policy {
route PEERING-LIST {
rule 100 {
destination {
group {
network-group PEERING-LIST
set {
mark 200
traffic-policy {
shaper PEERING {
bandwidth 10mbit
class 14 {
match PEERING-LIST {
mark 200
default {
bandwidth 10mbit
queue-type fair-queue
duplex auto
hw-id 00:25:90:37:41:1d
policy {
pppoe 0 {
default-route auto
mtu 1492
name-server auto
traffic-policy {
out PEERING
| Welcome to VyOS
Linux SLBB-NAS-TEST 4.19.89-amd64-vyos #1 SMP Fri Dec 20 15:24:48 UTC 2019 x86_64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Jan 14 18:29:49 2020 from
???@SLBB-NAS-TEST:~$ show configuration
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
group {
network-group PEERING-LIST {
network 173.194.0.0/16
network 74.125.0.0/16
network 216.58.0.0/16
ipv6-src-route disable
ip-src-route disable
log-martians enable
send-redirects enable
source-validation disable
syn-cookies enable
address ??.??.??.??/30
duplex auto
hw-id 00:25:90:37:41:1c
smp-affinity auto
speed auto
duplex auto
pppoe 0 {
default-route auto
mtu 1492
name-server auto
traffic-policy {
out PEERING
noc@SLBB-NAS-TEST:~$ show configuration commands
set firewall all-ping ‘enable’
set firewall broadcast-ping ‘disable’
set firewall config-trap ‘disable’
set firewall group network-group PEERING-LIST network ‘173.194.0.0/16’
set firewall group network-group PEERING-LIST network ‘74.125.0.0/16’
set firewall group network-group PEERING-LIST network ‘202.177.244.0/24’
set firewall group network-group PEERING-LIST network ‘124.155.0.0/16’
set firewall group network-group PEERING-LIST network ‘216.58.0.0/16’
set firewall ipv6-receive-redirects ‘disable’
set firewall ipv6-src-route ‘disable’
set firewall ip-src-route ‘disable’
set firewall log-martians ‘enable’
set firewall receive-redirects ‘disable’
set firewall send-redirects ‘enable’
set firewall source-validation ‘disable’
set firewall syn-cookies ‘enable’
set firewall twa-hazards-protection ‘disable’
set interfaces ethernet eth0 address ‘49.143.252.11/27’
set interfaces ethernet eth0 duplex ‘auto’
set interfaces ethernet eth0 hw-id ‘00:25:90:37:41:1c’
set interfaces ethernet eth0 smp-affinity ‘auto’
set interfaces ethernet eth0 speed ‘auto’
set interfaces ethernet eth1 duplex ‘auto’
set interfaces ethernet eth1 hw-id ‘00:25:90:37:41:1d’
set interfaces ethernet eth1 pppoe 0 default-route ‘auto’
set interfaces ethernet eth1 pppoe 0 mtu ‘1492’
set interfaces ethernet eth1 pppoe 0 name-server ‘auto’
set interfaces ethernet eth1 pppoe 0 traffic-policy out ‘PEERING’
set interfaces ethernet eth1 smp-affinity ‘auto’
set interfaces ethernet eth1 speed ‘auto’
set interfaces loopback lo
set nat source rule 300 outbound-interface ‘eth0’
set nat source rule 300 source address ‘10.99.99.0/24’
set nat source rule 300 translation address ‘masquerade’
set policy route PEERING-LIST rule 100 destination group network-group ‘PEERING-LIST’
set policy route PEERING-LIST rule 100 set mark ‘200’
set protocols static route 0.0.0.0/0 next-hop 49.143.252.1
set service https api keys id 1
set service https api port ‘7000’
set service pppoe-server access-concentrator ‘SLBB’
set service pppoe-server authentication mode ‘radius’
set service pppoe-server authentication radius-server 122.170.105.97 secret ‘localkey’
set service pppoe-server authentication radius-settings acct-timeout ‘0’
set service pppoe-server authentication radius-settings nas-identifier ‘VYOS_SLBB_NAS’
set service pppoe-server authentication radius-settings nas-ip-address ‘49.143.252.11’
set service pppoe-server authentication radius-settings rate-limit enable
set service pppoe-server client-ip-pool start ‘10.99.99.2’
set service pppoe-server client-ip-pool stop ‘10.99.99.250’
set service pppoe-server dns-servers server-1 ‘8.8.8.8’
set service pppoe-server interface eth1
set service pppoe-server local-ip ‘49.143.252.11’
set service pppoe-server service-name ‘smartlink123’
set service ssh
set system console device ttyS0 speed ‘9600’
set system host-name ‘SLBB-NAS-TEST’
set system login user noc authentication encrypted-password ‘$6$wPdPXUEcZ$Q.aksYzaevq5676xF5n0bJRp8pcnvGIFRidSlXdFbuDrKEAy2YvGANw0sQikecpM5QzLHohjbLvBaAauFJdu50’
set system login user noc authentication plaintext-password ‘’
set system login user noc level ‘admin’
set system login user vyos authentication encrypted-password ‘$6$Du9fx1DRTx$RT.ekLj8O/RTgrnrLrEpRaSqWyBUa/dI7g/YRVLNU7O.oySOKw0CA6NNy0zbXD0lW.eKK6RXeCT65kIzyvYLt1’
set system login user vyos authentication plaintext-password ‘’
set system login user vyos level ‘admin’
set system name-server ‘8.8.8.8’
set system time-zone ‘Asia/Kolkata’
set traffic-policy shaper PEERING bandwidth ‘auto’
set traffic-policy shaper PEERING class 14 bandwidth ‘10240kibps’
set traffic-policy shaper PEERING class 14 burst ‘15k’
set traffic-policy shaper PEERING class 14 match TESTING mark ‘200’
set traffic-policy shaper PEERING class 14 queue-type ‘fair-queue’
set traffic-policy shaper PEERING default bandwidth ‘20480kibps’
set traffic-policy shaper PEERING default burst ‘15k’
set traffic-policy shaper PEERING default queue-type ‘fair-queue’
I made changes as required, but still same result. PPPoE user not bypassing destination IP pools rate-limit.
