Protectli VP6650 RJ45 interfaces not showing up, only SFP+
Hi all, I just got a Protectli VP6650 in and installed VyOS 1.3.6 on it. I’m having trouble using the 4x 2.5GbE RJ45 interfaces - they’re not showing up when I run show interfaces or in ip addr output. The 2x SFP+ interfaces show up and I can configure them as expected. Any help would be greatly appreciated!
Edit: I should add, I think I am seeing them when I lspci, the first 2 are the SFP+ and the last 4 I assume are the RJ45:
01:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
01:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
02:00.0 Ethernet controller: Intel Corporation Device 125c (rev 04)
03:00.0 Ethernet controller: Intel Corporation Device 125c (rev 04)
04:00.0 Ethernet controller: Intel Corporation Device 125c (rev 04)
05:00.0 Ethernet controller: Intel Corporation Device 125c (rev 04)
Try latest 1.5-rolling just to verify if its the kernel or some other option:
Also output of sudo dmesg, lsmod and lspci would probably be handy (from both 1.3.6 and 1.5.0-nightly).
I added lspci to the OP, here’s lsmod and dmesg also from 1.3.6:
lsmod: vyos@vyos:~$ lsmodModule Size Used byip_set - Pastebin.com
dmesg: vyos@vyos:~$ sudo dmesg[ 0.000000] Linux version 5.4.268-amd64-vyos (vyos_b - Pastebin.com
If I boot the rolling image will my config work as-is and will I be able to switch back to the 1.3.6 image using the CLI without any hacking around? Only asking to be sure, since 1.3 to 1.5 is a big bump
Since the stuff from pastebin will randomly vanish over time - possible for you to paste that as blockquote here in the forum instead?
Sure, I didn’t because of how long the output is… here is lsmod and I will post dmesg next:
vyos@vyos:~$ lsmod
Module                  Size  Used by
ip_set                 53248  0
xt_state               16384  0
xt_conntrack           16384  3
8021q                  32768  0
garp                   16384  1 8021q
mrp                    20480  1 8021q
xt_MASQUERADE          20480  1
xt_comment             16384  0
af_packet              53248  6
fuse                  135168  3
nft_chain_nat          16384  8
xt_CT                  16384  9
xt_tcpudp              20480  5
nft_compat             20480  18
nfnetlink_cthelper     20480  5
nft_counter            16384  158
nf_tables             176128  290 nft_compat,nft_counter,nft_chain_nat
nfnetlink              16384  4 nfnetlink_cthelper,nft_compat,nf_tables,ip_set
nf_nat_pptp            20480  0
nf_conntrack_pptp      20480  1 nf_nat_pptp
nf_nat_h323            24576  0
nf_conntrack_h323      81920  1 nf_nat_h323
nf_nat_sip             20480  0
nf_conntrack_sip       36864  1 nf_nat_sip
nf_nat_tftp            16384  0
nf_nat_ftp             20480  0
nf_nat                 49152  7 nf_nat_ftp,nf_nat_tftp,nf_nat_pptp,nf_nat_h323,nft_chain_nat,xt_MASQUERADE,nf_nat_sip
nf_conntrack_tftp      20480  1 nf_nat_tftp
nf_conntrack_ftp       24576  1 nf_nat_ftp
nf_conntrack          159744  16 xt_conntrack,nf_nat,nf_conntrack_tftp,nfnetlink_cthelper,nf_nat_ftp,xt_state,nf_conntrack_pptp,nf_nat_tftp,nf_conntrack_sip,nf_conntrack_h323,nf_nat_pptp,nf_conntrack_ftp,xt_CT,nf_nat_h323,xt_MASQUERADE,nf_nat_sip
nf_defrag_ipv6         24576  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
libcrc32c              16384  2 nf_conntrack,nf_nat
x86_pkg_temp_thermal    20480  0
intel_powerclamp       20480  0
tpm_crb                20480  0
coretemp               20480  0
tpm_tis                16384  0
crct10dif_pclmul       16384  1
tpm_tis_core           24576  1 tpm_tis
sg                     32768  0
crc32_pclmul           16384  0
tpm                    73728  3 tpm_tis,tpm_crb,tpm_tis_core
ghash_clmulni_intel    16384  0
aesni_intel           368640  0
acpi_pad               24576  0
rng_core               16384  1 tpm
evdev                  20480  9
button                 24576  0
efi_pstore             16384  0
efivars                20480  1 efi_pstore
pcspkr                 16384  0
crypto_simd            16384  1 aesni_intel
cryptd                 24576  2 crypto_simd,ghash_clmulni_intel
glue_helper            16384  1 aesni_intel
mpls_iptunnel          20480  0
mpls_router            45056  1 mpls_iptunnel
ip_tunnel              24576  1 mpls_router
mpls_gso               16384  0
br_netfilter           28672  0
bridge                192512  1 br_netfilter
stp                    16384  2 bridge,garp
llc                    16384  3 bridge,stp,garp
efivarfs               16384  1
ip_tables              28672  0
x_tables               49152  8 xt_conntrack,nft_compat,xt_state,xt_tcpudp,xt_comment,xt_CT,ip_tables,xt_MASQUERADE
autofs4                53248  2
nls_cp437              20480  0
vfat                   20480  0
fat                    86016  1 vfat
usb_storage            73728  0
ohci_hcd               57344  0
uhci_hcd               53248  0
ehci_hcd               94208  0
squashfs               65536  1
zstd_decompress        86016  1 squashfs
lz4_decompress         24576  1 squashfs
loop                   36864  2
overlay               131072  2
ext4                  487424  1
crc32c_generic         16384  0
crc16                  16384  1 ext4
mbcache                16384  1 ext4
jbd2                   86016  1 ext4
hid_generic            16384  0
usbhid                 65536  0
hid                   135168  2 usbhid,hid_generic
nls_ascii              16384  0
sd_mod                 49152  4
ahci                   40960  2
libahci                45056  1 ahci
libata                245760  2 libahci,ahci
xhci_pci               20480  0
crc32c_intel           24576  3
i40e                  434176  0
scsi_mod              196608  4 sd_mod,usb_storage,libata,sg
xhci_hcd              204800  1 xhci_pci
thermal                20480  0
fan                    20480  0
[    0.000000] Linux version 5.4.268-amd64-vyos (vyos_bld@bbdcc08fd433) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Thu Feb 1 20:43:30 UTC 2024
[    0.000000] Command line: BOOT_IMAGE=/boot/1.3.6/vmlinuz boot=live rootdelay=5 noautologin net.ifnames=0 biosdevname=0 vyos-union=/boot/1.3.6 console=ttyS0,115200 console=tty0
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000071192fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000071193000-0x0000000071193fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000071194000-0x0000000071777fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000071778000-0x0000000074877fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000074878000-0x0000000074991fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x0000000074992000-0x0000000074a6efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000074a6f000-0x0000000075f65fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000075f66000-0x0000000075ffefff] type 20
[    0.000000] BIOS-e820: [mem 0x0000000075fff000-0x0000000075ffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000076000000-0x0000000079ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007aa00000-0x000000007abfffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007b000000-0x00000000803fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000047fbfffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.80 by American Megatrends
[    0.000000] efi:  ACPI=0x74a0b000  ACPI 2.0=0x74a0b014  TPMFinalLog=0x749da000  SMBIOS=0x75c91000  SMBIOS 3.0=0x75c90000  MEMATTR=0x6f18d118  ESRT=0x6f64ae18
[    0.000000] SMBIOS 3.5.0 present.
[    0.000000] DMI: Protectli VP6650/VP6650, BIOS 1.30 01/26/2024
[    0.000000] tsc: Detected 2500.000 MHz processor
[    0.001459] tsc: Detected 2496.000 MHz TSC
[    0.001459] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.001460] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001463] last_pfn = 0x47fc00 max_arch_pfn = 0x400000000
[    0.001534] MTRR default type: write-back
[    0.001534] MTRR fixed ranges enabled:
[    0.001535]   00000-9FFFF write-back
[    0.001535]   A0000-BFFFF uncachable
[    0.001536]   C0000-FFFFF write-protect
[    0.001536] MTRR variable ranges enabled:
[    0.001537]   0 base 0080000000 mask 7F80000000 uncachable
[    0.001537]   1 base 007C000000 mask 7FFC000000 uncachable
[    0.001537]   2 base 2000000000 mask 6000000000 uncachable
[    0.001538]   3 base 1000000000 mask 7000000000 uncachable
[    0.001538]   4 base 0800000000 mask 7800000000 uncachable
[    0.001538]   5 base 4000000000 mask 4000000000 uncachable
[    0.001538]   6 disabled
[    0.001539]   7 disabled
[    0.001539]   8 disabled
[    0.001539]   9 disabled
[    0.001929] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002436] last_pfn = 0x76000 max_arch_pfn = 0x400000000
[    0.013316] esrt: Reserving ESRT space from 0x000000006f64ae18 to 0x000000006f64aea0.
