Hi Guys,
I have been reading a lot of the documentation about it, but I don’t know what is wrong.
When I try ssh from 172.20.20.2
(DMZ network) to outside the internet, the SNAT gets 201.XX.201.93
or 182.208.XX.154
when should be 201.XX.201.92
or 182.208.XX.156
. If I delete load-balancing I’ve got the correct behavior.
vyos@VoIP# run show version
Version: VyOS 1.4-rolling-202206051402
Release train: sagitta
Built by: autobuild@vyos.net
Built on: Sun 05 Jun 2022 14:02 UTC
Build UUID: 02388a81-5d8d-48af-9737-b509d460c209
Build commit ID: 467062897966e7
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: To be filled by O.E.M.
Hardware model: To be filled by O.E.M.
Hardware S/N: To be filled by O.E.M.
Hardware UUID: 03000200-0400-0500-0006-000700080009
vyos@VoIP:~$ show configuration commands
set interfaces ethernet eth0 address '201.XX.201.93/29'
set interfaces ethernet eth0 address '201.XX.201.92/29'
set interfaces ethernet eth0 description 'Algar'
set interfaces ethernet eth0 hw-id '00:90:27:e6:32:da'
set interfaces ethernet eth1 address '186.208.XX.154/29'
set interfaces ethernet eth1 address '186.208.XX.156/29'
set interfaces ethernet eth1 description 'Veloo'
set interfaces ethernet eth1 hw-id '00:90:27:e6:32:db'
set interfaces ethernet eth2 address '172.20.20.1/24'
set interfaces ethernet eth2 description 'DMZ'
set interfaces ethernet eth2 hw-id '00:90:27:e6:32:dc'
set interfaces ethernet eth3 address '172.21.21.1/24'
set interfaces ethernet eth3 description 'Interno'
set interfaces ethernet eth3 hw-id '00:90:27:e6:32:dd'
set interfaces ethernet eth4 hw-id '00:90:27:e6:32:de'
set interfaces ethernet eth5 hw-id '00:90:27:e6:32:df'
set interfaces loopback lo
set interfaces wireless wlan0 hw-id '1c:4b:d6:6d:d9:d9'
set interfaces wireless wlan0 physical-device 'phy0'
set load-balancing wan interface-health eth0 failure-count '1'
set load-balancing wan interface-health eth0 nexthop '201.XX.201.94'
set load-balancing wan interface-health eth0 success-count '1'
set load-balancing wan interface-health eth1 failure-count '1'
set load-balancing wan interface-health eth1 nexthop '186.208.XX.153'
set load-balancing wan interface-health eth1 success-count '1'
set load-balancing wan rule 10 failover
set load-balancing wan rule 10 inbound-interface 'eth2'
set load-balancing wan rule 10 interface eth0 weight '1'
set load-balancing wan rule 10 interface eth1 weight '1'
set load-balancing wan rule 10 protocol 'all'
set load-balancing wan rule 20 failover
set load-balancing wan rule 20 inbound-interface 'eth3'
set load-balancing wan rule 20 interface eth0 weight '1'
set load-balancing wan rule 20 interface eth1 weight '1'
set load-balancing wan rule 20 protocol 'all'
set nat destination rule 5000 destination address '201.XX.201.92'
set nat destination rule 5000 inbound-interface 'eth0'
set nat destination rule 5000 translation address '172.20.20.2'
set nat destination rule 6000 destination address '186.208.XX.156'
set nat destination rule 6000 inbound-interface 'eth1'
set nat destination rule 6000 translation address '172.20.20.2'
set nat source rule 1000 outbound-interface 'eth0'
set nat source rule 1000 source address '172.21.21.0/24'
set nat source rule 1000 translation address '201.XX.201.93'
set nat source rule 2000 outbound-interface 'eth0'
set nat source rule 2000 source address '172.21.21.0/24'
set nat source rule 2000 translation address '186.208.XX.154'
set nat source rule 3000 outbound-interface 'eth0'
set nat source rule 3000 source address '172.20.20.2'
set nat source rule 3000 translation address '201.XX.201.92'
set nat source rule 4000 outbound-interface 'eth1'
set nat source rule 4000 source address '172.20.20.2'
set nat source rule 4000 translation address '186.208.XX.156'
set service ssh port '22'
set system host-name 'VoIPforAll'
set system login user vyos authentication encrypted-password '$6$aQ5CAXVfXaTrnOQd$8Gy2quOD.JpyiWPkdTVA00YAcWAksgT73utuuK2l380ykCrvBi/VLaeJPvE6xnbajWTG9Vgr9mtvKiYdpQB1j1'
set system ntp server time1.vyos.net
set system ntp server time2.vyos.net
set system ntp server time3.vyos.net
set system time-zone 'America/Maceio'
Best regards,
