[Q] How to build libmnl
Dear developers.
Does anyone knows how to build libmnl submodule
Sincerely.
[code]
git submodule update --init pkgs/libmnl
cd pkgs/libmnl
git checkout helium
[code]
 dpkg-buildpackage -rfakeroot -D -us -uc -i -b -nc
dpkg-buildpackage: export CFLAGS from dpkg-buildflags (origin: vendor): -g -O2
dpkg-buildpackage: export CPPFLAGS from dpkg-buildflags (origin: vendor):
dpkg-buildpackage: export CXXFLAGS from dpkg-buildflags (origin: vendor): -g -O2
dpkg-buildpackage: export FFLAGS from dpkg-buildflags (origin: vendor): -g -O2
dpkg-buildpackage: export LDFLAGS from dpkg-buildflags (origin: vendor):
dpkg-buildpackage: source package libmnl
dpkg-buildpackage: source version 1.0.3-5+vyos1+helium1
dpkg-buildpackage: source changed by Daniil Baturin <[email protected]>
 dpkg-source -i --before-build libmnl
dpkg-buildpackage: host architecture amd64
dpkg-source: info: using options from libmnl/debian/source/options: --compression=bzip2 --compression-level=9
 debian/rules build
autoreconf -i
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4'.
libtoolize: copying file `m4/libtool.m4'
libtoolize: copying file `m4/ltoptions.m4'
libtoolize: copying file `m4/ltsugar.m4'
libtoolize: copying file `m4/ltversion.m4'
libtoolize: copying file `m4/lt~obsolete.m4'
 fakeroot debian/rules binary
dh binary
   dh_install
dh_install: libmnl-dev missing files (usr/include/*), aborting
make: *** [binary] Error 2
dpkg-buildpackage: error: fakeroot debian/rules binary gave error exit status 2
debuild: fatal error at line 1325:
dpkg-buildpackage -rfakeroot -D -us -uc -i -b -nc failed
make: *** [libmnl] Error 29
Hi all,
I’m having the same problem, anyone managed to fix it?
Thanks in advance,
Adrian
I have scripts to rebuild the entire distribution. You might want to look at 510 Software Group - That worked the last time I ran it, about a month ago.