[    0.013319] e820: update [mem 0x6f64a000-0x6f64afff] usable ==> reserved
[    0.013330] Using GB pages for direct mapping
[    0.013331] Incomplete global flushes, disabling PCID
[    0.013416] Secure boot disabled
[    0.013416] RAMDISK: [mem 0x34b51000-0x3659ffff]
[    0.013417] ACPI: Early table checksum verification disabled
[    0.013419] ACPI: RSDP 0x0000000074A0B014 000024 (v02 ALASKA)
[    0.013420] ACPI: XSDT 0x0000000074A0A728 00011C (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.013423] ACPI: FACP 0x000000007498F000 000114 (v06 ALASKA A M I    01072009 AMI  01000013)
[    0.013425] ACPI: DSDT 0x00000000748F4000 09A360 (v02 ALASKA A M I    01072009 INTL 20200717)
[    0.013427] ACPI: FACS 0x0000000074A6E000 000040
[    0.013428] ACPI: FIDT 0x00000000748F3000 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.013430] ACPI: SSDT 0x0000000074991000 00038C (v02 PmaxDv Pmax_Dev 00000001 INTL 20200717)
[    0.013431] ACPI: SSDT 0x00000000748ED000 005D34 (v02 CpuRef CpuSsdt  00003000 INTL 20200717)
[    0.013433] ACPI: SSDT 0x00000000748EA000 002B7D (v02 SaSsdt SaSsdt   00003000 INTL 20200717)
[    0.013434] ACPI: SSDT 0x00000000748E6000 0033E9 (v02 INTEL  IgfxSsdt 00003000 INTL 20200717)
[    0.013435] ACPI: SSDT 0x00000000748D8000 00D7C2 (v02 INTEL  TcssSsdt 00001000 INTL 20200717)
[    0.013436] ACPI: HPET 0x0000000074990000 000038 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.013438] ACPI: APIC 0x00000000748D7000 0001DC (v05 ALASKA A M I    01072009 AMI  01000013)
[    0.013439] ACPI: MCFG 0x00000000748D6000 00003C (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.013440] ACPI: SSDT 0x00000000748D4000 001F1A (v02 ALASKA Ther_Rvp 00001000 INTL 20200717)
[    0.013442] ACPI: UEFI 0x00000000749C1000 000048 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.013443] ACPI: SDEV 0x00000000748D3000 000046 (v01                 00000000      00000000)
[    0.013444] ACPI: NHLT 0x00000000748D2000 00002D (v00 ALASKA A M I    01072009 AMI  01000013)
[    0.013445] ACPI: LPIT 0x00000000748D1000 0000CC (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.013447] ACPI: SSDT 0x00000000748CD000 002A83 (v02 ALASKA PtidDevc 00001000 INTL 20200717)
[    0.013448] ACPI: SSDT 0x00000000748C4000 008F27 (v02 ALASKA TbtTypeC 00000000 INTL 20200717)
[    0.013449] ACPI: DBGP 0x00000000748C3000 000034 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.013450] ACPI: DBG2 0x00000000748C2000 000054 (v00 ALASKA A M I    01072009 AMI  01000013)
[    0.013452] ACPI: SSDT 0x00000000748C0000 00190A (v02 ALASKA UsbCTabl 00001000 INTL 20200717)
[    0.013453] ACPI: DMAR 0x00000000748BF000 000088 (v02 INTEL  EDK2     00000002      01000013)
[    0.013454] ACPI: FPDT 0x00000000748BE000 000044 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.013456] ACPI: SSDT 0x00000000748BD000 0007AE (v02 INTEL  xh_adlLP 00000000 INTL 20200717)
[    0.013457] ACPI: SSDT 0x00000000748B9000 003AEA (v02 SocGpe SocGpe   00003000 INTL 20200717)
[    0.013458] ACPI: SSDT 0x00000000748B5000 0039DA (v02 SocCmn SocCmn   00003000 INTL 20200717)
[    0.013459] ACPI: SSDT 0x00000000748B4000 000144 (v02 Intel  ADebTabl 00001000 INTL 20200717)
[    0.013461] ACPI: SPCR 0x00000000748B3000 000050 (v02 ALASKA A M I    01072009 AMI  0005001B)
[    0.013462] ACPI: TPM2 0x00000000748B1000 00004C (v04 ALASKA A M I    00000001 AMI  00000000)
[    0.013463] ACPI: BGRT 0x00000000748B2000 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.013464] ACPI: PHAT 0x00000000748B0000 0005D1 (v01 ALASKA A M I    00000005 MSFT 0100000D)
[    0.013466] ACPI: WSMT 0x00000000748D0000 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.013467] ACPI: Reserving FACP table memory at [mem 0x7498f000-0x7498f113]
[    0.013468] ACPI: Reserving DSDT table memory at [mem 0x748f4000-0x7498e35f]
[    0.013468] ACPI: Reserving FACS table memory at [mem 0x74a6e000-0x74a6e03f]
[    0.013469] ACPI: Reserving FIDT table memory at [mem 0x748f3000-0x748f309b]
[    0.013469] ACPI: Reserving SSDT table memory at [mem 0x74991000-0x7499138b]
[    0.013470] ACPI: Reserving SSDT table memory at [mem 0x748ed000-0x748f2d33]
[    0.013471] ACPI: Reserving SSDT table memory at [mem 0x748ea000-0x748ecb7c]
[    0.013471] ACPI: Reserving SSDT table memory at [mem 0x748e6000-0x748e93e8]
[    0.013472] ACPI: Reserving SSDT table memory at [mem 0x748d8000-0x748e57c1]
[    0.013472] ACPI: Reserving HPET table memory at [mem 0x74990000-0x74990037]
[    0.013473] ACPI: Reserving APIC table memory at [mem 0x748d7000-0x748d71db]
[    0.013473] ACPI: Reserving MCFG table memory at [mem 0x748d6000-0x748d603b]
[    0.013474] ACPI: Reserving SSDT table memory at [mem 0x748d4000-0x748d5f19]
[    0.013474] ACPI: Reserving UEFI table memory at [mem 0x749c1000-0x749c1047]
[    0.013475] ACPI: Reserving SDEV table memory at [mem 0x748d3000-0x748d3045]
[    0.013476] ACPI: Reserving NHLT table memory at [mem 0x748d2000-0x748d202c]
[    0.013476] ACPI: Reserving LPIT table memory at [mem 0x748d1000-0x748d10cb]
[    0.013477] ACPI: Reserving SSDT table memory at [mem 0x748cd000-0x748cfa82]
[    0.013477] ACPI: Reserving SSDT table memory at [mem 0x748c4000-0x748ccf26]
[    0.013478] ACPI: Reserving DBGP table memory at [mem 0x748c3000-0x748c3033]
[    0.013478] ACPI: Reserving DBG2 table memory at [mem 0x748c2000-0x748c2053]
[    0.013479] ACPI: Reserving SSDT table memory at [mem 0x748c0000-0x748c1909]
[    0.013479] ACPI: Reserving DMAR table memory at [mem 0x748bf000-0x748bf087]
[    0.013480] ACPI: Reserving FPDT table memory at [mem 0x748be000-0x748be043]
[    0.013480] ACPI: Reserving SSDT table memory at [mem 0x748bd000-0x748bd7ad]
[    0.013481] ACPI: Reserving SSDT table memory at [mem 0x748b9000-0x748bcae9]
[    0.013482] ACPI: Reserving SSDT table memory at [mem 0x748b5000-0x748b89d9]
[    0.013482] ACPI: Reserving SSDT table memory at [mem 0x748b4000-0x748b4143]
[    0.013483] ACPI: Reserving SPCR table memory at [mem 0x748b3000-0x748b304f]
[    0.013483] ACPI: Reserving TPM2 table memory at [mem 0x748b1000-0x748b104b]
[    0.013484] ACPI: Reserving BGRT table memory at [mem 0x748b2000-0x748b2037]
[    0.013484] ACPI: Reserving PHAT table memory at [mem 0x748b0000-0x748b05d0]
[    0.013485] ACPI: Reserving WSMT table memory at [mem 0x748d0000-0x748d0027]
[    0.013492] ACPI: Local APIC address 0xfee00000
[    0.013597] No NUMA configuration found
[    0.013598] Faking a node at [mem 0x0000000000000000-0x000000047fbfffff]
[    0.013600] NODE_DATA(0) allocated [mem 0x47fbfd000-0x47fbfffff]
[    0.013613] Zone ranges:
[    0.013614]   DMA32    [mem 0x0000000000001000-0x00000000ffffffff]
[    0.013614]   Normal   [mem 0x0000000100000000-0x000000047fbfffff]
[    0.013615] Movable zone start for each node
[    0.013615] Early memory node ranges
[    0.013616]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
[    0.013616]   node   0: [mem 0x000000000009f000-0x000000000009ffff]
[    0.013617]   node   0: [mem 0x0000000000100000-0x0000000071192fff]
[    0.013617]   node   0: [mem 0x0000000071194000-0x0000000071777fff]
[    0.013618]   node   0: [mem 0x0000000075fff000-0x0000000075ffffff]
[    0.013618]   node   0: [mem 0x0000000100000000-0x000000047fbfffff]
[    0.013764] Zeroed struct page in unavailable ranges: 27882 pages
[    0.013765] Initmem setup node 0 [mem 0x0000000000001000-0x000000047fbfffff]
[    0.013766] On node 0 totalpages: 4133654
[    0.013766]   DMA32 zone: 7261 pages used for memmap
[    0.013766]   DMA32 zone: 26 pages reserved
