QOS match tcp ack not working
I want to add QOS rules to match TCP ack flag.
I added this vyos configuration:
set policy shaper EGRESS-QOS bandwidth '20gbit'
set policy shaper EGRESS-QOS class 2 bandwidth '20%'
set policy shaper EGRESS-QOS class 2 ceiling '100%'
set policy shaper EGRESS-QOS class 2 description 'qACK'
set policy shaper EGRESS-QOS class 2 match-group 'qACK'
set policy shaper EGRESS-QOS class 2 priority '0'
set policy shaper EGRESS-QOS class 2 queue-type 'fair-queue'
set policy shaper EGRESS-QOS default bandwidth '43%'
set policy shaper EGRESS-QOS default ceiling '100%'
set policy shaper EGRESS-QOS default priority '7'
set policy shaper EGRESS-QOS default queue-type 'random-detect'
set traffic-match-group qACK match ACK ip tcp ack
set traffic-match-group qACK match SYNACK ip tcp syn
set interface bond0 egress 'EGRESS-QOS'
but I there is no tc configuration:
vyos@am-rt-001# tc filter show dev bond0
vyos@am-rt-001#
Same issue if I use traffic-matech-group or not.
But if I add other ‘simple’ rules, like match address or port, I can see them with tc command.
can you help me about this issue please ?
thanks in advance
Vyos version:
vyos@am-rt-001# run show version
Version:          VyOS 1.5-stream-2025-Q1
Release train:    circinus
Release flavor:   generic
Built by:         VyOS Networks Iberia S.L.U.
Built on:         Thu 13 Feb 2025 18:06 UTC
Build UUID:       b38b28e0-a516-4f56-a596-5502ae094d3b
Build commit ID:  5128f5e45cdb73-dirty
Architecture:     x86_64
System type:      KVM guest
Hardware vendor:  QEMU
Hardware model:   Ubuntu 24.04 PC (i440FX + PIIX, 1996)
Hardware S/N:
Second question:
why command
show qos shaper interface bond0 never returns result.
I know on Vyos 1.3, show queueing worked like a charm
There was a bug. If the name of your policy has a dash, it won’t show anything. Just rename your policy to something without that dash and the command will work.
Thanks @L0crian , indeed, without dash it’s OK.
vyos@am-rt-001# run show qos shaper interface bond0
Interface: bond0
Policy Name: EGRESSQOS
Class    Type        Bandwidth    Max. BW       Bytes    Pkts    Drops    Queued
root     htb         20.000 Gb  20.000 Gb  561.200 KB    8791        0         0
2        sfq          4.000 Gb   1.000 Gb        0  B       0        0         0
10       fq_codel     2.000 Gb   1.000 Gb        0  B       0        0         0
default  red          8.600 Gb  20.000 Gb  561.200 KB    8791        0         0
maybe another litle bug with this command:
vyos@am-rt-001# run show qos shaper interface bond0 class 10
Interface: bond0
root     htb         20.000 Gb  20.000 Gb  606.830 KB    9638        0         0
default  red          8.600 Gb  20.000 Gb  606.830 KB    9638        0         0
I think I should to see only details of class 10 no ?
No, that was the intent with the command. You’ll always see root and default, it just filters the classes. In your example 2 is no longer present.
As far as your original problem, it appears you’ve found a bug. The filter is empty when trying to apply those flags. This returns no output:
sudo tc filter show dev eth1
If you manually configure it with tc, it’s fine:
filter parent 1: protocol ip pref 10 u32 chain 0
filter parent 1: protocol ip pref 10 u32 chain 0 fh 800: ht divisor 1
filter parent 1: protocol ip pref 10 u32 chain 0 fh 800::800 order 2048 key ht 800 bkt 0 flowid 1:2 not_in_hw
  match 00060000/00ff0000 at 8
run show qos shaper
Interface: eth1
Policy Name: EGRESS-QOS
root     htb       20.000 Gb  20.000 Gb  103.666 KB     791        0         0
2        sfq        4.000 Gb   1.000 Gb       74  B       1        0         0
You can submit a bug report at https://vyos.dev
thanks a lot for your help.
Yep, I did it manually and it’s work too.
I will post this issue on vyos.dev
have a good day
Hum… ok I’m waiting patiently
