Proxmox/VyOS VLAN configuration
I’m familiar with VyOS (using edgerouter now) but new to proxmox and I’m having some difficulty to get the following VLAN networking setup to work. Hope somebody here can help :slight_smile:
My goal is to virtualize my edgerouter router inside proxmox. I want clients connected to the physical network to route via the virtualized VyOS instance. For testing I’m using manually set IPs on my laptop’s NIC, and struggling to reach my guest. Specifically I want:
  • Proxmox host reachable vmbr0(=eno1) @ tagged VLAN 10
  • VyoS inside proxmox via eth0(=vmbr0) @ tagged VLAN 10/20/30
Visually this should look something like this (I’m now trying to get the purple LAN part working, ignore the blue WAN part for now):
For Proxmox I’ve tried two network configurations (found here):
Code:
auto lo
iface lo inet loopback
iface eno1 inet manual
auto vmbr0
iface vmbr0 inet static
    address 172.17.10.4/24
    gateway 172.17.10.1
    bridge-ports eno1
    bridge-stp off
    bridge-fd 0
#LAN
and
Code:
auto lo
auto vmbr0
iface vmbr0 inet manual
    bridge-ports eno1
    bridge-stp off
    bridge-fd 0
    bridge-vlan-aware yes
    bridge-vids 2-4094
#LAN port
auto vmbr0.10
iface vmbr0.10 inet static
    gateway 172.17.10.1
#Mgmt interface
Within VyOS I’m trying the following configuration:
Code:
set interfaces bridge br0 enable-vlan
set interfaces bridge br0 member interface eth0 allowed-vlan 10
set interfaces bridge br0 member interface eth0 allowed-vlan 20
set interfaces bridge br0 member interface eth0 allowed-vlan 30
delete interfaces bridge br0 vif 10
set interfaces bridge br0 vif 10 address 172.17.10.1/24
set interfaces bridge br0 vif 10 description 'VLAN10'
set interfaces bridge br0 vif 20 address 172.17.20.1/24
set interfaces bridge br0 vif 20 description 'VLAN20'
set interfaces bridge br0 vif 30 address 172.17.30.1/24
set interfaces bridge br0 vif 30 description 'VLAN30'
set interfaces bridge br0 stp
In proxmox I’ve given the Vyos guest the vmbr0 network device without VLAN tag.
However this is not working. I can reach the Proxmox host at 172.17.10.4, either without using VLAN or using tagged VLAN10, but I cannot reach the VyOS guest, either from my laptop or from the proxmox host itself. Any idea what I’m doing wrong? Specifically:
  1. I want to be able to handle the VLAN configuration in my VyOS guest. Should I set ‘vlan aware’ bridge in proxmox or not?
  2. In VyOS I’d like to manage multiple VLANs on one interface, should I use a bridge for this or something else?
Thanks in advance! :slight_smile:
Could you delete it
And just add
Dump traffic on the eth0
Thanks @Viacheslav! monitor was a useful suggestion I might’ve thought of myself :slight_smile:
It turned out that the underlying eth0 interface was not up. It’s now working. For reference, my interfaces configuration is now as follows:
    bridge br100 {
        enable-vlan
        member {
            interface eth0 {
                allowed-vlan 10
                allowed-vlan 20
                allowed-vlan 30
                allowed-vlan 40
        stp
        vif 10 {
            description VLAN10-Mgmt
        vif 20 {
            description VLAN20-Trusted
        vif 30 {
            description VLAN30-Guest
        vif 40 {
            address 172.17.40.1/24
            description VLAN40-IoT
        description LAN
        vif 1 {
            address dhcp
            description WAN
    loopback lo {