[    0.013767]   DMA32 zone: 464662 pages, LIFO batch:63
[    0.017176]   Normal zone: 57328 pages used for memmap
[    0.017177]   Normal zone: 3668992 pages, LIFO batch:63
[    0.035949] ACPI: PM-Timer IO Port: 0x1808
[    0.035950] ACPI: Local APIC address 0xfee00000
[    0.035953] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.035954] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.035954] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.035955] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.035955] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.035955] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.035956] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.035956] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.035956] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.035957] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.035957] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.035957] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.035957] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.035958] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.035958] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.035959] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.035959] ACPI: LAPIC_NMI (acpi_id[0x11] high edge lint[0x1])
[    0.035959] ACPI: LAPIC_NMI (acpi_id[0x12] high edge lint[0x1])
[    0.035960] ACPI: LAPIC_NMI (acpi_id[0x13] high edge lint[0x1])
[    0.035960] ACPI: LAPIC_NMI (acpi_id[0x14] high edge lint[0x1])
[    0.035960] ACPI: LAPIC_NMI (acpi_id[0x15] high edge lint[0x1])
[    0.035960] ACPI: LAPIC_NMI (acpi_id[0x16] high edge lint[0x1])
[    0.035961] ACPI: LAPIC_NMI (acpi_id[0x17] high edge lint[0x1])
[    0.035961] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.035996] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.035997] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.035998] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.035999] ACPI: IRQ0 used by override.
[    0.035999] ACPI: IRQ9 used by override.
[    0.036000] Using ACPI (MADT) for SMP configuration information
[    0.036001] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.036005] e820: update [mem 0x6e971000-0x6ead0fff] usable ==> reserved
[    0.036010] ACPI: SPCR: console: uart,io,0x2f8,115200
[    0.036010] TSC deadline timer available
[    0.036011] smpboot: Allowing 12 CPUs, 0 hotplug CPUs
[    0.036022] [mem 0x80400000-0xbfffffff] available for PCI devices
[    0.036023] Booting paravirtualized kernel on bare hardware
[    0.036025] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.069633] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:12 nr_node_ids:1
[    0.069966] percpu: Embedded 49 pages/cpu s160664 r8192 d31848 u262144
[    0.069970] pcpu-alloc: s160664 r8192 d31848 u262144 alloc=1*2097152
[    0.069970] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[    0.069982] Built 1 zonelists, mobility grouping on.  Total pages: 4069039
[    0.069982] Policy zone: Normal
[    0.069983] Kernel command line: BOOT_IMAGE=/boot/1.3.6/vmlinuz boot=live rootdelay=5 noautologin net.ifnames=0 biosdevname=0 vyos-union=/boot/1.3.6 console=ttyS0,115200 console=tty0
[    0.071005] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.071512] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.071561] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.075577] Calgary: detecting Calgary via BIOS EBDA area
[    0.075578] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.095561] Memory: 16040924K/16534616K available (10243K kernel code, 652K rwdata, 2600K rodata, 1200K init, 1492K bss, 493692K reserved, 0K cma-reserved)
[    0.095762] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.095838] rcu: Hierarchical RCU implementation.
[    0.095839] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[    0.095840] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.095841] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.095845] NR_IRQS: 16640, nr_irqs: 2152, preallocated irqs: 16
[    0.096203] Console: colour dummy device 80x25
[    0.096283] printk: console [tty0] enabled
[    1.334983] printk: console [ttyS0] enabled
[    1.339184] ACPI: Core revision 20190816
[    1.343398] hpet: HPET dysfunctional in PC10. Force disabled.
[    1.349146] APIC: Switch to symmetric I/O mode setup
[    1.354114] DMAR: Host address width 39
[    1.357951] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    1.363265] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
[    1.371683] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    1.377003] DMAR: dmar1: reg_base_addr fed91000 ver 5:0 cap d2008c40660462 ecap f050da
[    1.384911] DMAR: RMRR base: 0x0000007c000000 end: 0x000000803fffff
[    1.391170] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    1.397519] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    1.402915] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    1.412999] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    1.418406] x2apic enabled
[    1.421148] Switched APIC routing to cluster x2apic.
[    1.430571] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x23fa772cf26, max_idle_ns: 440795269835 ns
[    1.441074] Calibrating delay loop (skipped), value calculated using timer frequency.. 4992.00 BogoMIPS (lpj=2496000)
[    1.442072] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    1.442072] mce: CPU0: Thermal monitoring enabled (TM1)
[    1.442072] process: using mwait in idle threads
[    1.442072] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[    1.442072] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[    1.442072] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    1.442072] Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
[    1.442072] Spectre V2 : Mitigation: Enhanced IBRS
[    1.442072] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    1.442072] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[    1.442072] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    1.442072] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    1.442072] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    1.442072] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    1.442072] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    1.442072] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[    1.442072] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    1.442072] x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
[    1.442072] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
[    1.442072] Freeing SMP alternatives memory: 28K
[    1.442072] pid_max: default: 32768 minimum: 301
[    1.442072] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.442072] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.442072] smpboot: CPU0: 12th Gen Intel(R) Core(TM) i5-1235U (family: 0x6, model: 0x9a, stepping: 0x4)
[    1.442130] Performance Events: PEBS fmt4+-baseline, generic architected perfmon, full-width counters, Intel PMU driver.
[    1.443074] ... version:                5
[    1.444073] ... bit width:              48
[    1.445073] ... generic registers:      6
[    1.446073] ... value mask:             0000ffffffffffff
[    1.447073] ... max period:             00007fffffffffff
[    1.448073] ... fixed-purpose events:   3
[    1.449073] ... event mask:             000000070000003f
[    1.450096] rcu: Hierarchical SRCU implementation.
[    1.451496] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    1.452165] smp: Bringing up secondary CPUs ...
