I am struggling to get 10G networking on VyOS under proxmox.
root@gw-vpn-0-s2s-d6-ds:/home/vyos# lspci
00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
00:01.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II]
00:01.2 USB controller: Intel Corporation 82371SB PIIX3 USB [Natoma/Triton II] (rev 01)
00:01.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 03)
00:02.0 VGA compatible controller: Device 1234:1111 (rev 02)
00:03.0 Unclassified device [00ff]: Red Hat, Inc Virtio memory balloon
00:05.0 SCSI storage controller: Red Hat, Inc Virtio SCSI
00:08.0 Communication controller: Red Hat, Inc Virtio console
00:12.0 Ethernet controller: Red Hat, Inc Virtio network device
00:13.0 Ethernet controller: Red Hat, Inc Virtio network device
00:14.0 Ethernet controller: Red Hat, Inc Virtio network device
00:1e.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge
00:1f.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge
Here is another output
vyos@gw-vpn-0-s2s-d6-ds:~$ show interfaces ethernet eth0 physical
Settings for eth0:
Supported ports: [ ]
Supported link modes: Not reported
Supported pause frame use: No
Supports auto-negotiation: No
Supported FEC modes: Not reported
Advertised link modes: Not reported
Advertised pause frame use: No
Advertised auto-negotiation: No
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Port: Other
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Link detected: yes
driver: virtio_net
version: 1.0.0
Also I have tried VMXNET3 as well, but still got 1G link.
# ethtool -s eth0 speed 10000 duplex full
Cannot set new settings: Operation not supported
not setting speed
not setting duplex
# show interfaces ethernet eth0 physical
Settings for eth0:
Supported ports: [ TP ]
Supported link modes: 1000baseT/Full
10000baseT/Full
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Supports Wake-on: uag
Wake-on: d
Link detected: yes
driver: vmxnet3
version: 1.4.16.0-k-NAPI
firmware-version:
expansion-rom-version:
bus-info: 0000:00:12.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: yes
supports-priv-flags: no
I checked virtio drivers and it work fine.
Vmx3 does not work (speed 10000) even on ubuntu 18.04.
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.4 LTS"
root@openstack:/home/sever#
root@openstack:/home/sever# ethtool -s ens19 speed 10000 duplex full
not setting speed
not setting duplex
Does it work for you (10G vmxnet3) on any other system in proxmox?
I think this question for proxmox.
From proxmox documentation " * the vmxnet3 is another paravirtualized device, which should only be used when importing a VM from another hypervisor."
ref. https://pve.proxmox.com/wiki/Qemu/KVM_Virtual_Machines
