Hi all,
question for dhcp failover.
if one node goes down and will be replaced with a new one.
I will test this scenario twice a day and in the first time, the dhcp failover doesn´t come up. It feels like a split brain.
My question is how often will there be synced between nodes. One node goes down the dhcp is working without interruption
I found this nice blog post how complicated is the isc failover
I have attached my config file.
Would it be better to say split 255 , to say one vyos is the dhcp master.
My version
VyOS 1.4-rolling-202311220309
### Autogenerated by dhcp_server.py ###
# For options please consult the following website:
# https://www.isc.org/wp-content/uploads/2017/08/dhcp43options.html
# log-facility local7;
ddns-update-style none;
option rfc3442-static-route code 121 = array of integer 8;
option windows-static-route code 249 = array of integer 8;
option wpad-url code 252 = text;
option rfc8925-ipv6-only-preferred code 108 = unsigned integer 32;
# Vendor specific options - Ubiquiti Networks
option space ubnt;
option ubnt.unifi-controller code 1 = ip-address;
class "ubnt" {
match if substring (option vendor-class-identifier , 0, 4) = "ubnt";
option vendor-class-identifier "ubnt";
vendor-option-space ubnt;
# DHCP failover configuration
failover peer "internal-network" {
primary;
mclt 1800;
split 128;
address 192.168.2.3;
port 647;
peer address 192.168.2.2;
peer port 647;
max-response-delay 30;
max-unacked-updates 10;
load balance max seconds 3;
# Shared network configration(s)
shared-network LAN {
authoritative;
subnet 192.168.2.0 netmask 255.255.255.0 {
option domain-name-servers 192.168.2.1;
option domain-name "internal-network";
option domain-search "en.example.com", ;
option routers 192.168.2.1;
default-lease-time 900;
max-lease-time 900;
pool {
failover peer "internal-network";
deny dynamic bootp clients;
range 192.168.2.20 192.168.2.254;
on commit {
set shared-networkname = "LAN";