[    1.453119] x86: Booting SMP configuration:
[    1.454074] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11
[    1.467086] smp: Brought up 1 node, 12 CPUs
[    1.469073] smpboot: Max logical packages: 1
[    1.470075] smpboot: Total of 12 processors activated (59904.00 BogoMIPS)
[    1.472304] devtmpfs: initialized
[    1.473102] x86/mm: Memory block size: 128MB
[    1.474937] PM: Registering ACPI NVS region [mem 0x74992000-0x74a6efff] (905216 bytes)
[    1.475107] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    1.476075] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    1.477114] pinctrl core: initialized pinctrl subsystem
[    1.478309] NET: Registered protocol family 16
[    1.479127] audit: initializing netlink subsys (disabled)
[    1.480108] audit: type=2000 audit(1711671683.039:1): state=initialized audit_enabled=0 res=1
[    1.488084] cpuidle: using governor ladder
[    1.492109] cpuidle: using governor menu
[    1.493086] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    1.494074] ACPI: bus type PCI registered
[    1.495074] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    1.496123] dca service started, version 1.12.1
[    1.497101] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
[    1.498096] PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved in E820
[    1.504087] PCI: Using configuration type 1 for base access
[    1.511081] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    1.513114] ACPI: Added _OSI(Module Device)
[    1.517074] ACPI: Added _OSI(Processor Device)
[    1.521073] ACPI: Added _OSI(3.0 _SCP Extensions)
[    1.526073] ACPI: Added _OSI(Processor Aggregator Device)
[    1.531073] ACPI: Added _OSI(Linux-Dell-Video)
[    1.536073] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    1.541073] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    1.611300] ACPI: 14 ACPI AML tables successfully acquired and loaded
[    1.627675] ACPI: Dynamic OEM Table Load:
[    1.631110] ACPI: SSDT 0xFFFFA06EECA76800 0001AB (v02 PmRef  Cpu0Psd  00003000 INTL 20200717)
[    1.641111] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    1.648239] ACPI: Dynamic OEM Table Load:
[    1.653080] ACPI: SSDT 0xFFFFA06EED329000 000394 (v02 PmRef  Cpu0Cst  00003001 INTL 20200717)
[    1.662209] ACPI: Dynamic OEM Table Load:
[    1.666077] ACPI: SSDT 0xFFFFA06EECA32800 0005E4 (v02 PmRef  Cpu0Ist  00003000 INTL 20200717)
[    1.676229] ACPI: Dynamic OEM Table Load:
[    1.680077] ACPI: SSDT 0xFFFFA06EECA32000 0004B5 (v02 PmRef  Cpu0Hwp  00003000 INTL 20200717)
[    1.690109] ACPI: Dynamic OEM Table Load:
[    1.694081] ACPI: SSDT 0xFFFFA06EED334000 001BAF (v02 PmRef  ApIst    00003000 INTL 20200717)
[    1.703254] ACPI: Dynamic OEM Table Load:
[    1.707079] ACPI: SSDT 0xFFFFA06EED330000 001038 (v02 PmRef  ApHwp    00003000 INTL 20200717)
[    1.717268] ACPI: Dynamic OEM Table Load:
[    1.721077] ACPI: SSDT 0xFFFFA06EED336000 001349 (v02 PmRef  ApPsd    00003000 INTL 20200717)
[    1.731297] ACPI: Dynamic OEM Table Load:
[    1.735079] ACPI: SSDT 0xFFFFA06EECA7C000 000FBB (v02 PmRef  ApCst    00003000 INTL 20200717)
[    1.748473] ACPI: Interpreter enabled
[    1.752111] ACPI: (supports S0 S3 S5)
[    1.755074] ACPI: Using IOAPIC for interrupt routing
[    1.760110] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    1.769844] ACPI: Enabled 7 GPEs in block 00 to 7F
[    1.792109] ACPI: Power Resource [WRST] (on)
[    1.801209] ACPI: Power Resource [TBT0] (on)
[    1.806354] ACPI: Power Resource [TBT1] (on)
[    1.842873] ACPI: Power Resource [FN00] (off)
[    1.848128] ACPI: Power Resource [FN01] (off)
[    1.852122] ACPI: Power Resource [FN02] (off)
[    1.856121] ACPI: Power Resource [FN03] (off)
[    1.861124] ACPI: Power Resource [FN04] (off)
[    1.865733] ACPI: Power Resource [PIN] (off)
[    1.870287] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
[    1.876077] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    1.885354] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER]
[    1.894345] acpi PNP0A08:00: _OSC: OS now controls [PCIeCapability LTR]
[    1.901074] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    1.912335] PCI host bridge to bus 0000:00
[    1.916075] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    1.923074] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    1.930074] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    1.937074] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    1.945074] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    1.952082] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    1.960074] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    1.967074] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[    1.975074] pci_bus 0000:00: root bus resource [mem 0x80400000-0xbfffffff window]
[    1.982074] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[    1.990074] pci_bus 0000:00: root bus resource [bus 00-fe]
[    1.995085] pci 0000:00:00.0: [8086:4601] type 00 class 0x060000
[    2.003125] pci 0000:00:02.0: [8086:46a8] type 00 class 0x030000
[    2.009082] pci 0000:00:02.0: reg 0x10: [mem 0x6002000000-0x6002ffffff 64bit]
[    2.016077] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[    2.023076] pci 0000:00:02.0: reg 0x20: [io  0x3000-0x303f]
[    2.029084] pci 0000:00:02.0: BAR 2: assigned to efifb
[    2.034093] pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
[    2.041074] pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
[    2.050076] pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
[    2.058074] pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
[    2.069159] pci 0000:00:0d.0: [8086:461e] type 00 class 0x0c0330
[    2.075088] pci 0000:00:0d.0: reg 0x10: [mem 0x6003110000-0x600311ffff 64bit]
[    2.082113] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[    2.089321] pci 0000:00:14.0: [8086:51ed] type 00 class 0x0c0330
[    2.095106] pci 0000:00:14.0: reg 0x10: [mem 0x6003100000-0x600310ffff 64bit]
[    2.103165] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    2.110276] pci 0000:00:14.2: [8086:51ef] type 00 class 0x050000
[    2.116097] pci 0000:00:14.2: reg 0x10: [mem 0x6003124000-0x6003127fff 64bit]
[    2.123085] pci 0000:00:14.2: reg 0x18: [mem 0x600312a000-0x600312afff 64bit]
[    2.131320] pci 0000:00:16.0: [8086:51e0] type 00 class 0x078000
[    2.137106] pci 0000:00:16.0: reg 0x10: [mem 0x6003129000-0x6003129fff 64bit]
[    2.145159] pci 0000:00:16.0: PME# supported from D3hot
[    2.151321] pci 0000:00:17.0: [8086:51d3] type 00 class 0x010601
[    2.157096] pci 0000:00:17.0: reg 0x10: [mem 0x81100000-0x81101fff]
[    2.163082] pci 0000:00:17.0: reg 0x14: [mem 0x81103000-0x811030ff]
[    2.170081] pci 0000:00:17.0: reg 0x18: [io  0x3090-0x3097]
[    2.175081] pci 0000:00:17.0: reg 0x1c: [io  0x3080-0x3083]
[    2.181081] pci 0000:00:17.0: reg 0x20: [io  0x3060-0x307f]
[    2.186081] pci 0000:00:17.0: reg 0x24: [mem 0x81102000-0x811027ff]
[    2.193120] pci 0000:00:17.0: PME# supported from D3hot
[    2.199320] pci 0000:00:1c.0: [8086:51b8] type 01 class 0x060400
[    2.205171] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    2.211094] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[    2.219196] pci 0000:00:1c.4: [8086:51bc] type 01 class 0x060400
[    2.225168] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    2.231094] pci 0000:00:1c.4: PTM enabled (root), 4ns granularity
[    2.238321] pci 0000:00:1c.5: [8086:51bd] type 01 class 0x060400
[    2.244170] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    2.250094] pci 0000:00:1c.5: PTM enabled (root), 4ns granularity
[    2.258175] pci 0000:00:1c.6: [8086:51be] type 01 class 0x060400
[    2.264167] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[    2.270093] pci 0000:00:1c.6: PTM enabled (root), 4ns granularity
[    2.277320] pci 0000:00:1c.7: [8086:51bf] type 01 class 0x060400
[    2.283169] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[    2.289094] pci 0000:00:1c.7: PTM enabled (root), 4ns granularity
[    2.297195] pci 0000:00:1f.0: [8086:5182] type 00 class 0x060100
[    2.304283] pci 0000:00:1f.3: [8086:51c8] type 00 class 0x040300
