Problem with updating to latest rolling image
Have regularly updated my rolling image using the usual method. However, as of some days/weeks, I am getting the following error.
If I use the direct link to the latest dated version then all works as expected, but using vyos-rolling-latest.iso seems broken for some reason.
Anyone else experiencing this and found the solution to getting it to work again?
phillipmcmahon@router:~$ add system image
https://downloads.vyos.io/rolling/current/amd64/vyos-rolling-latest.iso
Trying to fetch ISO file from https://downloads.vyos.io/rolling/current/amd64/vyos-rolling-latest.iso
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  309M  100  309M    0     0  11.6M      0  0:00:26  0:00:26 --:--:-- 16.5M
ISO download succeeded.
Checking SHA256 (256-bit) checksum...
100   106  100   106    0     0    254      0 --:--:-- --:--:-- --:--:--   253
Found it.  Verifying checksum...
sha256sum: vyos-1.3-rolling-202010280217-amd64.iso: No such file or directory
vyos-1.3-rolling-202010280217-amd64.iso: FAILED open or read
sha256sum: WARNING: 1 listed file could not be read
Signature check FAILED.
Installation will not be performed.
Exiting...
Please try upgrading to the latest ISO directly by using this URL VyOS Community instead of the latest symlink.
I did already as per my post. It works.
"If I use the direct link to the latest dated version then all works as expected, but using vyos-rolling-latest.iso seems broken for some reason."
I usually use the symlink as it takes care of not having to know exactly the name is the latest ISO and can be run from a job.
I would prefer to understand why the symlink method is now broken.
Any ideas?
The problem here vyatta-cfg-system/install-image at current · vyos/vyatta-cfg-system · GitHub
Looks like line 173 is the offending line. Has some erroneous # element in there if I am not wrong.
Possible bug… Checksum expected a full name of the image instead “rolling-latest”
Definite bug as it’s broken.
Shall I file a report or is this thread good enough?
I created a bug report âš“ T3027 Unable to update system Signature check FAILED
Fixed in next rolling