find below the configuration:
set firewall group network-group PeeringList network ‘173.194.0.0/16’
set firewall group network-group PeeringList network ‘216.58.0.0/16’
set firewall group network-group PeeringList network ‘103.5.187.0/24’
set interfaces ethernet eth1 pppoe 0 traffic-policy out ‘PEER’
set policy route Peering rule 100 destination group network-group ‘PeeringList’
set policy route Peering rule 100 set mark ‘222’
set service pppoe-server authentication local-users username mahendra password ‘123456’
set service pppoe-server authentication local-users username mahendra rate-limit download ‘2048’
set service pppoe-server authentication local-users username mahendra rate-limit upload ‘1024’
set service pppoe-server authentication mode ‘local’
set service pppoe-server client-ip-pool start ‘139.5.98.2’
set service pppoe-server client-ip-pool stop ‘139.5.98.250’
set service pppoe-server local-ip ‘139.5.98.1’
set service ssh
set traffic-policy shaper PEER class 3 bandwidth ‘10mibit’
set traffic-policy shaper PEER class 3 match TEST mark ‘222’
set traffic-policy shaper PEER default bandwidth ‘10mibit’
set traffic-policy shaper PEER default queue-type ‘fair-queue’
Hi @mahendra, did you restart pppoe daemon after manually changing? restart pppoe-server
check please also sudo tc -s -d filter show dev ppp0
and also provide output of command show policy route
set interfaces ethernet eth1 pppoe 0 policy route ‘Peering’
status is same, not bypassing destination IP Pools
173.194.0.0/16
216.58.0.0/16
103.5.187.0/24
set service ssh
set traffic-policy shaper PEER bandwidth ‘auto’
set traffic-policy shaper PEER class 3 burst ‘15k’
set traffic-policy shaper PEER class 3 queue-type ‘fair-queue’
set traffic-policy shaper PEER default burst ‘15k’
100 set all 0 0
condition - saddr 0.0.0.0/0 daddr 0.0.0.0/0 /* Peering-100 */ MARK set 0xde
10000 drop all 0 0
NO, not working…
set service ssh
set system login user vyos authentication encrypted-password ‘$6$SKdAJ9ZuzN6JD.3$NseWPH/wzbVSjJkSXHQwz3fWR0kV0XZfFBFa3FT9oboiun2MQvyl9M4Xfly6rNUiRvRLEujIpfYrSFxfLgBQP1’
set interfaces ethernet eth0 policy route 'PEERING'
set policy route PEERING rule 10 set mark '222'
set policy route PEERING rule 10 source group network-group 'PEERING-LIST'
That worked for Dmitry and myself. We were able to bypass the PPPoE rate-limit.
set interfaces ethernet eth0 policy route ‘PEERING’
set policy route PEERING rule 10 set mark ‘222’
set policy route PEERING rule 10 source group network-group ‘PeeringList’
set service ssh
If you want access to router, I can allow you to check …
Please keep exactly that configuration, so that we are in the same page.
Please make sure /etc/accel-ppp/pppoe/pppoe.config includes
[shaper]
fwmark=222
down-limiter=htb
Please note that, if you reboot the machine, that section will be gone and you will have to configure it again.
On a PPPoE client run iperf -s
Take a host with an IP address belonging to your defined network-group.
Please note that this host should be accessible from the interface eth0 of the PPPoE server.
Run the following command in that host: iperf -c <PPPoE_client_IP_address>
Check the output, you should see the traffic has not been affected by the PPPoE Server rate-limit configuration.