[    2.310131] pci 0000:00:1f.3: reg 0x10: [mem 0x6003120000-0x6003123fff 64bit]
[    2.317124] pci 0000:00:1f.3: reg 0x20: [mem 0x6003000000-0x60030fffff 64bit]
[    2.324181] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    2.331321] pci 0000:00:1f.4: [8086:51a3] type 00 class 0x0c0500
[    2.337099] pci 0000:00:1f.4: reg 0x10: [mem 0x6003128000-0x60031280ff 64bit]
[    2.344101] pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
[    2.351321] pci 0000:00:1f.5: [8086:51a4] type 00 class 0x0c8000
[    2.357094] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    2.365169] pci 0000:01:00.0: [8086:1572] type 00 class 0x020000
[    2.371108] pci 0000:01:00.0: reg 0x10: [mem 0x6000800000-0x6000ffffff 64bit pref]
[    2.378097] pci 0000:01:00.0: reg 0x1c: [mem 0x6001008000-0x600100ffff 64bit pref]
[    2.386092] pci 0000:01:00.0: reg 0x30: [mem 0x81080000-0x810fffff pref]
[    2.393163] pci 0000:01:00.0: PME# supported from D0 D3hot
[    2.398114] pci 0000:01:00.0: reg 0x184: [mem 0x00000000-0x0000ffff 64bit pref]
[    2.405074] pci 0000:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x003fffff 64bit pref] (contains BAR0 for 64 VFs)
[    2.416094] pci 0000:01:00.0: reg 0x190: [mem 0x00000000-0x00003fff 64bit pref]
[    2.423074] pci 0000:01:00.0: VF(n) BAR3 space: [mem 0x00000000-0x000fffff 64bit pref] (contains BAR3 for 64 VFs)
[    2.433364] pci 0000:01:00.1: [8086:1572] type 00 class 0x020000
[    2.439106] pci 0000:01:00.1: reg 0x10: [mem 0x6000000000-0x60007fffff 64bit pref]
[    2.447097] pci 0000:01:00.1: reg 0x1c: [mem 0x6001000000-0x6001007fff 64bit pref]
[    2.454094] pci 0000:01:00.1: reg 0x30: [mem 0x81000000-0x8107ffff pref]
[    2.461160] pci 0000:01:00.1: PME# supported from D0 D3hot
[    2.467106] pci 0000:01:00.1: reg 0x184: [mem 0x00000000-0x0000ffff 64bit pref]
[    2.474074] pci 0000:01:00.1: VF(n) BAR0 space: [mem 0x00000000-0x003fffff 64bit pref] (contains BAR0 for 64 VFs)
[    2.484094] pci 0000:01:00.1: reg 0x190: [mem 0x00000000-0x00003fff 64bit pref]
[    2.491079] pci 0000:01:00.1: VF(n) BAR3 space: [mem 0x00000000-0x000fffff 64bit pref] (contains BAR3 for 64 VFs)
[    2.502351] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    2.507078] pci 0000:00:1c.0:   bridge window [mem 0x81000000-0x810fffff]
[    2.514077] pci 0000:00:1c.0:   bridge window [mem 0x6000000000-0x60010fffff 64bit pref]
[    2.522131] pci 0000:02:00.0: [8086:125c] type 00 class 0x020000
[    2.528105] pci 0000:02:00.0: reg 0x10: [mem 0x80e00000-0x80efffff]
[    2.534106] pci 0000:02:00.0: reg 0x1c: [mem 0x80f00000-0x80f03fff]
[    2.540106] pci 0000:02:00.0: reg 0x30: [mem 0x80d00000-0x80dfffff pref]
[    2.547168] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    2.553180] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    2.558077] pci 0000:00:1c.4:   bridge window [mem 0x80d00000-0x80ffffff]
[    2.565135] pci 0000:03:00.0: [8086:125c] type 00 class 0x020000
[    2.571105] pci 0000:03:00.0: reg 0x10: [mem 0x80b00000-0x80bfffff]
[    2.577106] pci 0000:03:00.0: reg 0x1c: [mem 0x80c00000-0x80c03fff]
[    2.584108] pci 0000:03:00.0: reg 0x30: [mem 0x80a00000-0x80afffff pref]
[    2.590169] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[    2.596181] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    2.601078] pci 0000:00:1c.5:   bridge window [mem 0x80a00000-0x80cfffff]
[    2.608133] pci 0000:04:00.0: [8086:125c] type 00 class 0x020000
[    2.614105] pci 0000:04:00.0: reg 0x10: [mem 0x80800000-0x808fffff]
[    2.620106] pci 0000:04:00.0: reg 0x1c: [mem 0x80900000-0x80903fff]
[    2.627106] pci 0000:04:00.0: reg 0x30: [mem 0x80700000-0x807fffff pref]
[    2.633170] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[    2.640180] pci 0000:00:1c.6: PCI bridge to [bus 04]
[    2.645077] pci 0000:00:1c.6:   bridge window [mem 0x80700000-0x809fffff]
[    2.651137] pci 0000:05:00.0: [8086:125c] type 00 class 0x020000
[    2.657105] pci 0000:05:00.0: reg 0x10: [mem 0x80500000-0x805fffff]
[    2.664106] pci 0000:05:00.0: reg 0x1c: [mem 0x80600000-0x80603fff]
[    2.670106] pci 0000:05:00.0: reg 0x30: [mem 0x80400000-0x804fffff pref]
[    2.677167] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[    2.683180] pci 0000:00:1c.7: PCI bridge to [bus 05]
[    2.688078] pci 0000:00:1c.7:   bridge window [mem 0x80400000-0x806fffff]
[    2.700124] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    2.707156] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[    2.714154] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    2.721154] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    2.728154] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    2.735154] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    2.742153] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    2.749154] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    2.757677] iommu: Default domain type: Translated
[    2.763116] ACPI: bus type USB registered
[    2.767082] usbcore: registered new interface driver usbfs
[    2.772077] usbcore: registered new interface driver hub
[    2.778076] usbcore: registered new device driver usb
[    2.783088] pps_core: LinuxPPS API ver. 1 registered
[    2.788073] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    2.797074] PTP clock support registered
[    2.801084] EDAC MC: Ver: 3.0.0
[    2.804159] Registered efivars operations
[    2.808111] PCI: Using ACPI for IRQ routing
[    2.834471] PCI: pci_cache_line_size set to 64 bytes
[    2.834523] pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[    2.844114] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    2.844114] e820: reserve RAM buffer [mem 0x6e971000-0x6fffffff]
[    2.844115] e820: reserve RAM buffer [mem 0x6f64a000-0x6fffffff]
[    2.844115] e820: reserve RAM buffer [mem 0x71193000-0x73ffffff]
[    2.844116] e820: reserve RAM buffer [mem 0x71778000-0x73ffffff]
[    2.844116] e820: reserve RAM buffer [mem 0x76000000-0x77ffffff]
[    2.844117] e820: reserve RAM buffer [mem 0x47fc00000-0x47fffffff]
[    2.844177] clocksource: Switched to clocksource tsc-early
[    2.849610] pnp: PnP ACPI init
[    2.852825] system 00:00: [io  0x0a00-0x0a0f] has been reserved
[    2.858750] system 00:00: [io  0x0a10-0x0a1f] has been reserved
[    2.864672] system 00:00: [io  0x0a20-0x0a2f] has been reserved
[    2.870587] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    2.871075] pnp 00:01: [dma 0 disabled]
[    2.871092] pnp 00:01: Plug and Play ACPI device, IDs PNP0501 (active)
[    2.871535] pnp 00:02: [dma 0 disabled]
[    2.871552] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[    2.871634] system 00:03: [io  0x0680-0x069f] has been reserved
[    2.877559] system 00:03: [io  0x164e-0x164f] has been reserved
[    2.883476] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    2.883561] system 00:04: [io  0x1854-0x1857] has been reserved
[    2.889485] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    2.891240] pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[    2.903659] system 00:05: [mem 0xfedc0000-0xfedc7fff] has been reserved
[    2.910279] system 00:05: [mem 0xfeda0000-0xfeda0fff] has been reserved
[    2.916889] system 00:05: [mem 0xfeda1000-0xfeda1fff] has been reserved
[    2.923499] system 00:05: [mem 0xfed20000-0xfed7ffff] could not be reserved
[    2.930456] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[    2.937413] system 00:05: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    2.944369] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[    2.951320] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    2.953745] system 00:06: [io  0x2000-0x20fe] has been reserved
[    2.959675] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    2.959990] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    2.960323] pnp: PnP ACPI: found 8 devices
[    2.965260] thermal_sys: Registered thermal governor 'fair_share'
[    2.965260] thermal_sys: Registered thermal governor 'bang_bang'
[    2.971355] thermal_sys: Registered thermal governor 'step_wise'
[    2.977360] thermal_sys: Registered thermal governor 'user_space'
