QoS: limit outbound traffic rate for particular source
Hello there.
I’m looking for example to limit outbound traffic rate from external interface (e.g. from eth0) if the source of this traffic belongs to particular network (e.g. 10.20.0.0/24). I really can’t understand all these QoS mechanisms, I’m confused so much.
Try these commands:
set traffic-policy limiter LIMIT_SMTP
set traffic-policy limiter LIMIT_SMTP class 10 bandwidth 512kbit
set traffic-policy limiter LIMIT_SMTP class 10 match TRAFFIC_SMTP ip destination port smtp
set traffic-policy limiter LIMIT_SMTP class 10 match TRAFFIC_SMTP ip destination address xx.xx.xx.xx
set traffic-policy limiter LIMIT_SMTP class 10 match TRAFFIC_SMTP ip source  address yy.yy.yy.yy
set interfaces ethernet eth_xx traffic-policy in LIMIT_SMTP
Remove smtp related rule (destination port smtp) if you don’t need it.
Insert correct IPs into “address xx.xx.xx.xx”.
