When configuring VyOS radius authentication it appears to only work if not using TLS. For example, configuring it with JumpCloud as a radius server, the “Require Secure Protocols” selection in JumpCloud must be unchecked for the authentication to work. JumpCloud lists secure protocols as PEAP, EAP-TTLS/PAP and EAP-TLS. Is there a workaround for this, or can any of these secure protocols be used for radius authentication in VyOS?