[    2.987886] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    3.002854] pci_bus 0000:00: max bus depth: 1 pci_try_num: 2
[    3.008522] pci 0000:00:02.0: BAR 9: assigned [mem 0x4020000000-0x40ffffffff 64bit pref]
[    3.016605] pci 0000:00:02.0: BAR 7: assigned [mem 0x4010000000-0x4016ffffff 64bit]
[    3.024262] pci 0000:00:1f.5: BAR 0: assigned [mem 0x81104000-0x81104fff]
[    3.031054] pci 0000:01:00.0: BAR 7: no space for [mem size 0x00400000 64bit pref]
[    3.038609] pci 0000:01:00.0: BAR 7: failed to assign [mem size 0x00400000 64bit pref]
[    3.046515] pci 0000:01:00.1: BAR 7: no space for [mem size 0x00400000 64bit pref]
[    3.054083] pci 0000:01:00.1: BAR 7: failed to assign [mem size 0x00400000 64bit pref]
[    3.061991] pci 0000:01:00.0: BAR 10: no space for [mem size 0x00100000 64bit pref]
[    3.069634] pci 0000:01:00.0: BAR 10: failed to assign [mem size 0x00100000 64bit pref]
[    3.077623] pci 0000:01:00.1: BAR 10: no space for [mem size 0x00100000 64bit pref]
[    3.085264] pci 0000:01:00.1: BAR 10: failed to assign [mem size 0x00100000 64bit pref]
[    3.093256] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    3.098225] pci 0000:00:1c.0:   bridge window [mem 0x81000000-0x810fffff]
[    3.105009] pci 0000:00:1c.0:   bridge window [mem 0x6000000000-0x60010fffff 64bit pref]
[    3.113087] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    3.118052] pci 0000:00:1c.4:   bridge window [mem 0x80d00000-0x80ffffff]
[    3.124841] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    3.129808] pci 0000:00:1c.5:   bridge window [mem 0x80a00000-0x80cfffff]
[    3.136601] pci 0000:00:1c.6: PCI bridge to [bus 04]
[    3.141572] pci 0000:00:1c.6:   bridge window [mem 0x80700000-0x809fffff]
[    3.148359] pci 0000:00:1c.7: PCI bridge to [bus 05]
[    3.153329] pci 0000:00:1c.7:   bridge window [mem 0x80400000-0x806fffff]
[    3.160112] pci_bus 0000:00: No. 2 try to assign unassigned res
[    3.166037] release child resource [mem 0x6000000000-0x60007fffff 64bit pref]
[    3.166037] release child resource [mem 0x6000800000-0x6000ffffff 64bit pref]
[    3.166038] release child resource [mem 0x6001000000-0x6001007fff 64bit pref]
[    3.166038] release child resource [mem 0x6001008000-0x600100ffff 64bit pref]
[    3.166039] pci 0000:00:1c.0: resource 15 [mem 0x6000000000-0x60010fffff 64bit pref] released
[    3.174546] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    3.179521] pci 0000:00:1c.0: bridge window [mem 0x00400000-0x017fffff 64bit pref] to [bus 01] add_size 800000 add_align 400000
[    3.190966] pci 0000:00:1c.0: BAR 15: assigned [mem 0x4017000000-0x4018bfffff 64bit pref]
[    3.199137] pci 0000:01:00.0: BAR 0: assigned [mem 0x4017000000-0x40177fffff 64bit pref]
[    3.207226] pci 0000:01:00.1: BAR 0: assigned [mem 0x4017800000-0x4017ffffff 64bit pref]
[    3.215309] pci 0000:01:00.0: BAR 7: assigned [mem 0x4018000000-0x40183fffff 64bit pref]
[    3.223392] pci 0000:01:00.1: BAR 7: assigned [mem 0x4018400000-0x40187fffff 64bit pref]
[    3.231471] pci 0000:01:00.0: BAR 3: assigned [mem 0x4018800000-0x4018807fff 64bit pref]
[    3.239561] pci 0000:01:00.1: BAR 3: assigned [mem 0x4018808000-0x401880ffff 64bit pref]
[    3.247651] pci 0000:01:00.0: BAR 10: assigned [mem 0x4018810000-0x401890ffff 64bit pref]
[    3.255823] pci 0000:01:00.1: BAR 10: assigned [mem 0x4018910000-0x4018a0ffff 64bit pref]
[    3.263992] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    3.268969] pci 0000:00:1c.0:   bridge window [mem 0x81000000-0x810fffff]
[    3.275756] pci 0000:00:1c.0:   bridge window [mem 0x4017000000-0x4018bfffff 64bit pref]
[    3.283840] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    3.288814] pci 0000:00:1c.4:   bridge window [mem 0x80d00000-0x80ffffff]
[    3.295601] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    3.300574] pci 0000:00:1c.5:   bridge window [mem 0x80a00000-0x80cfffff]
[    3.307369] pci 0000:00:1c.6: PCI bridge to [bus 04]
[    3.312342] pci 0000:00:1c.6:   bridge window [mem 0x80700000-0x809fffff]
[    3.319127] pci 0000:00:1c.7: PCI bridge to [bus 05]
[    3.324105] pci 0000:00:1c.7:   bridge window [mem 0x80400000-0x806fffff]
[    3.330895] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    3.337070] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    3.343243] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    3.350114] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000e3fff window]
[    3.356977] pci_bus 0000:00: resource 8 [mem 0x000e4000-0x000e7fff window]
[    3.363849] pci_bus 0000:00: resource 9 [mem 0x000e8000-0x000ebfff window]
[    3.370720] pci_bus 0000:00: resource 10 [mem 0x000ec000-0x000effff window]
[    3.377671] pci_bus 0000:00: resource 11 [mem 0x000f0000-0x000fffff window]
[    3.384623] pci_bus 0000:00: resource 12 [mem 0x80400000-0xbfffffff window]
[    3.391574] pci_bus 0000:00: resource 13 [mem 0x4000000000-0x7fffffffff window]
[    3.398871] pci_bus 0000:01: resource 1 [mem 0x81000000-0x810fffff]
[    3.405134] pci_bus 0000:01: resource 2 [mem 0x4017000000-0x4018bfffff 64bit pref]
[    3.412687] pci_bus 0000:02: resource 1 [mem 0x80d00000-0x80ffffff]
[    3.418948] pci_bus 0000:03: resource 1 [mem 0x80a00000-0x80cfffff]
[    3.425211] pci_bus 0000:04: resource 1 [mem 0x80700000-0x809fffff]
[    3.431479] pci_bus 0000:05: resource 1 [mem 0x80400000-0x806fffff]
[    3.437903] NET: Registered protocol family 2
[    3.442460] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    3.451636] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    3.460257] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    3.468442] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    3.475914] TCP: Hash tables configured (established 131072 bind 65536)
[    3.482564] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    3.489372] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    3.496662] NET: Registered protocol family 1
[    3.501034] NET: Registered protocol family 44
[    3.505495] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    3.514186] PCI: CLS 64 bytes, default 64
[    3.518249] Trying to unpack rootfs image as initramfs...
[    3.813338] Freeing initrd memory: 26940K
[    3.822941] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    3.829402] software IO TLB: mapped [mem 0x66a26000-0x6aa26000] (64MB)
[    3.835943] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23fa772cf26, max_idle_ns: 440795269835 ns
[    3.845975] clocksource: Switched to clocksource tsc
[    3.850968] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    3.859006] Initialise system trusted keyrings
[    3.863522] workingset: timestamp_bits=40 max_order=22 bucket_order=0
[    3.872691] Key type asymmetric registered
[    3.876804] Asymmetric key parser 'x509' registered
[    3.881686] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    3.889120] io scheduler mq-deadline registered
[    3.893666] io scheduler kyber registered
[    3.897703] io scheduler bfq registered
[    3.902538] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    3.909257] efifb: probing for efifb
[    3.912862] efifb: framebuffer at 0x4000000000, using 1920k, total 1920k
[    3.919558] efifb: mode is 800x600x32, linelength=3200, pages=1
[    3.925478] efifb: scrolling: redraw
[    3.929060] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    3.935089] Console: switching to colour frame buffer device 100x37
[    3.941756] fb0: EFI VGA frame buffer device
[    3.946056] intel_idle: does not run on family 6 model 154
[    3.946349] Monitor-Mwait will be used to enter C-1 state
[    3.946369] Monitor-Mwait will be used to enter C-2 state
[    3.946385] Monitor-Mwait will be used to enter C-3 state
[    3.949036] ioatdma: Intel(R) QuickData Technology Driver 5.00
[    3.954919] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.983997] 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    4.014150] 00:02: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[    4.021745] hpet_acpi_add: no address or irqs in _CRS
[    4.026842] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    4.033549] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    4.041351] i8042: PNP: No PS/2 controller found.
