I’m a lover of zone based firewalls, and I like to be very granular for security reasons, hence lots of rules…
We have a client on 1.3.5 with a bunch of zones and rules, the config file is about 34,000 lines of mostly firewall rules. NAT is handled by another router.
Their hardware is an old Dell R220 with a quad core Xeon @ 3.xGhz… The time it takes to go from “Mounting VyOS Config…done.” to an actual login prompt and a usable system is about 30 minutes.
Our of curiosity I wanted to see if it was a CPU thing and if it was core or MHz limited.
On my work laptop I have a Ryzen 5, I spun up a virtual guest and loaded the clients config… this is a rough benchmark because I was doing other things on the laptop but I think the results are still revealing.
@6 cores, 4GB RAM the load time was 22 minutes
@4 cores, 4GB RAM the load time was 23 minutes
@2 cores, 4GB RAM the load time was 25 minutes
so it all seems the same no matter the core count…
Then I dropped the CPU frequency from the average of 3.5GHz to 1GHz
@2 cores (1GHz), 4GB RAM the load time was 88 minutes and it brought me to the login prompt but it also said “migrate rl-system firewall failed”
So… the cores didn’t seem to make a real difference for loading all those firewall rules. Going from 1GHz to 3.5GHz made it load 3.5x faster… so here frequency on loading firewall rules seems king.
Anyway, I’m getting over a cold and am putzing about so ran this quick test (we’ll it took 4 hours to complete), and wanted to put it out there for all those with the same unanswered question. I ordered some used higher frequency CPUs and we’ll see what they do ![]()
Next to see what 1.4 does… and thank you again for keeping zone based firewalls, if it had been dropped my confidence in my systems would have dropped.
