Problem with NAT and WAN Loadbalancer
I have a wierd problem with a wan loadbalancing in vyos 1.3.4. If I set it up like below no traffic will pass trough the router not even from lan to wan ip of the router.
Setup, I have a vyos box with 2 nic.
On nic eth0 has two ISP connectec. VLAN 301 and VLAN 311 both have static IPs, the other nic eth1 has WLAN with differen SSID / VLAN on it. VLAN 122,130,131.
Everything is working fine (DNS, DHCP) from the vyos to the WLAN Clients. The vyos can reach Internet via both ISPs.
I had source nat in place to one ISP. Now I want bloadbalnce both.
If should be a pretty easy tusk, the only twist is, clients try to connect our ISP assigned networks (/28) should not go to the outside. Like Client is loadbalance to ISP A and then goes to the internet to reach ISP B. That why I added the exclusion from the loadbalancing for the /28 Networks from Loadbalancing and added some native source nat only for this destination.
Since there are 3 SSIDs and 3 VLAN many rules needed to be duplicated since with vyos I couldn’t use network groups here. (or at least with 1.3.4)
Maybe this is total the wrong thinking or I overcomplicated the config. Any suggestion on where to improve or make it other are wellcome. Below find attached the full config.
        hw-id b8:85:84:9c:73:aa
        vif 301 {
            address 81.XX.YYY.78/28
            description goetelnet
        vif 311 {
            address 62.AAA.BBB.42/28
            description telekom
        hw-id 0c:37:96:0a:f7:c3
        vif 122 {
            address 192.168.122.254/24
            description "wlan vpn"
        vif 130 {
            address 192.168.130.254/24
            description "wlan intern"
        vif 131 {
            address 192.168.131.254/24
            description "wlan guest"
    loopback lo {
    wireless wlan0 {
        disable
        hw-id 74:40:bb:42:cd:8f
        physical-device phy0
load-balancing {
    wan {
        enable-local-traffic
        flush-connections
        interface-health eth0.301 {
            failure-count 10
            nexthop 81.XX.YYY.65
            success-count 3
        interface-health eth0.311 {
            failure-count 3
            nexthop 62.AAA.BBB.33
            success-count 3
        rule 5 {
            destination {
                address 62.AAA.BBB.32/28
            exclude
            inbound-interface eth1.122
            protocol all
        rule 6 {
            destination {
                address 81.XX.YYY.64/28
            exclude
            protocol all
        rule 10 {
            interface eth1.301 {
                weight 1
            interface eth1.311 {
                weight 1
            protocol all
        rule 15 {
            destination {
            exclude
            inbound-interface eth.130
            protocol all
        rule 16 {
            destination {
            exclude
            protocol all
        rule 20 {
            inbound-interface eth1.130
                weight 1
                weight 1
            protocol all
        rule 25 {
            destination {
            exclude
            inbound-interface eth.131
            protocol all
        rule 26 {
            destination {
            exclude
            protocol all
        rule 30 {
            inbound-interface eth1.131
                weight 1
                weight 1
            protocol all
        sticky-connections {
nat {
        rule 100 {
            destination {
            outbound-interface eth0.301
            protocol all
                address 192.168.130.0/24
            translation {
        rule 110 {
            destination {
                address 192.168.131.0/24
            translation {
        rule 200 {
            destination {
                address 62.159.236.32/28
            outbound-interface eth0.311
            protocol all
            translation {
                address masquerade
        rule 210 {
            destination {
            protocol all
            translation {
                address masquerade
protocols {
    static {
        route 0.0.0.0/0 {
            next-hop 62.AAA.BBB.33 {
            next-hop 81.XX.YYY.65 {
You need a static route for the specific /28 network that routes to ISP B gateway address. That should do the trick