[    4.046116] rtc_cmos rtc_cmos: RTC can wake from S4
[    4.051538] rtc_cmos rtc_cmos: registered as rtc0
[    4.056259] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[    4.063486] intel_pstate: Intel P-state driver initializing
[    4.070762] intel_pstate: HWP enabled
[    4.075287] ledtrig-cpu: registered to indicate activity on CPUs
[    4.081966] NET: Registered protocol family 10
[    4.092641] Segment Routing with IPv6
[    4.096596] mip6: Mobile IPv6
[    4.101362] microcode: sig=0x906a4, pf=0x80, revision=0x429
[    4.107598] microcode: Microcode Update Driver: v2.2.
[    4.107601] IPI shorthand broadcast: enabled
[    4.117577] sched_clock: Marking stable (2772675346, 1344890894)->(4455860367, -338294127)
[    4.126353] registered taskstats version 1
[    4.130726] Loading compiled-in X.509 certificates
[    4.137535] rtc_cmos rtc_cmos: setting system clock to 2024-03-29T00:21:27 UTC (1711671687)
[    4.146535] Freeing unused kernel image memory: 1200K
[    4.152913] Write protecting the kernel read-only data: 16384k
[    4.159768] Freeing unused kernel image memory: 2036K
[    4.165530] Freeing unused kernel image memory: 1496K
[    4.174411] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    4.181105] Run /init as init process
[    4.228498] thermal LNXTHERM:00: registered as thermal_zone0
[    4.234745] ACPI: Thermal Zone [TZ00] (28 C)
[    4.239833] SCSI subsystem initialized
[    4.244325] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[    4.244370] i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 2.8.20-k
[    4.249885] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[    4.258310] i40e: Copyright (c) 2013 - 2019 Intel Corporation.
[    4.267218] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000000009810
[    4.282699] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[    4.282758] libata version 3.00 loaded.
[    4.284549] i40e 0000:01:00.0: fw 6.1.49420 api 1.7 nvm 6.80 0x80003cf2 255.65535.255 [8086:1572] [8086:0000]
[    4.288212] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[    4.288214] xhci_hcd 0000:00:0d.0: Host supports USB 3.2 Enhanced SuperSpeed
[    4.314343] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    4.323132] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.330867] usb usb1: Product: xHCI Host Controller
[    4.330983] ahci 0000:00:17.0: version 3.0
[    4.336273] usb usb1: Manufacturer: Linux 5.4.268-amd64-vyos xhci-hcd
[    4.336487] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    4.343235] usb usb1: SerialNumber: 0000:00:0d.0
[    4.351602] ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part deso sadm sds
[    4.351755] scsi host0: ahci
[    4.357050] hub 1-0:1.0: USB hub found
[    4.365990] scsi host1: ahci
[    4.369286] hub 1-0:1.0: 1 port detected
[    4.373321] ata1: SATA max UDMA/133 abar m2048@0x81102000 port 0x81102100 irq 128
[    4.377345] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    4.381019] ata2: SATA max UDMA/133 abar m2048@0x81102000 port 0x81102180 irq 128
[    4.406120] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.413986] usb usb2: Product: xHCI Host Controller
[    4.419511] usb usb2: Manufacturer: Linux 5.4.268-amd64-vyos xhci-hcd
[    4.426588] usb usb2: SerialNumber: 0000:00:0d.0
[    4.432084] hub 2-0:1.0: USB hub found
[    4.436532] hub 2-0:1.0: 4 ports detected
[    4.592632] i40e 0000:01:00.0: MAC address: xxx
[    4.599239] i40e 0000:01:00.0: FW LLDP is enabled
[    4.608926] i40e 0000:01:00.0: PCI-Express: Speed 8.0GT/s Width x4
[    4.615775] i40e 0000:01:00.0: PCI-Express bandwidth available for this device may be insufficient for optimal performance.
[    4.628171] i40e 0000:01:00.0: Please move the device to a different PCI-e link with more lanes and/or higher transfer rate.
[    4.641157] i40e 0000:01:00.0: Features: PF-id[0] VFs: 64 VSIs: 66 QP: 12 RSS FD_ATR FD_SB NTUPLE VxLAN Geneve PTP VEPA
[    4.663774] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    4.665551] i40e 0000:01:00.1: fw 6.1.49420 api 1.7 nvm 6.80 0x80003cf2 255.65535.255 [8086:1572] [8086:0000]
[    4.669687] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    4.687250] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.690228] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000000009810
[    4.695649] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.706159] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    4.712835] ata1.00: supports DRM functions and may not be fully accessible
[    4.720414] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    4.727752] ata2.00: supports DRM functions and may not be fully accessible
[    4.733526] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    4.733528] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    4.741135] ata1.00: disabling queued TRIM support
[    4.749075] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    4.756483] ata1.00: ATA-11: Samsung SSD 870 EVO 500GB, SVT02B6Q, max UDMA/133
[    4.756484] ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    4.756681] ata2.00: disabling queued TRIM support
[    4.765446] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.765447] usb usb3: Product: xHCI Host Controller
[    4.765448] usb usb3: Manufacturer: Linux 5.4.268-amd64-vyos xhci-hcd
[    4.765449] usb usb3: SerialNumber: 0000:00:14.0
[    4.765604] hub 3-0:1.0: USB hub found
[    4.773116] ata2.00: ATA-11: Samsung SSD 870 EVO 500GB, SVT02B6Q, max UDMA/133
[    4.773116] ata2.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    4.774903] ata1.00: supports DRM functions and may not be fully accessible
[    4.780721] hub 3-0:1.0: 12 ports detected
[    4.788876] ata2.00: supports DRM functions and may not be fully accessible
[    4.795523] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    4.800860] ata1.00: disabling queued TRIM support
[    4.806135] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.810799] ata2.00: disabling queued TRIM support
[    4.818269] usb usb4: Product: xHCI Host Controller
[    4.818270] usb usb4: Manufacturer: Linux 5.4.268-amd64-vyos xhci-hcd
[    4.818271] usb usb4: SerialNumber: 0000:00:14.0
[    4.826819] ata1.00: configured for UDMA/133
[    4.833296] hub 4-0:1.0: USB hub found
[    4.837884] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 870  2B6Q PQ: 0 ANSI: 5
[    4.838284] ata2.00: configured for UDMA/133
[    4.845415] hub 4-0:1.0: 4 ports detected
[    4.854807] scsi 1:0:0:0: Direct-Access     ATA      Samsung SSD 870  2B6Q PQ: 0 ANSI: 5
[    4.914947] ata1.00: Enabling discard_zeroes_data
[    4.920230] ata2.00: Enabling discard_zeroes_data
[    4.925362] sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    4.925497] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    4.933541] sd 1:0:0:0: [sdb] Write Protect is off
[    4.941533] sd 0:0:0:0: [sda] Write Protect is off
[    4.946666] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    4.946718] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.952017] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    4.961814] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.978767] i40e 0000:01:00.1: MAC address: xxx
[    4.985339] i40e 0000:01:00.1: FW LLDP is enabled
[    4.994917] i40e 0000:01:00.1: PCI-Express: Speed 8.0GT/s Width x4
[    5.001723] i40e 0000:01:00.1: PCI-Express bandwidth available for this device may be insufficient for optimal performance.
[    5.014038] i40e 0000:01:00.1: Please move the device to a different PCI-e link with more lanes and/or higher transfer rate.
[    5.026928] i40e 0000:01:00.1: Features: PF-id[1] VFs: 64 VSIs: 66 QP: 12 RSS FD_ATR FD_SB NTUPLE VxLAN Geneve PTP VEPA
[    5.039056] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[    5.048269] ata1.00: Enabling discard_zeroes_data
[    5.053651] ata2.00: Enabling discard_zeroes_data
[    5.060654]  sda: sda1 sda2 sda3
[    5.060656]  sdb: sdb1 sdb2 sdb3
[    5.075203] ata2.00: Enabling discard_zeroes_data
[    5.083784] sd 1:0:0:0: [sdb] supports TCG Opal
[    5.083984] ata1.00: Enabling discard_zeroes_data
[    5.089691] sd 1:0:0:0: [sdb] Attached SCSI disk
[    5.096899] sd 0:0:0:0: [sda] supports TCG Opal
[    5.106211] sd 0:0:0:0: [sda] Attached SCSI disk
[    5.124796] md/raid1:md0: not clean -- starting background reconstruction
[    5.132080] md/raid1:md0: active with 2 out of 2 mirrors
[    5.142968] md0: detected capacity change from 0 to 499838287872
[    5.149674] md: resync of RAID array md0
[    5.174916] usb 3-1: New USB device found, idVendor=2109, idProduct=2812, bcdDevice= d.a0
[    5.185278] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.193388] usb 3-1: Product: USB2.0 Hub
[    5.193389] usb 3-1: Manufacturer: VIA Labs, Inc.
