I am using Rolling 220305.
I’m doing a configuration that will act as a master. Beyond a basic configuration with NAT, I am removing the interface hardware-ids. I am also trying to delete the Loopback interface.
When I issue the shutdown now command, one of the log messages I see is
[FAILED] Failed unmounting /usr/lib/live/mount/persistence
and
[2643] Failed to unmount /usr/lib/live/mount/persistence: Device or resource busy
I also see a device or resource busy for the loopback interface
Can I safely ignore these errors?
Thanks!
