 {
next-hop 10.10.20.2 {