[    5.194197] hub 3-1:1.0: USB hub found
[    5.209603] hub 3-1:1.0: 4 ports detected
[    5.531089] usb 3-1.1: new full-speed USB device number 3 using xhci_hcd
[    5.634924] usb 3-1.1: New USB device found, idVendor=046d, idProduct=c08b, bcdDevice=27.03
[    5.645688] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.653912] usb 3-1.1: Product: G502 HERO Gaming Mouse
[    5.659663] usb 3-1.1: Manufacturer: Logitech
[    5.664628] usb 3-1.1: SerialNumber: XXX
[    5.678142] hidraw: raw HID events driver (C) Jiri Kosina
[    5.686751] usbcore: registered new interface driver usbhid
[    5.693162] usbhid: USB HID core driver
[    5.698974] input: Logitech G502 HERO Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.0/0003:046D:C08B.0001/input/input0
[    5.713152] hid-generic 0003:046D:C08B.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech G502 HERO Gaming Mouse] on usb-0000:00:14.0-1.1/input0
[    5.727413] input: Logitech G502 HERO Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0002/input/input1
[    5.755085] usb 3-1.4: new full-speed USB device number 4 using xhci_hcd
[    5.794234] input: Logitech G502 HERO Gaming Mouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0002/input/input2
[    5.813884] input: Logitech G502 HERO Gaming Mouse System Control as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0002/input/input3
[    5.829736] hid-generic 0003:046D:C08B.0002: input,hiddev0,hidraw1: USB HID v1.11 Keyboard [Logitech G502 HERO Gaming Mouse] on usb-0000:00:14.0-1.1/input1
[    5.858097] usb 3-1.4: New USB device found, idVendor=24f0, idProduct=0140, bcdDevice= 1.00
[    5.867197] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.875729] usb 3-1.4: Product: Das Keyboard
[    5.880716] usb 3-1.4: Manufacturer: Metadot - Das Keyboard
[    5.894204] input: Metadot - Das Keyboard Das Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.4/3-1.4:1.0/0003:24F0:0140.0003/input/input6
[    5.961495] hid-generic 0003:24F0:0140.0003: input,hidraw2: USB HID v1.10 Keyboard [Metadot - Das Keyboard Das Keyboard] on usb-0000:00:14.0-1.4/input0
[    5.981709] input: Metadot - Das Keyboard Das Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.4/3-1.4:1.1/0003:24F0:0140.0004/input/input7
[    6.049240] input: Metadot - Das Keyboard Das Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.4/3-1.4:1.1/0003:24F0:0140.0004/input/input8
[    6.069891] hid-generic 0003:24F0:0140.0004: input,hidraw3: USB HID v1.10 Device [Metadot - Das Keyboard Das Keyboard] on usb-0000:00:14.0-1.4/input1
[   10.683843] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
[   10.789106] loop: module loaded
[   10.828227] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   10.848354] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.857000] uhci_hcd: USB Universal Host Controller Interface driver
[   10.867549] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.877342] usbcore: registered new interface driver usb-storage
[   16.490030] EXT4-fs (md0): re-mounted. Opts: (null)
[   17.064811] systemd[1]: Inserted module 'autofs4'
[   17.101077] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   17.136143] systemd[1]: Detected architecture x86-64.
[   17.156629] systemd[1]: Set hostname to <localhost.localdomain>.
[   17.163398] systemd[1]: Initializing machine ID from random generator.
[   17.499141] systemd[1]: Listening on udev Kernel Socket.
[   17.506237] systemd[1]: Created slice system-getty.slice.
[   17.512835] systemd[1]: Reached target Swap.
[   17.518265] systemd[1]: Listening on Journal Audit Socket.
[   17.524957] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.532051] systemd[1]: Reached target Network.
[   17.572858] random: systemd-random-: uninitialized urandom read (512 bytes read)
[   17.595700] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   17.603825] systemd-journald[957]: Received request to flush runtime journal from PID 1
[   17.623523] Bridge firewalling registered
[   17.636420] mpls_gso: MPLS GSO support
[   17.855357] cryptd: max_cpu_qlen set to 1000
[   17.891220] input: PC Speaker as /devices/platform/pcspkr/input/input9
[   17.898464] EFI Variables Facility v0.08 2004-May-17
[   17.918970] pstore: Registered efi as persistent store backend
[   17.949310] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input10
[   17.949329] ACPI: Sleep Button [SLPB]
[   17.949374] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input11
[   17.949385] ACPI: Power Button [PWRB]
[   17.949407] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input12
[   17.949440] ACPI: Power Button [PWRF]
[   18.058390] AVX2 version of gcm_enc/dec engaged.
[   18.058391] AES CTR mode by8 optimization enabled
[   18.107776] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   18.107806] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   18.113929] random: crng init done
[   20.455383] Process accounting resumed
[   24.455879] fuse: init (API version 7.31)
[   36.410600] usb 3-1.1: USB disconnect, device number 3
[ 2391.009967] md: md0: resync done.
[15342.982660] i40e 0000:01:00.1 eth1: NIC Link is Up, 10 Gbps Full Duplex, Flow Control: None
[15342.984218] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[15343.809053] i40e 0000:01:00.1 eth1: NIC Link is Down
[15344.332730] i40e 0000:01:00.1 eth1: NIC Link is Up, 10 Gbps Full Duplex, Flow Control: None
[15425.583990] NET: Registered protocol family 17
[16419.825632] 8021q: 802.1Q VLAN Support v1.8
[16419.825642] 8021q: adding VLAN 0 to HW filter on device eth0
[16419.825651] 8021q: adding VLAN 0 to HW filter on device eth1
[54472.655816] i40e 0000:01:00.1 eth1: NIC Link is Down
[54481.366773] i40e 0000:01:00.1 eth1: NIC Link is Up, 10 Gbps Full Duplex, Flow Control: None
[60962.251907] i40e 0000:01:00.1 eth1: NIC Link is Down
[61124.248739] i40e 0000:01:00.1 eth1: NIC Link is Up, 10 Gbps Full Duplex, Flow Control: None
OK there’s the dmesg in 3 blocks since forum limits each post to 32k!
Seems like the “Intel Corporation Device 125c” is a:
Ethernet Controller I226-V
Info about this controller:
Launchdate: Q2’22
The driver used is named “igc” and exists in-tree only after Linux kernel 5.16.18.
Im not sure what its named in the out-of-tree drivers from Intel (quick search wont give any “igc” in the out-of-tree homepage over at Formerly Intel Ethernet Drivers - Browse Files at SourceForge.net ).
Your installation is using Linux kernel version:
So my best guess is that VyOS 1.3.6 wont support the Intel I226-V nic.
Regarding 1.5-rolling I think you should be safe if you download that ISO and use Etcher to put it into a USB-drive and then boot your box from that USB-drive and run VyOS as a “liveboot”. This should be sufficient to get an output of dmesg, lspci, lsmod and verifiy how that detects your Intel I226-V nic.
Edit: Digging through Linux kernel sources the first trace of the igc is for Linux Kernel 4.20-rc1 from 2018-10-17 according to (unless I have misread something):
Edit2: And according to No I225 Linux Driver (IGC) available? - Intel Community its plausible that the igc driver didnt exist until Linux kernel 5.16.18.
I would suggest building your own 1.4 (it’s very easy) and trying that.
Much less of a config jump from 1.3.6->1.4.0-epa
FYI you can filter the dmesg output for your Ethernet devices by using grep along with the pipe operator.
As tjh said you can build your own 1.4 rolling following the how to’s.
sudo dmesg | grep “eth”
Had the same Problems with 1.3.5 and ofc. With 1.5 it works. Will try 1.4-epa if I find the time.
Thanks for reporting your findings! I haven’t had a chance to get to this yet myself
